Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
When i try to print, it says the ink catridge was run out.
    Sergeant:
  • 284 Answers
When machine shows ink out, you must replace with new cartridge. If not the machine won work.
Posted on May 31, 2010
I keep getting a error code 1203 what does that mean
Hello
It means your catridges overflow even from brand new catridges after several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge
use a klennex with a few drops of water to dampen and clean off those contact on the holder and your printer should work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned catridges a couple times then run clean catridges a couple times.
Print the test page to see how it looks .
Be sure not to leave any debris of klennex on those holder contact panel.
Jun 10, 2011 | Dell 926 All-In-One InkJet Printer
I cant print and get error message 1203 on my lexmark p315 model:any idea wat that error message is?
t's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Too bad that I also cound not find out how to reset the ink indicator. It's annoying to hit the OK button every time you want to print.
Try and see if it's work for you. Good luck......
Dec 22, 2010 | Office Equipment & Supplies
I was printing on my printer with no problem when in the window of the printer it shows cartridge error,error 1203.I checked the cartridges and they look fine.I took them out and put them back in I...
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge.
Solution:
The refill ink works very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Try and see if it works for you. Good luck......
Oct 30, 2009 | Dell Photo 964 All-In-One InkJet Printer
Replaced color cartiage, now only one color prints, red? Help
Try to check the level of your ink in your color catridge maybe is running low or empty then if its empty then remove the catridge then replace another color catridge full of ink then run your printer again. If you successfully installed new ink catridge then it will automatically reset the level of your ink monitor to full.
Jun 16, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Error 1203 how do I fix it?
try this solution:
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
Jun 10, 2009 | Lexmark X4250 All-In-One InkJet Printer
Catridge problem
when printing try to press resume button for about 5 seconds
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
L have an error #1203 what is it
Solution:
Sep 29, 2008 | Lexmark Office Equipment & Supplies
Error 1203
Solution:
Sep 28, 2008 | Office Equipment & Supplies
Error 1203
  It's mean your catridges overflow even from brand new catridges. After  several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge is located.
Solution:
 use  kleenex with a few drops of water to dampen and clean off those contact on the holder.
The refill ink works very well if you let it sit 24 hrs. Then before you print anything, you should run align  catridges a couple times then run clean catridges a couple times.
Print the test page to see how it  looks and away you go.
Oct 29, 2007 | Lexmark P4350 All-In-One InkJet Printer
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
old marine
old marine
