Question about Maytag (MSD2351KES) Side by Side Refrigerator
The water filter assembly has these two spring-loaded (?) teeth which the filter presses in for the water to come into the filter. The tips of these teeth broke such that the filter cannot depress them and thus: no filtered water. I put a rubber gasket on top of the teeth to apply a little more pressure when filter screwed in for water to work but there has to be a better way. I'd rather just turn the water on/off via the valve in the wall behind the water and never have to deal with those teeth again. Does anyone know how to remove those teeth or fix the water filter assembly?
  • Maytag Master
  • 3,196 Answers
Don't be angry... Pastic parts are everywhere...
Nice part is... they are not terribly expensive
(unless they are from a LUXURY Vehicle)
Obviously these water head can be DAMAGED... because they CERTAINLY sell them... appliancepartspros (one of many)
(about $50 USD, see below)...
Check out the parts and videos on the same page...
I believe there is a "filter" bypass plug... ($5)
but HEY...
No FEDERAL regulations on that one... (yet).
Good lock & happy hunting...
appliancepartspros
http://www.appliancepartspros.com/repair-help/maytag-refrigerator-msd2351kes-repair/msd2351kes-not-dispensing-water.html
Other .com... partsselect, searsparstdirect or repairclinic
Posted on Apr 18, 2017
docjohn174
  • 943 Answers
SOURCE: no water from door outlet
Hi. Thanks For The Question. I Would Check The Water Valve. Disconnect The Water Line From The Valve ,Leaving The Water On. Now Push The Water Button. If Water Flows You Have A Blockage. If Water Does Not Flow. Replace The Valve .Thanks The Appliance doc
Posted on Oct 03, 2008
daddy1264
  • 76 Answers
SOURCE: replaced water filter now icemaker not working
check to see if the direction of the water flow is correct on the filter
Posted on Dec 31, 2008
Sea Breeze
  • 4655 Answers
SOURCE: CHANGED FILTER, HUGE INCREASE IN WATER DISPENSER PRESSURE
No it will be fine. Just think about all that small particulate stuff the filter caught and filtered out of your drinking water. The pressure will drop as this filter begins to collect particles from your water and be back to about the same in a few months. Sea Breeze
Posted on Jun 23, 2009
aasc
  • 1606 Answers
SOURCE: I have Maytag MTF1954ARA with ice maker which
Pour about 3/4 cup of water into the icemaker . If it dumps the icecubes but doesn't refill with water , then replace the water inlet valve . If it doesn't dump the cubes , replace the icemaker . Make sure the coils are clean down by the compressor also .
Posted on Aug 02, 2009
erpaalai
  • 999 Answers
SOURCE: Maytag Model MSD2651HEW - Changed Filter and
Was the pressure ok before you changed the filter? The water valve itself could be partially plugged or the supply line may be filling with minerals. Usually happens in the piercing tap used to attacc to the house line. Difficult to say for sure without seeing the way it is installed. If it was just the drinking water I would suggest the reservoir being froze up but since it affects both look at my initial comments...
Eric
Posted on Oct 12, 2009
When i pull the brake it doesent stay
When you pull the brake lever up it does not lock but pops back down? If so undo the two screws that hold the lever assembly together. You'll see an inner button with a spring and the lever. The inner button has ratchet teeth that need to lock into matching teeth on the inside of the black lever holder. If these are worn you can reshape them with a small file or a rotary tool like a Demell. The lever assembly should be kept well lubricated with silicon spray to avoid ware on the teeth. It is the teeth shape that does the locking and not lubricating them wares them down.
Aug 14, 2011 | Bugaboo Cameleon Jogger
My PHT150 SharpShooter is jammed and won't spring back. The staple plunger is sticking out and won't retract.
Sometimes a bit of the staple material will be sheared off and jam the hammer in its guide, keeping the tool compressed. On the business end of a PHT150 there is a notch in the hammer housing and a slot on the staple carrier. Most times a standard screwdriver can be used by sticking the tip straight into the slot and using the notch to leverage the the two apart. If not, you can clamp the hammer housing in a vise and, using the screwdriver in the carrier slot, tap away from the hammer housing to release the jamb.
May 31, 2011 | Stanley Tools Hammer Staple/Tacker -...
GE smartwater filter (model GXRLQR) stopped working...help!
These replacement filters (GXRLQR) are FLAWED straight out of the factory. The problem is in the 2 little "teeth" nubs that stick up near the center circle of the filter. When the filter is twisted and inserted, these teeth push up on a tiny black spring loaded valve in the body of the filter, alowing water to pass through up and out the spigot. The flaw is that the "nubs" are too short and do not push open the spring valve far enough, reducing flow to a semi-trickle, even with a brand new filter. GE seems to think this is not a problem.
Solution=stick a $0.25 garden hose rubber washer in the top of the filter and screw it in. You may have to try a few times to get it to work and seat properly. When it works, you'll immediately get a nice super flow of water. Better than upgrading to a $200 filter system recommended by GE...
May 06, 2010 | General Electric GE SmartWater Household...
Have LG 1812 front load washer, it is making noise when water tries to drain out, we were able to drain the hose but unable to remove the drain pump filter-just spins
Unscrew the drain pump filter counterclockwise to remove it from the pump assembly. If it cannot be removed, you need to replace the pump casing (part #3108ER1001B) and the pump filter (part #383EER2001A).
Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Remove the two screws at the rear of the top panel attaching it to the cabinet. Slide the panel rearward then lift it off the washer.
Disconnect the control panel wiring harness from the main board assembly. Pull the dispenser drawer out until it stops then press the locking tab and pull the drawer out completely.
Remove the two screws from the drawer opening then lift the left side of the console and pull it off the cabinet.
Remove the three screws from the upper part of the front panel and the screw from the filter cover.
Insert a putty knife blade or similar flat tool in both sides of the filter cover then pull it out of the cabinet. Remove the screw from the lower side of the front panel.
Open the washer door and remove the wire and spring holding the door gasket to the outer lip of the door opening. Stretch the spring with a pair of needle-nose pliers to clear the wire off the lip of the door opening then remove the wire and spring assembly.
Peel off the door gasket into the drum then tilt the front panel and disconnect the door switch wiring harness from the door switch terminals. Lift the front panel and remove it from the cabinet.
Compress the spring clamps holding the pump inlet and outlet hoses then move the clamps away from the pump casing.
Remove the two screws securing the pump to the base of the washer. Press down the tab at the back of the pump assembly and push the assembly into the washer then lift the pump assembly up and out of the washer. Remove the hoses from the pump assembly.
Unscrew the pump from the casing and inspect the impeller for any damage. Rotate the impeller to check whether there's restriction. Replace the pump (part #4681EA2001D) if the impeller is broken or does not rotate freely.
Install the pump assembly and reassemble the washer by reversing the given disassembly steps.
Mar 20, 2010 | LG WM1812C Front Load Washer
Water pooling in washer in between loads
The problem is caused by a leaking water inlet valve and the only way to solve it is by replacing the water inlet valve assembly. It is an easy "do-it-yourself" fix that only requires a minimum effort.
Water Inlet Valve Replacement Procedure
  1. Remove the three screws at the back of the machine holding the top cover.
  2. Slide the top cover to the back and lift it from the washer.
  3. Put a bucket or pan under the inlet valves.
  4. Remove the fill hoses from the machine and drain the water into the bucket or pan to avoid flooding your floor.
  5. Remove the screws holding the water inlet valve assembly to the back of the machine.
  6. Use a pair of pliers to press the spring clamp holding the inlet hose to the inlet valve assembly and move the spring clamp away.
  7. Install the new water inlet valve assembly and all other parts disassembled in reverse order of the procedure above.
  8. Make sure to clean the fill hose filters, if there's any, before attaching it to the water inlet valve assembly.
Jan 20, 2010 | Kenmore Elite 45986 Front Load Washer
Ibm 6400
This is a easy problem... Have any question call 972-907-9771 x311
51e9bbd.jpg ATTENTION Hammer springs and hammer tips are fragile. Do not touch the hammer springs or tips. Handle hammer springs by the
thick mounting base only. Apply pressure only to the mounting base.
NOTE: Replace a hammer spring assembly only if there is visible damage or broken parts can be seen in the assembly.
5. Remove the mounting screws from the old hammer spring assembly. (See Figure 18, page 367.)
6. Handling the hammer spring assembly by the mounting base only, gently pry the old hammer spring assembly off its
mounting pins. (See Figure 18, page 367.)
7. Inspect the hammer bank and the old hammer spring assembly:
a. If there is ink on the hammer bank mounting surface, the hammer spring assembly mounting surface, or the hammer
spring neck or tines, reinstall the old hammer spring assembly and replace the shuttle frame assembly (page 405).
b. If the old hammer spring assembly and the hammer bank are free of ink, install the new hammer spring assembly
Installation
1. Using a clean dry cloth, wipe the hammer spring mounting surface on the hammer bank. Make sure the cloth does not
leave lint on the hammer bank.
NOTE: Replace a hammer spring assembly only if there is visible damage or you see broken parts in the assembly.
2. Handling it by the mounting base only, remove the new hammer spring assembly and mounting screws from the box.
3. Handling the hammer spring assembly by the mounting base only, carefully position it on the hammer bank mounting pins.
then gently press the mounting base down against the alignment pins. (See Figure 19, page 369.)
4. Continue pressing down on the mounting base of the the new hammer spring assembly as you install the mounting screws
from the replacement kit. Using a Torx T-10 bit adapter, torque each screw to 14 inch-pounds (1.58 N•m). Tighten the
center screw(s) first. (See Figure 19, page 369.)
NOTE: Use the 1-30 inch-pound Torque Screwdriver, IBM part number 16F1661.
5. Install the hammer bank cover assembly (page 354).
6. Install the shuttle frame assembly (page 405).
7. Install the ribbon and load paper.
ATTENTION Do not attempt to adjust or “tweak” hammer springs.
8. Run an operator print test and check print quality (page 223):
a. If print quality is acceptable, return the printer to normal operation (page 339).
b. If print quality is still degraded, replace the shuttle frame assembly (page 405).
Sep 10, 2009 | IBM 6400 Matrix Printer
Hand safety control on gmc grass cutter
A hypodermic needle assembly configured such that the movement of a needle shield into position to block the needle tip occurs as a direct consequence of a longitudinal force applied by insertion of a syringe plunger is provided. The hypodermic needle assembly according to the present invention includes a needle, a needle hub, and a safety spring clip assembly, the safety spring clip assembly being configured to automatically launch from the needle hub and slide along the needle to shield the needle tip, thus preventing accidental contact with the needle tip. Additional mechanisms for launching the safety spring clip are also provided, which include using a trigger ring for rotating and launching the safety spring clip.
Jun 21, 2009 | Garden
The back wheel came off and i went to put it back on and the other wheel that connects to the mechinism/gear height ajustment that goes up/down with a spring in it came off as well. i have been looking for...
You do not need schematics, it is fairly easy. Clean and lubricate the teeth on the inside of the front wheel shaft assembly. Insert the spring into small pedal and place the pedal designated opening on the Kirby front fan casing with teeth facing out. Then take the wheel shaft assembly and put it over those teeth and onto the fan casing. Use two clamps and 2 screws to attach the shaft to the fan case. Need any parts - go HERE.
Good Luck,
Rocky
Apr 05, 2009 | Kirby G6 Bagged Upright Vacuum
Emergency brake pedal will not stay down when i press it.
The parking brake actuator (the mechanism you press with your foot) works like a ratchet wrench. The pedal has a cresent shaped plate with teeth on it. It pivots on a mounting plate. There is a pawl with a small spring also on the backing plate. This pawl engages the teeth on the pedal assembly to hold the brake engaged (against the large return spring).
Stick your head under the dash and look carefully at the parking brake actuator mechanism. See why the pawl is not engaging the teeth on the pedal assembly. Most likely causes are that the release mechanism is jammed "on" or that the light spring which attaches to the pawl is missing (usually from being kicked by some one with large feet) View this mechanism on another GM vehicle with the same style parking brake if you suspect that parts are missing.
Charlie
Dec 07, 2008 | 2002 Chevrolet Blazer
Kenmore 655 ultra wash built in dishwasher
Possible problem is that the chopper/cutter filter is plugged. This prevents water circulation and therefor no water is available for cleaning.
Solution:
Remove the dish baskets.
Remove the bottom cleaning arm - Rotate the centre post and the arm can then be removed.
Remove the conduit that feeds the upper arm(s) - Remove screws, one at the back and one at the top. Rotate the whole assembly 45 deg right and lift off of the centre post.
Remove 4 screws in the plastic assembly and lift it off of the centre.
Remove 1 screw at left front (Under assembly just removed). Lift off the plastic cap which covers the cutter/chopper. Remove the chopper. It is on a spring loaded pin. Pull the cutter foreword while lifting the filter disc straight up. Thoroughly clean the filter disc - a knife will be req'd to scrape in clean.
Reassemble in reverse to the disassembly steps.
May 05, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Maytag (MSD2351KES) Side by Side Refrigerator Logo
53 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
