Question about Car Audio & Video
I have a boss mosfet amp- 360 car amp but the fuse is missing and need to know the rating
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
I just got one and its with a 30A one which by the way makes sence as the formula says: 360w:12v=30a (P:V=I)
Posted on Apr 11, 2011
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 77 Answers
Should be 20a
Posted on May 09, 2010
I have a boss s120.5a 12" sub with 5 channel 3000
Check the power pack and the fuse to make sure the are working but if the are not okay then take the car audio amplifier to audio mechanic.
Jan 22, 2011 | Boss gt580 - GT580 1000W 2 Channel MOSFET...
Bought a car and this amp was in it(Pyramid Crystal PB781X 2ch MOSFET). it is missing the fuse. what fuse does it require?
25 to 30 amp fuses are the most commonly used fuses in any amp and since yours is a 1000w amp, I would use the 30a.
Sep 05, 2010 | Pyramid 2CH 1000W CRYSTAL AMP Car Audio...
Boss c705 chaos "manual" try-en to find
What info do you need? All amps are exactly the same and the manual only differs for specific specs and db ratings!!
Nov 03, 2009 | Boss C700 Car Audio Amplifier
Why would i spend a 100 to 120 dollars on a car amp?
any amp will work with any speaker, you just need to make sure it is a mono amp if you are running 1 speaker and a stereo amp wither 2 or 4 channel if you are running 2 or 4 speakers, the ohm rating on the amp should match the speakers also, on the back of the speaker it has the ohm rating, most will be 8 ohm, but you still find some 4 ohm, depending on the speaker if it has a lot of throw (the in and out movement) you may want a higher wattage amp so you get clean sound, it is up to you.... if you are installing lower price amps to you may hear engine wine or noise while car is running so a grounde loop isolator installed on the system will remedy that... also with the amp the directions will tell you the ohm rating of the wire to use, follow that.... and keep the ground short and clean where ever you put it.. try not to go directly off the battery cause you will get a lot of noise... hope this helps..
Jun 23, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Jun 22, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
On power up.......protect light comes on
what are the resistors connected to? mosfets?if so you need to identify which pin gate or source,these amps have dual so the other side would be the same.
May 04, 2007 | Boss IQ 1080.2 Car Audio Amplifier
Channels Not Playing
i had afriend who is atechnician. his boss amplifier stopped working on one channel,so what he did is openened the amp,tested the mosfet transistors and it showed signs of failure.then he went shopping for same type of mosfet transistors and with no luck in buying the right type, he put the amp away for acouple of weeks. then one day he hooked it up and strangely it worked again. he told me that while it was hooked up itwent into protection mode and for some reason it worked later. so i would not open it because of static discharge i would disconnect the amp for maybe acouple of weeks then hook it back up.... its worth a try & good luck
Nov 10, 2006 | Boss C350 Car Audio Amplifier
Car Audio & Video Logo
165 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
