Question about Frigidaire ATF6000ES Front Load Washer
My Frigidaire frontloader is not spinning until dry. The drum appears to be banging against the interior, making a loud noise.
Were the drum support brackets removed after purchase? you may need to open the front access panel and remove two brackets that support the drum during shipping. also at the rear are support screws that need to be removed
Posted on May 09, 2010
Frigidaire washer makes a very loud humming noise on spin cycle.
Good Morning Larry Looney, thank you for your post!
I understand that your Frigidaire frontload washer is making a humming noise while in spin cycle. This could be a potential problem with your motor or drum bearing. In order to find the proper cause of the humming noise I would highly recommend having a professional technician come out to your home for diagnosis and repair. This will help to avoid any unnecessary part purchases as well as any future issues. -Matt
Nov 14, 2014 | Frigidaire ATF6000ES Front Load Washer
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
Machine makes loud banging noise during the spin cycle
The load is out of balance. Open the lid and redistribute the contents. When it's empty, grab the basket and give it a slight push sideways. It should move a little but, not free swing. If it doesn't have much resistance, the "snubber" has dried out and should be replaced. It is simply a piece of rubber in a metal bracket, that rests on the tub. When the basket spins,the snubber keeps it from jumping around.
Aug 31, 2009 | Frigidaire FWT449
Washer frigidaire GLTF1670A
you need a new drum, wich is pretty much like buying a new machine
Jun 18, 2009 | Washing Machines
Loud banging noise during final high speed spin
I have the HE3T which is 6 yo. Last week it started making a loud banging noise in the spin cycle. I had a repairman come out. He said it is the drum bearings. He said that it is a problem with these machines and to call Sears. He said that the drum and bearing is one assembly and that Sears should cover it.
I called today and Sears todl me that I have to pay for a Sears technician to come out a determine if it is indeed the problem. If so, it will be covered under the lifetime warranty on the drum. I have to pay for the service call $75.00 and if it is the problem, I will be reimbursed. Cross my fingers!
May 21, 2009 | Frigidaire ATF6000ES Front Load Washer
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Dec 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
129 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
