Question about Car Audio & Video
Dodge Neon'01 (Base model) streo upgrade enabling re-use oldWires
I would like to install a new audio system in my car without ripping off the factory wiring harness. I would like to know how to get a connector(s) that would slot into the the old 7 pin connectors ( grey and black) and be able to connect the other end to the new audio system. Please advise as I am just learning to do it myself. thanks.
  • 6,674 Answers
If you check at nearest auto parts stores, or car stereo stores, they will usually carry, the plug in adapters that you will need to simply plug in to your factory harness, and then wire to your new stereo. Makes for a nice easy, clean installation.
Posted on May 09, 2010
My 2001 dodge neon cranked without the cam sensor connected. what's wrong with this picture?
Changing the Cam Position Sensor on Dodge Neon ...
? 10:33
https://www.youtube.com/watch?v=ciCPQ0kVAQY
Dec 21, 2012 - Uploaded by VeeTheAmazingGreek
... had to change out the cam position sensor on my 2001 Dodge Neon. ... 1997 Dodge Neon no start, crank sensor problems - Duration: 26:53.
Dodge Neon Questions - It will turn over but has no spark ...
www.cargurus.com > Questions > Dodge > Neon
CarGurusAug 9, 2015 - I did have a neon while ago and image crank sensor was bad ... my 1999dodge neon has no spark it will turn over but not fire i have changed the crank sensorcoil ... I have a 2001 Dodge Neon 2.0 with 140,000 kms on it.
Dodge Neon Questions - 2001 Dodge Neon will turn over ...
CarGurusJan 7, 2013 - I have a 2001 Dodge Neon 2.0 with 140000 kms o... ... went about a month before this recent problem, fixed that with no problem now this. ... firing. you said you replaced the cam sensor, did you do the crank sensor as well? ... My 1996Dodge Neon won't stay running whenever I take my foot off of the gas.
Starting Issues and Trouble Code Due to Defective Cam ...
repairpal.com > Problems > Dodge > Neon
Feb 05, 2016 | 2001 Dodge Neon
2002 dodge neon doe it have disc brakes in the front and disc in the rear?
The base model of the 02 neon has disc front brakes and drum rear brakes.
Oct 10, 2010 | 2002 Dodge Neon
I just bought the xd1222 car radio, but the components in my 01' dodge neon and the radio do not match up. How do i install the radio?
www.dualav.com/support/manuals/xd1222.pdf - Similar
this site is very helpful i just bought a new used vehicle with the same stereo system and i have had no problems since going to this site.
Aug 01, 2010 | Dual Electronics XD1222 Car USB Player
Reverse lights dont workon 01 chryser neon.
problem may at be reverse switch at tansmision shifter
Dec 28, 2009 | Pro-Fit Pro.Fit Dg 91 01 Dodge/Plym/Chry...
How do I install a new car streo in a for escape
go to a car stereo store or auto parts store, adapter harness available for your model vehicle
Dec 25, 2009 | Car Audio & Video
2001 dodge neon radio
Also had no radio but flashing bass/treble indicator lights. As suggested by another post, I disconnected neg. batt. cable and pulled the "interior cluster" fuses, re-set them and then reconnected batt. cable. This fixed the radio.
Apr 04, 2009 | 2001 Dodge Neon
Imobiliser will not turn off.
get a new fob and have it programmed to the vehicle....it will need to be towed to a dealer to program...should be under 200 dollars
Oct 09, 2008 | 2002 Dodge Neon
Dodge radio
If you already checked the fuse, you need to check for power to the back of the radio. If power is present there you will need a new radio. Factory radios are expensive, the best bet is to get an aftermarket radio and install it.
Aug 26, 2008 | 2001 Dodge Neon
Car Audio & Video Logo
53 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
