Question about Champion International Champion Riding Mower Lawn Tractor Cover
I need new choke and clutch cable for a champion 40 lawn mower but can't seam to fined where to get them from
Toro Model 20070 lawn mower starts and runs, just does not seam to have a lot pf power does anyone have a lack of power issue with their Toro 20070 Pace Lawn mower. Runs fine just no balls
could be dirt in the carby , blocked fuel filter or lack of adjustment in the accelerator cable
I will go for a cable adjustment as they slip under the clamp on the carby bracket when the throttle is pull wide open
May 30, 2016 | Toro Power Lawn Mower
Mtd lawn tractor wont run on fast
First off I don't know what the model number is to your mower so the first question I have is the choke operated by the throttle cable or is it separate? If it is all in one you may just need to reset your cable linkage because it sounds to me as if the choke is not completely undone or it is partially choked causing it to flood at a higher rmp due to improper air fuel mixture. I hope this helps.
Sep 22, 2013 | Mtd Garden
Can you use a champion spark plug rdj7y in 6.5 silver series lawn boy mower
Anthony you can use any kind of spark plug brand as long as its the same size. Sometimes they have a longer sparking element and this will catch on the piston. Just be careful.
Sep 10, 2013 | Champion International Lawn Mower Champion...
New craftsman 26hp gas out exhast
sounds like the float in the carburetor is not functioning correctly.
After the mower was turned off did gas start to drip out by the carburetor?
Jul 13, 2013 | Garden
Starting hard
Hi Ted, most likely the choke is not coming on fully. To fix this adjust the choke cable or if the choke is on the throttle adjust the throttle cable. Regards Phil.
Jan 01, 2013 | Cub Cadet Street Sign- tractor lawn riding...
I have Honda self propel lawn mover and when I push the choke lever will go down from 1 and 2 setting and it gets stuck between 2 and choke.
Be careful here. New choke wires are expensive! spray white lithium grease into the choke assemply up at the handle, then follow the cable down to the engine, extend the choke cable inside the outer cable housing and try to get it lubricated white WD-40 or white lith gease. spary everything at the chole area with WD-40 OUTSIDE only - operate the choke manually and carefully a few times and git mowin!
May 13, 2011 | Garden
Toro riding lawn mower. 12 h/p is hard to start
Hi there, It is most likely that the choke isn't closing fully. The throttle cable will need to be adjusted to cure this. The cable is clamped where it joins the engine. Simply slacken the bolt and move the outer cable out a bit. When you operate the throttle control you should see the choke start to operate near the start position. Make sure that the choke control rod operates to its fullest extent when the control is fully on the start position.
Sep 08, 2009 | Toro Lawn Mower With Toro Power Tools
Can't pull choke knob up on my riding lawn mower
take the cable off the mower and clean it in a pan with solvent or brake cleaner spray. you can coil it up to fit the pan while soaking. afterwards, let dry --- if you have an air compressor blow it dry to help clean and dry it --- then oil it up with a light oil or wd-40, wipe it off, stretch it out, and work the cable again before you remont it. the cable will stick if it gets too dirty and has no lubrication. may want to buy a new cable but they usually can be cleaned and lubricated.
Jun 25, 2009 | Garden
Champion International Champion Riding Mower Lawn Tractor Cover Logo
146 people viewed this question
Top Champion International Garden Experts
JohnPaul Robertson
Douglas Wade
Douglas Wade
Level 1 Expert
chuck ringwood
chuck ringwood
Are you a Champion International Garden Expert? Answer questions, earn points and help others
