Question about Microsoft Windows XP Professional SP2
I'm using Windows XP professional. Recently, I got formatted my system. Since then, when I'm pressing DELETE button or RIGHT CLICK any folder....The screen is disappearing for 2 seconds & all folders getting closed & taskbar customize changes being changed.
  • 88 Answers
Strange problem, if you are sure that you didn't catch some malware then try this sollution: (scroll down to "Resolution" in this link)
http://windowsxp.mvps.org/slowrightclick.htm
If that didn't help then try checking this thread:
http://forums.techguy.org/windows-xp/446850-windows-explorer-right-click-crash.html
Leave rate if I helped you, thanks!!
Cheers,
Mike
Posted on May 09, 2010
I installed Windows XP a second time on my hard drive hence I now have a menu on boot up where I select which operating system I wish to use. I have since delted the second install of XP but the menu...
If you just formatted the partition with the second XP installation on there, it should remove the boot menu where you choose which installation to go to.
Here are a few options for you to choose from.
  • Option One: Open Start-Run and enter msconfig Click the tab "BOOT.INI" The contents of the boot.ini file are shown and a number of configuration settings are available. Under Operating systems, delete the one you don't want. Be careful not to delete the wrong one.
  • Option Two: Right-click on "My Computer" and choose "Properties" from the context menu. The System Properties dialog box will open. In the section "Startup and Recovery" click the button "Settings". To delete the unwanted operating system from the boot display menu, use the "Edit" button on the right of the entry.
  • Option Three: If the OS is Windows XP Professional, it has a command line utility for manipulating boot.ini called bootcfg.exe.
    Click start, type CMD, click OK and you are presented with the command prompt. Type bootcfg /? It will list the description and parameter list. Once again, you can delete the unwanted OS.
  • Option Four: Boot to the XP install disk and open up the command prompt utility of the disk. Enter "fixmbr" and press enter. Restart the computer and remove the disk.
Mar 05, 2011 | Microsoft Windows XP Home Edition English...
Tip
"the component IoloSystemService" Error on Iolo System Mechanic Pro
The "the component IoloSystemService" Error message shows up due improper installation of the System Mechanic Pro. Some of the Iolo dependencies failed to get activated and that is the problem.
Now the only solution to fix it is to follow a thorough uninstallation of the System Mechanic Pro.
For WinXP, you can uninstall it from the "Add or Remove Programs".
Next, once its unistalled do not RESTART the PC.
Now, go to the Registry (press "windows" + R to open the run command and type "regedit").
OR
Click the Windows start button and select RUN. Type REGEDIT on the openfield.
On the left-hand side, expand HKEY_CURRENT_USER by clicking the + symbol next to the entry.
Expand Software.
Expand the iolo folder.
Navigate to the System Mechanic Professional folder.
Right-click on the System Mechanic Professional folder and select Delete.
Click Yes to confirm the deletion.
On the left-hand side, expand HKEY_LOCAL_MACHINE by clicking the + symbol next to the entry.
Expand Software.
Close the Registry Editor.
Click Start>My Computer and then navigate to your Local Disk (usually the C: drive) then Program Files\iolo\System Mechanic Professional.
Click Yes to confirm.
on Jun 16, 2010 | Computers & Internet
How can i remove microsoft windows 2000 form a dual boot system
Just start windows XP. Open Explorer go to menu: Tools - Folder Options Select : View Tab Select : Show hidden files and folders Click OK In explorer select C;\ Look for file : boot.ini Open boot.ini for editing (double click) CAREFULLY remove the line which looks like : multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" Close notepad, select SAVE Reboot You will not have the option to start windows 2000 anymore. On your desktop right click: My Computer and choose "manage" Select: Disk Management Select the partition where Windows 2000 was (is) installed. Right click and choose format You can now use this partition to store data and or programs
Feb 01, 2011 | Microsoft Windows XP Professional
The iolo system shield would not update
This is gonna be Lengthy process.
First
Uninstall System Mechanic Professional
Open the Control Panel by clicking:
Start>Control Panel
or
Start>Settings>Control Panel
Open Add or Remove Programs.
Locate and select the entry entitled iolo technologies System Mechanic Professional
Click the entry’s corresponding Change/Remove button.
Follow the on-screen instructions to uninstall, restarting the computer as prompted.
Remove the System Mechanic Professional registry entries
WARNING: Using the Windows Registry Editor incorrectly can cause serious problems and may result in an inoperable operating system. Use Registry Editor at your own risk and discretion.
Click the Windows Start button.
Select Run.
Type regedit in the Open field.
Click OK.
Expand Software.
Expand Software.
Remove residual antivirus files
Close all open windows and restart the computer
Follow the same process to uninstall the System Shield also.
Reboot the PC after everything is over.
Then install System Shield First, reboot the PC after the installation and check if the update it working or not. Once its confirmed that System Shield's update is working, install the System Shield.
May 30, 2010 | ACDSystems System Mechanic with Bonus Iolo...
My System Mechanic Professional not is too good: "the component"iolosystenservice" is required for System Mechanic Professional to operate properly and could not be started please let me know some...
OR
Expand Software.
Expand Software.
May 19, 2010 | Iolo Technologies System Mechanic: Windows
Program won't start. Get message "the component IoloSystemService" is required for system mechanic to operate properly and could not be found. System Mech 9.5.6 is installed and looks good. Running XP,...
OR
Expand Software.
Expand Software.
Reinstall the System Mechanic Pro
Mar 06, 2010 | Iolo Technologies System Mechanic: Windows
$Recycle.Bin and System Volume Information
please click start->all programs->accessories->windows explorer right click it and select RUN AS ADMINISTRATOR
when a new window appears go to the drive and delete what ever you want
you can also use winkey+r and type explorer and press enter and do the procedure as stated above
Hope this helps
Please rate
Thnx
Waqat
Jul 17, 2009 | Microsoft Windows XP Professional With...
Windows XP Pro
Thats is virus...you need a updated virus guard to clean it.
Feb 05, 2009 | Microsoft Windows XP Professional With...
Password on shared documents on a workgroup
Password Protect Folders in XP
To password protect a folder built into Windows XP (for other Windows flavors, there are some freeware/shareware programs out there).
If you have a log in password for your account, this can be used to protect folders from other users. If not, you need to creat one. Your hard drive must be formatted using NTFS (which it probably is unless you're dual booting with another operating system). Here's what to do...
Right-click the folder that you want to make private and choose "Properties" (or Alt+Double-click). Go to the "Sharing" tab and check the "Make this folder private" box.
Click Apply . If you do not have a password on your account, a box will pop up asking if you want to assign a password. This must be done if you want to make the folder private, so click Yes . You will need to use your password to log on to your computer from then on.
Type in a password then confirm it. Click the "Create Password" button then close the Password window.
Click OK in the Properties dialog box.
Now anyone else logged on to your computer can't access that file without knowing your password.
Dec 02, 2008 | Microsoft Windows XP Professional
Windows xp service pack 2
Hi 1. Click Start, click Run, type regedit in the Open box, and then press ENTER. 2. Locate and click the following registry key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom 3. To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1. 4. Restart your computer. NOTE: This method disables automatically running CD-ROMs. If you want to disable automatically running CD-ROMs depending on the CD-ROM that you insert in the CD-ROM drive, you can press and hold down one of the SHIFT key while you insert the CD-ROM. This may help. Good Luck
Sep 12, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional SP2 Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
