Question about Uniden BC248CLT Base Scanner
Ive got a Uniden BC248 CLT Base Scanner. In the back of it, there are two holes for input/output of some sort, What is the diference in the am radio antenna vs. the antenna ?
  • 454 Answers
Your scanner has four connections on the back. Looking at the rear, from left to right, are the power jack (10 volts AC, you need an adapter for this), an external speaker jack, the AM antenna connection, and the scanner antenna jack.
The AM antenna jack is for the reception of AM radio station signals. The scanner antenna jack is for police/fire etc, as well as FM signals.
In case you don't have a manual for your radio, it is available for free here:
http://www.uniden.com/pdf/BC248CLTom.pdf
Posted on May 09, 2010
Date and time appears scanner doesn't scan
Hi June,
Has the radio scanner been programmed with frequencies?
If not, that is the answer to your query.
All radio scanners need input to function as they should, no input, FREQUENCIES, no go.
If you have the user manual handy, it will guide you through the steps required to program frequencies into your scanner.
If you don't have the manual, then going to your local Radioshack store would be of benefit to obtain a copy.
You will also need a hard copy of frequency listings for your location.
these can be found by a simple google search.
I hope this has been useful to you.
Cheers,
Peter
Feb 26, 2013 | Uniden BC370CRS Base Scanner
Voice is not clear...sounds muffled
hello depending on what sort of transmissions you are listening to all should be set to NFM ,cb radio will be set at AM ,radio stations WFM so check the mode you are using this could be your problem
Feb 16, 2011 | Uniden BCT8 Base Scanner
My scanner bc350a will not turn on was working is there a fuse somewhere inside of the unit
There's a fuse in line with the DC (vehicle) cord, but none for AC power operation. Check the power supply with a voltmeter to be sure it's outputting power to the scanner (As a alternate, check the unit on vehicle power). If there's no output you can purchase a replacement power supply from Uniden on line of from other sources - such as eBay. If the power supply is outputting power, but the scanner is still not working, your problem could be the power connection at the scanner (internal or external), the power switch, or a myriad of other problems.
Bill B
Jul 04, 2010 | Uniden BC350 Base Scanner
Looking for a manual for a uniden bearcat 30 chanel scanner
Uniden scanner manuals can be found at the following location:
http://www.uniden.com/index/manuals_results.cfm?cat=3
Just click on the model of your scanner and download it.
Hope this helps!
Jan 03, 2010 | Uniden BC248CLT Base Scanner
Want to convert analog police scanner into digital
Some scanners are capable of digital (APCO25). The BC248 however is not. You'll have to buy newer equipment.
Apr 16, 2009 | Uniden BC248CLT Base Scanner
BEARCAT BC 175 XL--Where might I download manual? Thanks
hi . i w given a Uniden Bearcat 175XL 16 channel scanning radio. the OPERATION buttons are: PRI SPEED WX LIMIT SRCH HOLD DELAY LOCKOUT and in orage color: SCAN MANUAL. please help. the only thing i can get to hear is the WEATHER CHANNEL. i cant even hear the squelch. can u help
Mar 21, 2009 | Uniden BC340CRS Base Scanner
Uniden marine radio
Cb radios are usally detuned to meet fcc regulations. The other radios usually are peaked out all the way.
Jan 28, 2009 | Uniden BC248CLT Base Scanner
Uniden BC248CLT Base Scanner Logo
199 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
