Question about Hotpoint WMA54 Front Load Washer
Door lock sencor not working properyl
Door lock censor not working properyl, it stops the washer until i push the door in at the bottom?
Thanks for any help in advance.
Regards simon (london England)
  • Hotpoint Master
  • 3,463 Answers
You probably need to fit a new door handle spring, and or a new door catch.
You will need to undo all the screws that hold the 2 halves of the door together and seperate the 2 halves of the door.
Then you will be able to see the problem, and repair as repair as req'd.
Posted on May 09, 2010
What would cause my Kenmore washer not to spin. I have replaced the MCU and still have the same problem. the door locks and the lock light comes on. All connections seem to be good. The drain at the bottom...
I would take the back off the machine and check the small 5mm censor pipe that goes off from the bottom of the drum and blow gently into it if you hear a click and one when you release the air then clean the small metal pipe where it goes on with a pipe cleaner or something similar as sometimes this pipe is only partially blocked not allowing the censor to react fully causing the problem
Dec 22, 2017 | Washing Machines
My whirlpool LHW0050PQ4 washer door is locked and unable to open, wash cycle is finished. Unplugged overnight and return next day, still locked. Any suggestions?
reset it
push sound for 10 secs
or
open top
spline screws top back
an reach down to the door latch
bottom of latch t is a small loop for your finger to pull/push it down
you can get to it same way from the bottom front cover
unplug unit
3 spline screws on bottom front washer cover
reach up an pull the loop on latch
good time to clean out the trap since your (t)here.
May 13, 2014 | Whirlpool Washing Machines
How to manually open locked door
First UNPLUG the WASHER.
There is a little white circle plastic lever that feels like an upside down lollipop about 2-3 inches below the door lock behind the front panel.. Pulling that down will unlock the door.
To access from the top of the washer remove 3 screws to the back top of the washer, push it back and then lift the top off the washer. Facing the washer slide your right hand down the space at the front corner where the lock is located. Feel around for the circular part at the bottom of the door lock and gently push it down. The door should then manually click and unlock.
To access from the bottom of the washer. Facing the washer, Remove the 3 screw to the very bottom that is holding the small access panel in place. This allows access to the bottom of the washer. Once removed, reach towards front and upwards to where the door lock is located. Feel around for a circle plastic level. Pull the level down. The door should click and you should be able to open the door.
Apr 18, 2014 | Maytag Washing Machines
Opening the door after a wash
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped.
Mar 18, 2013 | Bosch Logixx WFT 2806 Front Load...
Problem for Bosch Nexxt® 500 WFMC3301 Front Load Washer - it stopped completely while in progress. Despite resetting the breaker of the house the electronic display is not lighting up and the door is...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is for the WFMC6400, but it could help.
To manually unlock the door lock system, perform the following steps:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and
locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch
assembly is a teardrop shaped tab.
Gently pull the tab down approximately 1/4 inch,
or until a click is heard.
5. The door may now be manually opened.
Pl give me a ‘very helpful’ rating for the free help, thanks!
Oct 26, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Door not locking
Doot lock hook may not be engaging or door lock is faulty- wiggle the door around while pushing on it, check the door hook , replace the electric latch
Sep 12, 2009 | Samsung WF337AA Front Load Washer
No lights on panel, door won't open
This is for the Whirlpool/Kenmore HE2 Plus:
1 Unplug/Disconnect the washer
2 Remove the lower kick panel
3 Reach up along the inside of the front & locate the bottom of the door switch/lock unit.
4 Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
5 Gently pull the tab down about quarter inch or until a click is heard. Gently open door.
Apr 11, 2009 | Kenmore Washing Machines
Duet front load washer control locked--How do I undo??
Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom
4. Located on the bottom of the door switch/lock unit is a
5. Gently pull the tab down about a ¼" or until a click is heard
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint WMA54 Front Load Washer Logo
101 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
