Question about Sharp Viewcam VL-Z1H Mini DV Digital Camcorder
Tape will not load into camcorder. Keeps ejecting.
SOURCE: sony hi8 ccd-trv208e pal camcorder
Same problem, same frustration. Just flashing, won't open to insert tape, Battery relatively new. Is there any way to get it to open to put in tape? I hate this technology, not along far enough.
Posted on Feb 03, 2008
SOURCE: Canon zr300 ejects tapes
I just tried the "Fonzie" fix in my ZR300 and my camera now works - cassette compartment closes all the way now with the tape inserted. It just took one "hit" to fix the prolem. I was surprised. But ericemartin's solution is worth a try.
Posted on May 28, 2008
The solution for this required sending it to Canon factory service. I was very reluctant to do this because I've heard horror stories about Canon service, but I was actually pleasantly surprised. The total cost was only about $65 and the shipping and service turn around time was amazingly fast. I was expecting weeks to go by. If memory serves me right I shipped it and received it back in less than 2 weeks.
This is a known problem with Canon and would be covered under warranty if your time hasn't run out.
Posted on Sep 25, 2008
SOURCE: Cannot insert tape into canon MV800. Always ejects
Hi Everyone,
our MV800 was doing the the same so i "accidentally" dropped it (i got a bit frustrated and it was out of warranty) and now it works fine. please note it dropped about half a meter on carpeted floor while it was off.
Hope this helps
Posted on Dec 18, 2008
satavlad
  • 405 Answers
SOURCE: Sharp VL-Z1 will not load the cassette...
Modification is available to fix this problem, contact sharp repair facility.
Posted on Oct 26, 2009
My TRV68 ejected a tape half ways and stopped. I removed the power source and then the tape ejected fully upon reconnecting the battery. HOWEVER, now the tape loads and then will not stay in - the camera...
This is a common problem often caused by a problem with the head/motor assembly. This is not a DIY repair. It is possible that this can be repaired without any parts. Expect to pay in the $150 range for labor.
Dan
Mar 30, 2011 | Sony Handycam CCD-TRV68 Camcorder
I have a canon MV 830.Please could you tell me when i put the cassette into the camcorder it keeps beeping then asks me to eject the cassette. Is this expensive to fix?
My MV830 would load without a cassette; but freeze, beep 3 times and eject if a cassette was inserted. I read the following thread with a great deal of scepticism and concern that I would damage my MV830 camcorder even more; but what did I have to lose? I loaded the compartment without a cassette, hit it firmly 3 times on the tape loading side and the issue was gone. It now works perfectly! Technology is fantastic...
http://www.fixya.com/support/t238707-will_not_load_tape
Dec 06, 2010 | Canon MV830 Mini DV Digital Camcorder
Handy cam video 8 XR keeps ejecting cassette any ideas please
thats is because the servo mechanism chip do not detect the cassette,
when its in the housing could be a sensor or the cassette in switch or mechanism its self (missalignement.)
hope that will help you
regards alan.
Oct 18, 2010 | Sony Handycam CCD-TRV37 Camcorder
Every time i put a tape in to play or record, it keeps ejecting it why??
Please be more specific. When you insert tape, the tape housing extract to its body, or it just stays still and eject your tape.
Aug 15, 2010 | Canon ZR100 Mini DV Digital Camcorder
I can't eject cassette from my Canon MV800i
The mechanical of the tape loading path is misaligned, Contact any expert for mechanical adjustment of the tape loading path, No worries it will work fine again, and this would not be expensive.
Thanks for using fixya.
Jun 16, 2009 | Canon MV800i Mini DV Digital Camcorder
Sony TRV120 Won't load tape C21:00 code
From the user manual ...
Under self diagnosis display
C21:00
Moisture condensation has occurred.
Remove the cassette and leave your camcorder for at least 1 hour to acclimatize. (p117)
On p117
If your camcorder is brought directly from a cold to a warm place, moisture may condense inside your camcorder, on the surface of the tape, or on the lens. In this condition, the tape may stick to the head drum and be damaged or your camcorder may not operate correctly. If there is moisture inside your camcorder, the beep sounds and the [picture of water drip] indicator flashes. When the [end tape icon] indicator flashes at the same time, the cassette is inserted in your camcorder. If moisture condenses on the lens, the indicator will not appear.
If moisture condensation occurred
None of the functions except cassette ejection will work. Eject the cassette, turn off your camcorder, and leave it for about 1 hour with the cassette compartment open. Your camcorder can be used again if the [water drip] indicator does not appear when the power is turned on again.
Note on moisture condensation
Moisture may condense when you bring your camcorder from a cold place into a warm place (or vice-versa) or when you use your camcorder in a hot place as follows:
- You bring your camcorder from a ski slope into a place warmed up by a heating device.
- You bring your camcorder from an air-conditioned car or room into a hot place outside.
- You use your camcorder after a squall or a shower.
- You use your camcorder in a high temperature and humidity place.
How to prevent moisture condensation
when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and tightly seal it. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature (after about 1 hour).
Dec 06, 2008 | Sony Handycam DCR-TRV120BT Digital...
Canon Elura 65 Camcorder Refuses to Load Mini DV Tape
Try a different tape in case the take up isn't working in the previous tape.
Clean the tape heads with a tape cleaner in case there is buildup on the pinch rollers causing the tape to jam or slip.
If those solutions don't work, you should take it into a repair shop to have a closeup view as to what the problem is unless you see something obvious like a spring broken or loose or a bent piece or foriegn objects in the deck.
Aug 12, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Mv800i camcorder
well there are certain cassettes made for that camcorder. i suggest you search for what the are called and then you can buy them
May 26, 2008 | Canon MV800i Mini DV Digital Camcorder
My sharp hi8 camcorder will not produce a picture unless it is in the review mode. What can I do?
The loading mechanism is not completing its cycle. That will cause the tape to be ejected as a safety feature so no damage occurs to the tape. This unit will require a "rebuild" to retime the loading mechanism.
Dan
Apr 19, 2008 | Sharp Viewcam VL-A10U Camcorder
Playback & Ejection Problem
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
Sep 04, 2005 | Canon ZR25MC Mini DV Digital Camcorder
Sharp Viewcam VL-Z1H Mini DV Digital Camcorder Logo
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
