Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
My huskee lawn tractor will not turn over! The battery is fully charged, it is a 25hp with a 50inch cut, i replaced the selnoid last year!
The arm that engages the cutting blade tends to wiggle. Make sure it is pulled toward you (unengaged) before trying to start.
Posted on May 11, 2010
Replaces battery and spark plugs in my huskee lawn tractor it cranks over but won't fire has full tank of gas and battery is charged what could be the problem?
No spark? Check out ignition coil. Make sure the fuel is turned on if you have an on line hose switch for that.
Mar 28, 2017 | HP Garden
Im having trouble with the charging system
to test it , start engine then turn on head lights to tractor , vary engine speed with throttle , do lights dramitiacly dim/brighten if so replace battery , your only runing off the alternator , it's also a good time to ck/replace your battery wires and connectors , if that batterys been in there for more than 5 years then yeah the connectors are gonna be hard to remove and most likey will require replacement
Sep 13, 2014 | Kohler 25HP Replacement Engine SV730-3001
Cub cadet mower turns off when I slow down
one more possible check. Make sure the battery is fully charged. Then try it. You might put jumpers from the car on to do a check without doing the battery check. If it runs with the car battery, most likely in battery, or alternator.
Jun 20, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I have a 3 year old ys4500, wont start
Have you tried bypassing the cut off switch, by joining the wires together
Sep 20, 2012 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
My mower discharge when the blades are ingauge
The wires connected to your PTO are the key to your problem. The electric pto is designed to run off the engine charging system when it is engaged and will run your battery down if it isn't. The fact your battery will charge and hold a charge tells me it is probably ok. You will need a wiring diagram to figure this out. You might check outdoordistributors.com. They have pdf files that you can view online for most lawn tractors. Good luck Tim
May 31, 2011 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
When I turn key on I get nothing. No lights , no engine hours, no nothing.
If the battery is fully charged you most likely have a blown main fuse. If you can't find it send me the model of the mower and I will try to assist you. Regards Phil.
Apr 26, 2011 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
I have a Husqvarna 21 HP Lawn Tractor and I went out to start it and the battery was totally dead, so I jump started it. It started but died out a couple times. So I got it going again and drove it up the...
The electric clutch needs full power in the battery to stay engaged. I would recommend you check your charging system before replacing the battery. Put a digital volt meter across the + and - terminals of the battery and while running at about 1/2 throttle you should be over 13 volts DC. Probably around 13.5 or so. If not you have a charging problem. Lawn mower batteries I have seen seem to last only 2-3 years. I would also recommend a trickle charger for extended periods of non use. Don't forget the Stabil also.
Hope this helps.
Jun 27, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
50'' Huskee lawn tractor only turns in one direction
the brand huskee is now manufactured by MTD
Parts are available from tractor supply company at www.tractorsupply.com
there are pages of not very encouraging reviews about the huskee mower or about the tractor supply company but you can contact them to see what you can get
as for the problem , if it is a zero turn unit it may be a clutch arrangement needs adjustment
If you do not get any help from that company, you could ring around the mower repairs shops to get an idea as what could be wrong as the principle of operation will be the same .
also there are sites that have pdf versions of the workshop manual for huskee
May 20, 2017 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
959 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
