Old akai telly. no remote. no manual. no patience. how do i tune the channels in?
5 Suggested Answers
  • 76 Answers
SOURCE: akai ct29x4av television
Hi you sound as if you know what you are doing,so looks like service manual needed,try Donberg electronics at www.Donberg Electronics .ie Good luck
Posted on May 12, 2007
pishta68
  • 579 Answers
SOURCE: toshiba 2141tb tuning
there is a menu that has autoprogram in it, use that and itll scan all channels and memorize the viewable ones. Sometimes it is a stand alone button behind a door or it is in the setup menu. Make sure your antenna is plugged in. If you have cable, the only channel that may be stored is 3.
Posted on Mar 03, 2008
  • 163 Answers
SOURCE: how do i tune tv channels?
I am afraid thatyou need the original remote to access tuning universal remotes will not give you this option. An original remote will probably be very expensive check with your local TV dealer.
SUPER8
Posted on Jan 05, 2009
  • 89 Answers
SOURCE: Akai CT21W30AT Manual Tuning
It sets the channel according to the frequency they are on, If you don't have any channels below those numbers and are connected to Cable TV, you have a bad tuner
Posted on Mar 13, 2009
Tuning bush tv
Because you haven't programmed the Sky remote correctly.
Put the TV and Sky box on, and put the telly on the Sky channel. Press Interactive on the Sky remote. Choose "Program my remote" from the menu list. Follow the onscreen guide. The pages take a bit to update so be pationent
Sep 07, 2014 | Televison & Video
Hi, i have a ps one i want to connect to my tv via the aerial. iv plugged it in and checked the av channels but cant find it, is there anything i need to do?
Hi, right now as your plugging it in via the aerial socket then this means you wont be using any of the input channels or source channels such as av ok.
now what you can try is when its plugged in and switched on go through the channels on the telly using the telly remote try channels you dont use such as 0 6 7 8 9 10 if after trying these you still have no picture then you need to put the telly on a channel you dont use say 0 then make sure ps is switched on with a game in then on telly remote choose menu or setup then you need to use the tv setup function to search the frequency as if you are tuning a channel in so do this till you see the game then store it onto that channel, now when ever you want to play the ps you just plug it in and put it on the channel you tuned in.
or an easier option would be to go to the well known auction site and buy a ps1 scart lead then when you plug this into your telly you just choose av1 or av2 and then you can play it without tuning the channel in so this owuld be the easiest way
let me know if you have any problems
Feb 08, 2010 | Video Game Consoles & Games
Cant seem to fine the sega mega drive2 on my tv
hi, if your plugging the sega mega drive into the airial socket ie same fitting as the arial then what you need to do is make sure its plugged into the arial socket properly now you need to switch it on with a game in wait for minute or so for the game to load up.
Then you need to put your telly onto a channel you dont use such as 7.
Then you need to use the telly remote and enter the setup mode once in this mode you need to use the setting that lets you scan for the telly channels.
Now depending on your telly this will either be an auto tune or manual or both if you can choose then pick the manual type.
Once this is selected you then need to choose witch way your going to tune ie up or down.
Make sure on the menu your tuning the channel you want ie 7 or what ever you want to use.
Now it dont matter witch way you start scanning so start the scanning then just keep going the one way then eventually you will get the screen tuned into the mega drive you then need to save this setting into the channel your using.
Right now you have done all that if by any chance on the lead from the megadrive to the tell it has a switch ok then try it with it in the on possition then scan all the way if after ages you get no picture then press the little switch and scan again.
But depending how old it is you may not have a switch dont worry if not as its less hassle to tune in as you havent got 2 choices.
So their is the instructions if it is an arial socket type connector.
If however it is the three color leads then plug these into the right colors on the telly then make sure you have a game in switch it on wait 1 min or so then get the telly control and find the source or maybe av button depending on your control is will be either of those 2 if it dont have them then look for a small picture on the control it will look like a square box with an arrow running from the right to left this is the av/source button.
Once you have found this button you may need to press it 3 or 4 times untill your on the right input ok then you should have it on(only these instructions if its color leads if not follow first instructions ok)
I know its a lot of info but youll get their in the end (that is if the lead from mega to telly isnt damaged) if after doing what i say you still get no picture then the chances are the lead is damaged and needs replacing but from what i can remember (back in the day) it was just a normal arial lead anyway so you should have one of these lying around.
Let me know how you get on or if you need further assistance ok
Nov 12, 2009 | Computers & Internet
SKY DIGIBOX 2nd RF frequency
your in luck, I work for sky as an Engineer.
Firstly go to the main telly where your sky box is.
Using the sky remote press the following buttons.
SERVICES
0,1,SELECT
go to RF
In this menu I would set the RF channel to 38 and turn the power ON and then down to save.
now leave it on the blue menu screen (sky menu)
go to the other room where you link from your sky box is connected to.
press the tv button on that remote and then select channel 6 on the remote
Then go into the menu for the tv and then to setup. go to MANUAL TUNE/SEARCH with most new tv you can scroll down to were it says C _ _ you can then input your channel number as 38 the same as you setup on your sky box.
Dont forget to save the settings and that should be you. You should be able to see the sky menu on the telly with the link on. (that is why I asked you to leave the sky menu on that way you know you havent just tuned it into your normal terrestrial channels.
The reason I told you to turn the power onto the link was so that you can purchase a Magic eye. This will allow you to turn your sky box over from the 2nd room without having to keeping going to the main tv to change over.
here is a link to a random site with a picture of a magic eye on. you can purchase these from many places or even Ebay. here is the link anyway.
http://www.aerialshack.com/commtel-digital-link-magic-p-815.html
hope this sort you out. If so please leave a thumbs up
Cheers Little Dish Fitter
Sep 26, 2009 | Televison & Video
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Early 2000's AKAI ATV 140 (Tv / Video Combo)
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Mar 31, 2009 | Akai LCT2701AD Television
Mar 13, 2009 | Akai CFT2490 24" TV
How do i tune tv channels?
SUPER8
Jan 05, 2009 | Televison & Video
I have a sega mega drive with all the relevant pieces but i cant tune it into the tv
Hi. is the lead from mega drive a rf socket that goes into the arial socket on the telly and does the lead have a switch on it?
Plug the rf lead from md into areial socket on telly
then put telly on channel you dont use i used 0 or 9 but use any.
then turn mega drive on
then press setup on tv
enter channel settup then you need to go through the procedure of tuning channel in its best doing it manualy its like when you tune a channel in make sure md is on then keep changing the frequency one way or the other could take few minutes then when you get it on the telly save this setting on the channel you want to use ok.
If it dont work then the chances are the lead is damaged this is often the case with these consoles as the are not made that well so if no good then replace if necesarry.
If your unsure on tuning your telly then give me make and model then i can talk you through the process ok
Apr 22, 2008 | Video Game Consoles & Games
Akai ct29x4av television
May 11, 2007 | Akai CTS2550 25" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
