Viewing screen has moved to the left?
Ive had my panasonic th-46pz82b for a few years now and this morning one of my boys said the tv went off and beeped, when i looked at it the stanby light was flashing red so i turned it off and back on again, it came on but the whole picture has moved to left leaving a black column on the right hand side of the screen, now i cant seem to move the picture back so it fills the whole screen again, any help in how to put it right would b appreciated!
kind regards dom
trintek
  • 111 Answers
SOURCE: panasonic tv TC-26LX60 PICTURE PROBLEM
if this is under warranty still, i would take it to a service center or rma it to panasonic.. if it is not under warranty, you can try the following.
1) try a different video source and verify the problem is happening on all video sources and modes.
2.a) if the problem is not happening in all modes, remove and replace the cable that is causing the issue. if this doesn't remedy the problem, the controller for that particular input is going out
2.b) if the problem is happening in all modes, you can open the case and carefully disconnect and clean (de-oxit or rid-ox) the hirose style connectors on the back of the display panel.
3) disconnect and clean all ribbon cables around the display panel
this sounds like either the connectors are not performing adequately or are loose, the top ribbon is acting up for some reason, or the graphic controller is going out.
Posted on Nov 15, 2007
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Posted on Nov 03, 2008
SOURCE: TH-42PX25 TV won't turn on
most cases the power supply board goes. plasma displays run hot, so that causes the supply to go
Posted on Nov 09, 2008
  • 150 Answers
SOURCE: My Tv Panasonic TH-42PZ80BA switched into standby
Yep , I cannot remember offhand but one the the internal boards has failed. The flashing code is telling us which one , will have to check SM to tell you which board but it should be under warranty , get it repaired for free.
Posted on May 05, 2009
  • 6 Answers
SOURCE: my plasma tv has a red light flashing on the
You have to bad compacitors on the power board. They will be buldged on the top. Once replace you TV will live again. The parts will cost you about $4
Posted on Mar 04, 2010
Red hues all over the images on screen
The TV is a plasma screen. There are several circuit boards that will go bad over time that affects the picture quality. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get the parts here and replace those boards yourself.
Apr 10, 2017 | Panasonic TH-42PZ700U 42 in. Plasma...
Our Panasonic 50" TH 42PX75U
well it sounds like something fried inside the tv. In my experience, this sounds like your y-sustain board went bad. it could be your video board also. considering todays value of the 50" panasonic plasma, it will be cheaper to replace it, unless you are willing to spend around $300 to get it fix at a shop.
good luck
Jun 17, 2011 | Panasonic TH-42PX75U 42 in. Plasma...
After 14 months of having my TH-p42pz80u, the power went off, and I had a flashing red power light. TV wouldn't come back on, so I unplugged the power cord from the back of the set, and plugged back in....
2 possibilities... First, your lower-left buffer is bad. Second, your panel is bad. First possibility is the most desirable. You should contact Panasonic directly for service information on this TV. They are having some panel problems on a few models... they may have issued a warranty extension for this model. Panasonic likes to have their hands in the repair process anyway. I highly doubt you could just order a part for this model without using an authorized servicer. Best wishes.
Apr 17, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
I have a vertical black line on the left side of my TH-50pz85u.
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Oct 11, 2009 | Panasonic Viera TH-50PZ85U Plasma TV
Panasonic TH-42PX75U won't turn on
Your powerboard is damaged, and need to be replaced.
Sometimes it appear the TV is working again with no problem but it is only a matter of time for the board to get completely damaged.
May 30, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Panasonic Viera Scratches help
The only supplier for parts is the Panasonic service rep and their parts distributors. To change the front panel transparent window is a fairly big job. In most models, the compete screen has to be removed.
You will find that the replacement window is fairly expensive. The labour would also be expensive because of the time involved.
What you should do is get it streight with your children to not touch the screen. Also, if they have allowance, you should cut if back by a fair amount for a long time to compensate for the damage.
Jerry G.
Nov 27, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Green Screen
Turn Tv off by power point unplug even for 30 or 45 minutes then turn back on. that way the tv has time to reset back to normal
Sep 07, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Only right side of screen
If the TV cost to much to repair, would you be willing to sell it for parts? My front glass screen has got a chip in it. Cant see paying 500 just to have a new one installed.
Thanks
Apr 14, 2008 | Panasonic TH-42PX60U Television
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
