Question about Dell 810 All-In-One InkJet Printer
I get a cartridge missing message in a Dell 810 printer
I have installed a brand new print cartridge in a Dell A10 810 printer but every time I try to print I get a 'Print Cartridge Missing' message. I have tried reinstalling it and switching the printer off and on. I reinstalled the old cartridge and did not get the error message. What do I do now?
I am having the exact same problem. Just got my cartridge refilled, and whenever I hit the print command, I keep getting the message "printer cartridge missing." It's obviously there! gaahhh, so annoying! I hate dell.
Posted on Jun 23, 2010
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
I have a lexmark x1240 and just installed a new cartridge. I keep getting an error message that says " print cartridge missing" install print cartridge even though both cartridges are in the printer.
If you insert the old cartridge, does it recognize it? If it does, then it's a problem with the new cartridge. Try to check if you already have taken out the protective tapes out of the cartridge.
If it still doesn't recognize the old cartridge, then it's a problem with the printer.
Nov 29, 2012 | Lexmark X1240 All-In-One InkJet Printer
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
Cartridge Error 50C consult user guide. I
Cartridge Error
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Dell 720 won't print color, color ink cartridge missing
check to see if the color cartridge has the plastic tab on the cartridge. Remove and reinsert cartridge.
Sep 13, 2009 | Dell Inkjet 720 Printer
Missing black ink cartridge
Unplug the printer from the wall. Also remove the power brick for 60 seconds. This will reset any error messages you get from the printer. Plug everything back in and power on the printer. Take out the Dell black cartridge and reseat it. Put it back in and do the same for the color cartridge. When you close the printer it should try to print an alignment page.
Aug 11, 2009 | Dell A960 All-In-One InkJet Printer
Printer Not Registering New Cartridge
try installing the original cartridges u got with the printer & reseating the power cable assembly....make sure u hav removed the tape frm the cartridge....
Jul 11, 2008 | Dell 810 All-In-One InkJet Printer
New cartridge
Clean the copper contacts of the cart and reset back in the printer and if your getting the same error message please replace the cart with another cart .......
May 13, 2008 | Dell 922 All-In-One InkJet Printer
Dell 962
Just found this partial fix: "Try removing the color cartridge and try printing with the color cartridge out. If it gives you a message that the cartridge is missing, it will still allow you to print by clicking "continue". And from there, it will allow you to print black. I think it really is a problem with your color cartridge." From searching the net, this seems to be a major problem with no solution from Dell!
Feb 14, 2007 | Dell 962 Photo All-In-One InkJet Printer
Dell 810 All-In-One InkJet Printer Logo
321 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
