Door open sign on panel when it is shut cannot get it to switch on
My door/tailgate open warning sign keeps flashing and coming on intermitently - suggesting a door is open, but every door is shut?
bad earth or faulty open close switch in one of the doors
start at the tail gate and work forward
Apr 30, 2016 | Honda CRZ Cars & Trucks
Interior lights flicker on and off with warning that doors are open sign on dashboard comes on at same time
Open each door (one at a time) with the car running and parked.
Look for the small contact switch that tells the car the door is open/shut.
See image for location.
Press that switch in firmly and watch the dash to see if the light comes on while you are pressing.
This will tell you which one of the switches is bad.
Mar 18, 2014 | Suzuki Grand Vitara Cars & Trucks
Sanyo DW-MS600F error message saying door is still open
Sounds like the door interlock switch electrical connector is failing to make a connection. You can open the panel and inspect the lock to confirm. Clean as needed (Please remove power from the unit at the circuit breaker panel before opening the door panel).
Jim
Mar 10, 2014 | Dishwashers
My kenmore elite 106.59966803 beeps every two minutes. Doors are shut and the unit seems to be working fine. Any suggestions?
if the refrigerator is beeping -- then this is a sign that the door switch is not working properly,loose or broken.
to stop the beeping --- press and hold the "lock/alarm" button on the control panel until the indicator light turns off. ( this turns off the 'doors open' alarm ) --- now if you get the door switch fixed and you want to turn the 'door open' alarm back on, then press and hold the " lock/alarm " button again until the indicator light come back on.
c...
Feb 15, 2011 | Kenmore Refrigerators
I have a Kenmore 500 that shuts off if the load touches the door from the inside or wont start unless I press the door in again after its shut. I'm assuming there is a safety switch the door touches to let...
sounds like the door catch is loose,this is what holds the door shut,when the clothes are spinning they hit the door opening it enough to reset the door switch,there's a metal or plastic tab that goes into the catch,easy to install and part is cheap money
Oct 13, 2010 | Kenmore 500 6952 Dryer
The door on my Bosch washing machine 1605 is stuck on shut
Hiya,
the door not opening is normally a sign that there is still water inside if you can try a spin cycle or if you have a drain option try using that & if it was the water then the switch will trip & you should be able to open the door again.
Hope this helps
Apr 21, 2010 | Washing Machines
Interior lights wont go off when you shut the door have to disconnect the battery
There is a switch/button in each door frame that pops up when the door is open and gets depressed when the door is shut. One of those switches may be malfunctioning. Go around the doors and check each one of those switches for signs of damage. If you cannot see anything superficially, you will need to remove each switch to inspect it thoroughly. Start with the driver door as its get the most use and is the most likely to fail..
Mar 14, 2010 | 2003 Mercury Mountaineer
Dome light stays on and door open sign is on
this problem is caused by the courtesy light switch being defective in one of the 4 doors, the switch is attached to the door latch inside the door so access is not easy as the door panels must be removed, the dealer has a scan tool that can quickly ID electronically which switch is causing the problem.
Dec 18, 2009 | 1997 Mercury Sable
My electric dryer runs for a few minutes then shuts off. You can restart it almose immediately.
Probably the door switch. Is it closing tightly? Open the door and look at the switch, is it loose or any signs of problems. Try putting some tape on the edge of the door where it makes contact with the switch and see if it makes better contact.
Jul 03, 2009 | Whirlpool LER4634J Electric Dryer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
