Question about Averatec 3150H Notebook
Hook up wireless interenet
Trying to hook up wireless internet connection and Comcast Tech tells me there is a problem with the IP# 169 which preceeds all the other IP #;s and needs to be removed. Suggest I contact manufacturer which I thought this site was. Have already paid the premium assistance fee and got no response.
  • johnchand8 Apr 04, 2008
    I cvan see wireless network and have all the bars but my computer will not hook up to it even if the network is unsecure. At home it hooks up with no problem
    Scholar:
  • 46 Answers
Did you by any chance give you router the mac address on the wireless card? Do you have the comcast version of a netgear wireless router? Any wireless router will do also. Does not have to be netgear or from comcast. You can get online by the network cable right?. Where else are you trying to connect to wirelessly?
Let me know
comier957
Posted on Aug 10, 2008
Belkin 54g Wireless DSL/Cable Router (DHF5D72304): Im trying to hook my wii up to the internet and it...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings change channel type to 3 or 6 or 11 and save so you get better signal.
Then save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
May 17, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I am trying to hook up my ps3 to the internet. It
most likely the problem is that you need to set up your router to be on the same subnet of your modem.
please contact D-Link support- they have a great one at http://www.dlink.com/support/ or contact the ISP's support and they can help
Mar 10, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
We have wireless internet using Netgear router.... we are trying to connect xbox to the internet using this router, but cannot recognise IP address, how can we set this up?
There are so many possible steps to take to do this..
First, make sure your wireless network is working, and a computer can use it to get on the internet..
Then , if you want to hook the xbox up wirelessly, you will need the wireless adapter made especially for the xbox..
) or you will need to hook the xbox up by an ethernet cable (
Then, check out this link, about halfway down the page is an in depth guide on how to hook the xbox up wirelessly..
http://www.microsoft.com/windowsxp/using/networking/setup/xbox.mspx
Nov 02, 2009 | NetGear WG311T 802.11g/b Wireless Adapter
I'm trying to hook up my modem through my router. My last router had an ip address of its own which I used to tell it to work through the router. Does the sb4220?
You may want to have the modem working with your system first and hook up your router after wards.
Disconnect your router and modem.
Reboot your system.
Run your hard wire direct to your SB4220 from computer net card.
Allow to load whatever drivers necessary.
On your computer type ipconfig /all This will show you all your information.
Try the internet and see if it works. If you know the ip of your carrier, Type ping ????? ie: Ping comcast.net
If you recv. a timeout you still have problems.
If you succeed, you are their.
If not, type ipconfig /renew This will reset your ip and configurations.
Now, hook up your router and you should be their.
Oct 08, 2009 | Arris SURFboard SB4220 Modem
169 IP address just happened and now have limited to no connectivity use comcast as a provider It's a dell 2300 dimension help
This is a common networking occurrence. This is called APIPA. See this link: http://www.webopedia.com/TERM/A/APIPA.html APIPA is an IP address which is assigned when no other address is available. Whatever Windows version you have, this will work if it's above Windows 95. Click on the Start menu, choose "Run", type in "cmd.exe" once you get a command prompt, type in "ipconfig /release", then "ipconfig /renew". This will release the APIPA address and attempt to get a valid address. Hope this helps.
Jun 08, 2009 | Dell Inspiron 6400 Notebook
Trying to install router for wireless
If that's hooked to comcast you can only have one computer hooked up to it, and no modems as they block mac address. If you are a Comcast customer there is a workaround. Turn on your wife's wireless if she hasit, if not get her a wireless card USB is easiest. Turn on sharing on that wireless card and you will be able to access the internet through your wifes computer, and not run afoul of your Comcast agreement. Or request an upgrade to a wireless router from Comcast but your rent goes from $3.00 per month to $10.00!
May 12, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Cannot share my cable modem connection
You need to connect a router to the cable modem.  The router then gets an IP address from Comcast and provides a gateway between the computers connected to the router.
The modem expects to communicate with a single Ethernet device, and provides an IP address to the first device that provides a piece of data called a MAC address.  By placing a router in-between, the router gets the IP address that lets you communicate on the Internet.  It provides local IP addresses to the equipment connected to the local Ethernet and "routes" those to the Internet.  You can either hook your two devices into the router if it has enough ports, or hook you switch to the router and hook your PC and PS3 into the switch.
May 05, 2009 | Linksys EtherFast EZXS16W 16-Port Ethernet...
Internet hookup
This is not the manufacturer's site, but i will try to help.
Is it your own network?
You need to make sure that the network is not protected, or you'll need the password.
Go to Start>Control Panel on your computer
Then go to Network Connections
There should be an icon for your wireless connection.
Right-click -> select Properties
In the selectbox select 'Internet Protocol (TCP/IP)'
Click Properties
Check if 'Obtain an IP-address automatically' and 'Obtain DNS-server' are selected
If they were not, Press <Ok> two times and try to connect to the wireless network again.
Can you also tell what IP-address you get?
Find it by going to Start > Run
Type 'cmd' without the quotation marks and press <Ok>
you get a black command box
type 'ipconfig', again without the quotation marks and press <Enter>
Please tell me the IP-address it tells you...
Mar 27, 2008 | Averatec 3200 Notebook
Laptop (Averatec Model #3150
Hi
I am try to take a stab at answering your query.
Internet Protocol (IP) Address preceeding with "169" means your PC is not receiving IP Address "generally" from your Boradband Modem or Internet Service Provider (ISP). The PC through Automatic Private Internet Protocol Addressing (APIPA) is assigning itself a temporal IP address.
This conditions means either
1. Dynamic Host Configuration Protocol (DHCP) Client service is not running properly on your PC (Unlikely)
2. There is no connection between your PC and Broadband Device or ISP wired or wirelessly (very likely)
3. DHCP Server Service is not configured or not running on Boardband device (likely) or ISP (unlikely)
4. Some firewall software when improperly configured are known to block all ports and services. This can block TCP Ports 67 and 68 used by DHCP Client/Server communication (quite likely)
Some pointers for more info;
1. Your query suggest your issues are limited to Wireless connection. Can you access Internet through wired connection? If so;
a) What Wired connection is in use? USB or Ethernet?
b) Is wired connection through same Broadband device?
c) What IP is assigned to your PC in wired connection?
d) If wired connection works, is IP assignment static or by DHCP?
e) What Boardband device is in use? In which mode is the device set to? Router/Bridge
2. If you can't connect both wired and wireless, then it is unlikely your PC hardware is at fault. Call your Broadband Provider for further help and configuration. Try entily disabling your firwall software (if installed) and test conection.
3. If you can connect through wired connection and your IP Address does not proceed with "192.168" or "172.16" then your boadband device is likely in a bridge mode. In bridge mode, the DHCP Server Service on your boardband device is disabled. Most ISPs will only assign only one IP address to a user. If an IP address has been assigned to your PC on the wired connection, then the wireless connection will not receive an IP address and therefore your PC will assign itself an IP in the range "169.254"
Regards
Mike
Mar 27, 2008 | Averatec 3150H Notebook
Trying to hook up lap top to wireless internet. Comcast tech says there is problem with IP# 169 which preceeds other numbers and needs to be removed for hookup. How can I accomplish this? Model #3150H
Usually you will have an IP address starting with 169 if the adapter cannot get an ip address from anywhere, it is an autmoatic IP address.
What operating system (Windows XP or 2000 or Vista) are you using?
Mar 27, 2008 | Computers & Internet
Averatec 3150H Notebook Logo
151 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
