Question about Whirlpool AWM6120 Front Load Washer
FP displaying in wash cycle - Whirlpool AWM6120 Front Load Washer
  • Whirlpool Master
  • 12,061 Answers
Drain as much water out as possible, tip the machine to 45 deg to one side under the drum there is a black ribbed elbow pipe leading to the pump, disconect it and check for obstructions, mine had a sock stuck in the hole. if not try the pipe from the pump
Posted on May 09, 2010
Flashing fp on my washing machine and stops half way through cycle please help
"PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Sep 28, 2011 | Whirlpool AWM8143 Front Load Washer
Display is showing FP - any ideas what I need to do?
FP message (on a Whirlpool Washing Machine or derivative of it) usually means that there is a 'F'ilter issue: check your machine drain pipe and drain filter and remove any obstructions from 'stuck' objects such as socks, hanky, coins, etc ...
Sep 23, 2011 | Washing Machines
Am getting FP error message on a Whirlpool 6th Sense washing machine. Have removed foreign objects from filter but still getting error message. What more can i do?
your right the error code is filer pump now disconnect power and let unit sit for 1 hr should reset its computer
dam computers
Dec 29, 2010 | Washing Machines
Machine will not spin and displays FP fault
Hi There
I have this for you and i hope this will get you in the right direction. Let me know how this goes. By the way Merry X-Mass and a Happy New Year.
PF Power Failure PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle. Thank you for writing to fix ya.
Best Regards Richard
Dec 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When machine get to rinse cycle it stops and the letters FP appear.
FP means "faulty pump" but before buying a pump make sure to check your drain hoses first since any blockage may cause the same readout in display:
Opene the flap on the front lower right side and unscrew the cap. If it doesn't come out easily a bit of force will get it out - look for hair klips and fluff blocking the pump inlet/outlet hoses.
GOOD LUCK!
Aug 30, 2009 | Whirlpool AWM8143 Front Load Washer
FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Dec 26, 2008 | Whirlpool AWM8143 Front Load Washer
Fp fault
The problem is pump is either broke or there maybe something is caught up in the impellor, easy to fix, remove front cover undo spring for door seal unplug electrics, remove both hoses on pump and undo bracket, then check pump, had same problem myself it was an elastic band and coins got it fixed myself saved a fortune hope this helps.
Dec 14, 2008 | Washing Machines
Won't run
found a pf not an a fp
Apr 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool AWM6120 Front Load Washer Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
