Recently purchased a targus dvd-rom external usb2.0 drive. it is not compatible with my windows 7 starter. please advise as to solution
  • joedelancey May 09, 2010
    could not use your solution;which involved items not found on my acer netbook-windows 7 starter. found solution from an online blogger who had the same problem. i would have thought that just purchasing the targus dvd-rom initial help would have been at no cost especially after advertising that the targus worked with most netbooks and laptops.
  • 4,924 Answers
Http://www.targus.com/hk/drivers_manuals.asp?SKU=PADVD010U
If this is the product that you are talking about ..it is written clear that no additional software and drivers are needed..This means that it is a plug and play device ..or it has the drivers for it already built in the windows operation systems..so ...
My advice is to insert the usb and power it up..after that ..go to control panel .and start the add new hardware wizard ..and let it install the device automatically ..To check if it is installed proper...go to the device manager ..(right click on my computer and properties..hardware .......or ..from the start ..or control panel .what ever suit s you ..The idea is to get to the device manager ..and see the new hard ware ..if it appears in yellow ..this means that it is not installed proper.. and you have to right click on it ..and than update driver ...first time let it search automatically ...even on the net ...if it do not gets anything ...than make the operation again ..but choose to not search auto ...and than to choose from a list ...It will display the drivers available in the system for the dvd roms..and you will have to choose one from the manufacturer..or try a few ones from that list to see if it suits it ..
I will wait for you to explain better what kinda computer you have ..why the choice for external drive...and what exactly you tried already ..(I guess it is a small notebook or a tablet pc ...but still will have to work the same if it has a windows 7 based OS ..Probably it just didnt start the found new hardware wizard automatically ..and cause it has no driver assigned its unusable for the moment ..
good luck and Im waiting to see whats going on ..
Posted on May 10, 2010
  • 4,281 Answers
First make sure usb cable connected to dvd rom is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If your dvd-rom still not recognized then you need to repair your harddrive.Try your dvd-rom in different computer if it is not recognized on another computer then your dvd-rom has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 09, 2010
Cdvd rom dont work on emachine, will a usb 2.0 external dvd rom drive work
If it is USB CD_Drive you can plug it in a USB port of the computer. You may have to install drivers, but usually Windows Update can download them from the Internet.
Apr 07, 2013 | E-Machines emachines (emachinees) CD-ROM...
My compaq presario f768wm isnt recognizing my cd/dvd rom. my camera quit working and also it says it can't find my audio output device.
For that problem, Try first replace that internal DVD-rom drive other good internal DVD-rom drive. if not Also Detected or recognize.
Try this second solution. insert external USB type DVD-ROM. if not recognize also, Your operating system Have internal software device data corrupted. You need to reinstall operating System like windows xp, windows 7 (OS) etc.. to fix data Corrupted of operating system device for hardware software.
Please see sample external DVD-rom USB type.
Just let me know if not yet working your Compaq Presario 700 series DVD-rom Drive.
Thanks for using Fixya.
Aug 19, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Hi, I have Windows 7 on my MSi L1350 laptop. Whenever I try to play a DVD on my RockSoul DVD Multi Recorder (RW) on Windows Media Player, I get the following error message: "Windows Media Player...
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or
http://majorgeeks.com/Realtek_High_Definition_Audio_for_VistaWin_7_d5513.html
hope this helps
Apr 04, 2011 | Toshiba ROCKSOUL ED100 USB slim external...
Targus CD/DVD does not show in directory
try to use another usb cable for your external dvd drive>>>> then if it's not working again try to check the bios setup if the optical drive is enable. if the setting is disable please change it to enable>>> if still not work back on where did you bought it>>> maybe it is defective...
Dec 14, 2009 | Targus USB 2.0 DVD/CD-ROM SLIM EXTERNA DVD...
I purchased a CD-Rom advertised on Amazon as compatible with Asuseeepc and I wanted it for use with the DVD support disc. It works fine with cds but does not recognize dvds when inserted. I have been
A CD-Rom will only recognize CD's. It must be a DVD-ROM to recognize DVD's. DVD-ROM will recognize CD's ,but not the other way around. No drivers needed for thes, they are plug and play.
Char S.
May 20, 2009 | Teac PortaCD 224PE External 24x CD-ROM...
Computers & Internet Logo
David Payne
David Payne
