Question about Bose QuietComfort 2 Consumer Headphones
The wire has split
The wire going into the headphone has split
  • Bose Master
  • 5,126 Answers
You might want to check out my tip on replacing dodgy cable/plugs on headphones.
Posted on May 14, 2010
Broken speaker wire
Hello, Get some black electrical tape for ace, lowes or home depot and put around the exposed wires.
Apr 08, 2014 | X-1 x Interval 4G Waterproof Headphone...
Can you plug a stereo headphone (for on stage monitor) to aux 1 on a Soundcraft fx12? This output seems to be only mono...
Generally mono outputs on this kind of mixer are usually balanced. This means all three poles of the connector are connected. The hot or plus signal (tip) will go to the left of your phones, the cold or minus (ring) will go to the right. This will be ok from a sound point of view But it may not have enough drive to make the phones loud enough.
If you only hear a signal in the left then the output is unbalanced.
A simple fix is a cheap headphone amp (less than 20 pounds) and a simple jack to two phono lead (wired as a split). There is a ton of old audio equipment about for very little money including some very small mixers, that have headphone outputs, that is what I have done a lot in the past.
Oct 31, 2013 | Soundcraft Music
Audio cable snapped -
Buy a new cable. I don't know what the application here is, but if you have the capacity, go to either HDMI, digital or optical, rather than straight RCA cables.
Jul 28, 2017 | Sennheiser RS 110 Consumer Headphones
The right earbud on my Bose earphones stopped working. It will only produce sound when I move the cord a certain way. I've plugged them into other devices to make sure it wasn't the headphone jack. Any...
I've experience this issue on a different set of headphones and unfortunately it means that there is a split in the wiring in the headphone cables. The only option I found is to contact Bose for a repair. If you are under warranty then this is a quick and easy process, otherwise they request that you pay for the repairs to the headphones. Good luck and have a nice day!
May 03, 2011 | Bose In-Ear Headphones
There's no sound coming out from left earphone
Try your headphones in a different audio device. If the problem persists than the headphones have a split in the wiring for the left earbud. If you are under warranty then Sennheiser will happily repair your headphones.
May 03, 2011 | Sennheiser Sport II CX 380 Stereo...
My jvc foldable headphones the right side is not
you have to take off wire casing near the split and resauder
May 11, 2010 | Audio Players & Recorders
Cracked wires
I recommend getting some Shure headphones if you are into the in-ear style. In reality, better sound is achieved by larger older style headphones like a pair of Ultrasones or Sennheisers.
http://www.sweetwater.com/c412--Shure--Headphones
older style
http://www.sweetwater.com/store/detail/HD280Pro/
Jun 19, 2009 | Bose in-ear headphones - Black with...
Wire loose
If you can carefully take the foam earpad off you might find screws holding the speaker plate to the cup.
May 11, 2009 | Altec Lansing AHP712i Consumer Headphones
Wireless headphone connection to multiple components?
Cat,    Splitting an optical output is not recommended.  In fact it would require an optical patch bay, which would be overkill. You could use the headphone output on the front of the Denon AVR3805.    Because this output is behind a door it might be a cleaner looking set up to use the optical output on the top left looking at the back of the unit.  Because those two optical outputs are labeled "optical 3 and 4" they are zone outputs, they should work without having to "map" or patch them internally. The outputs here will be controlled independently as zones from the receiver's remote.      The easiest option looks to be the analog "pre output" located in the middle of the back of the receiver.  The left-most two rca jacks you want to use are labeled "front" and are white over red.  This output will work fine.  Control of the volume will be from the headphone unit and not the receiver.
Jan 07, 2009 | Audio Players & Recorders
Hooking up wireless headphones into the tv
u have to split the signal by having both the tv and the headphones getting the input,as you're probably only have the audio cables going to the headphones.You need an audio splitting cable (it has 4 malle connections) so you can put 2 in the tv and 2 in the headphone base.
Jun 16, 2008 | Radio Communications
Bose QuietComfort 2 Consumer Headphones Logo
148 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
