Question about Whirlpool Duet GHW9150P Front Load Washer
What does f-24 mean?
I have a Whirlpool Duet Sport Washer and the error that keeps coming up isf-24 Can someone tell me what this means and how do I fix it?
Inside the machine should be repairmans instructions. this includes explanations for all the error codes.
you will have to remove the front access panel
Posted on May 09, 2010
I Have a whirlpool sport ht a number F5 came one what does this mean
The "F5" error means that the temperature sensor has recorded an unusual reading while using hot water. This usually is a sensor error rather than a malfunction of your hot water heater.
Check the temperature sensor connection. The sensor may be moved out of place or disconnected. Remove it from the plug and plug it back in to reset the connection. If the error appears again, replace the sensor on the washer.
Nov 20, 2012 | Whirlpool Duet Sport HT WFW8400TE Washer
What is error code f 21 on a whirlpool duet sport wfw8300 3.8 cubic washer?
This means that the drain pump is clogged. Tip the machine back and remove the three screws on the bottom panel. The pump has a filter inside. Pull the filter out and clean it, it will fix the issue for sure!
Apr 13, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
The computer panel says f 20, what does that mean?? And when I turn the washer on, I noticed that no water is going into the machine?? why??
The error "F20" means : Water Inlet Problem - no water or insufficient
water supply.
Several possibilities.
Have a look at this forum - several tests must be perform to clearly identify where does problem comes from :.
http://www.applianceblog.com/mainforums/whirlpool-kitchenaid/10201-fixed-whirlpool-duet-sport-f-20-error-code.html
Good luck
Jan 24, 2011 | Whirlpool WFW9400S
I keep getting an F 11 error code on my duet washer. What does it mean exactly?
Motor control Unit error Most likely means the MCU is bad but a tech can check.
Nov 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer displaying a fault code.
check your manual. it will tell you what it means and what to do
Apr 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have a duet sport whirlpool washing machine and a F then a number keeps coming up and it wont complete the cycle
What number is it. That is called a fault code and is telling you what is wrong. The numbers may be in your owners manual.
Mar 08, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
257 people viewed this question
Dan Webster
Dan Webster
Sal De
