SANYO REMOTE COTROL
IN SIDE TEMP ON REMOTE READS 37
  • 86 Answers
1.check remote its working properly or not.
2.check temperature control switch.
3.put the temperature put below 16 n on the unit
4.if not working change the remote
Posted on Mar 28, 2008
Sanyo 37 LCD ce37ld33-b
Sounds like display panel fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Sanyo Televison & Video
User manuals
google user guide sanyo model sr-290 also the temp setting for 37 deg is 37 deg the numbers on the dial are only for reference you should get a thermometer for accuracy
Dec 01, 2013 | Sanyo SR-290 Compact Refrigerator
Where is temp cotrol door located on 2000 buick century
before chasing doors inside the heater box a low freon charge will cause the problem your looking to repair
Jun 05, 2012 | 2000 Buick Century
Fisher/sanyo 37" tv. when I
Hello
If you are using a Universal remote control with this set, some button functions won't coincide with the display. If you are using its original remote control, the contacts inside the remote control is dirty or dusty. You have to open the remote control and clean its contact pad and printed circuit touch pad with rectified spirit or medical quality turpentine. Never use petrol of such hard solvents to do this, becuse they will damage the rubber parts of the remote control. If it is a universal remote control doing this will be of no use. It will behave only like this. OK.
Jul 09, 2011 | Sanyo 42 in. LCD TV
I have 1 37" Sanyo LCD TV. The screen is split
bad screen driver boards, it can sometimes be corrected by tapping it on the side that is affected NOT ON THE SCREEN I MEAN ON THE TOP. The only way to cure the problem is replacing the panel.
Nov 14, 2010 | Sanyo DP37647 37 in. LCD TV
Need codes
I have old model portable tv.Has perfect picture.But, cannot find a remote cotrol or code compatible to make it change channels or adjust the volume..Phillips Brand Model PR0920X101
Sep 13, 2010 | Philips Magnavox 42MF521D/37 Television
Pool Heater Mis-reading Temp.
Your temp sensors are on the heater, a small tube that slides into the water manifold, usually on the left side. On the remote it will be in one of the pipes coming from the pump or the filter. If it is after the heater you should move it to between the filter and heater. It will be a tube that is in the pipe with a stanless steel clamp holding it in place.
To find out wich one it is you will need to remove the remote from the system by takeing the wires that go to it from the wireing inside the heater and wire nuting the wires in the heater together. If the heater runs normal then it is the sensor for the remote if not it is the sensor for the heater. Let me know how you do and if need be we can get a little more specfic for your system. good luck.
Mar 29, 2010 | Pentair Minimax NT Heater
No remote cotrol available
Yes.
remotes.com has one.
It's the only place I can find one for TA2050.
Feb 20, 2009 | GoVideo TA2050 20 in. EDTV-Ready LCD...
Remote codes lost need new ones
i am guessing you found out it is a phillips remote and found the codes. if not get back to me
Oct 09, 2007 | Televison & Video
Heating & Cooling Logo
113 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
