Question about LG 32LG30 32 in. LCD HDTV
Black streaks on screen
Started small but getting worse
My minolta ep 4000 copier prints with thick black streaks imprinted on page. what's wrong? is it the corona, the drum, or something else?
Most likely it is the drum cleaning blade. One indicator of the drum cleaning blade going bad is that the black lines will get worse as you run multiple copies. So if you make 10 copies for example, the last copy out will be streaked worse than the first copy out. Drum cleanig blades are about $30 bucks plus whatever your local service guy charges for a svc call.
Good Luck and Thank You for using Fixya.
Jul 21, 2010 | Minolta EP4000/5000 CS/PRO Copier
After a few copies are made, black streaks start showing up on the copies and gets worse with each successive copy
for most copier those black streaks are caused by poor cleaning of the Photo Conductor Drum these can be fix by replacing the cleaning blade. after replacing them clean the Photo Conductor Unit and make some test copies.
Feb 27, 2010 | Office Equipment & Supplies
Our Sony TV started to display something that looked like interference, with sharp horizontal white streaks across the screen, accompanied by loud popping noises. It has nothing to do with the cable,...
According to the symptom the FBT Which is called "Fly Back" is popped, and it needs replacement. Details like Part No. and Description is given below:
145334611 FBT ASSY (NX-6000//J1J4)
Replace the FBT and your tv work fine again.
Nov 18, 2009 | Sony KV-36XBR450 36" TV
I have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Oct 12, 2009 | Minolta EP1031/1031F CS/PRO Copier
Black streaks all over copy
Copies come out with one black line
Feb 05, 2009 | Sharp AL 1631 Copier
N95 Virus?
Change of a virus on your n95 is really small. I think you have just a bad screen. If warranty is still valid, i think you should try to get a new one. Otherwise, you should get a new screen and a some information on how to replace the screen.
Apr 03, 2008 | Nokia N95 Cellular Phone
Minolta 2300DL Printer - black streaks
Hey Chuck, Any chance you can post a scan of one of the faulty pages ? This will make it easier to assess the fault. Print off about 10 pages of a page that is affected by the lines. Look at each page and see if you can detect a recurring pattern over any of the pages. If there is a pattern, chances are it is probably the PCU that is marked.
May 20, 2007 | Minolta magicolor 2300W Laser Printer
you will have to check the Minolta web tech support team for this one.
May 20, 2007 | Minolta QMS 2200DL Laser Printer
Without actually seeing a print sample or the machine, my bet would be on the black print cartridge. Even though it reads a an acceptable level of toner, the cartridge itself sounds like it has developed a proble. 1. It's the most obvious 2. It't the cheapest place to start. If it does not correct the problem, you can still use it later. 3. It's the problem in about 80% of these types of cases. 4. I know it should be fine, but if things didn't go wrong, I wouldn't have a job! Let me know. If not we'll investigate further. Ed
LG 32LG30 32 in. LCD HDTV Logo
106 people viewed this question
