Question about Garmin GPS
Garmin Nuvi 350 won't turn on after pressing reset button
A message onscreen suggested that I continue, by using the battery, and I responded yes. After a countdown, the screen went blank. I tried resetting by holding the power key down, the one on the top right and again the other one on the back of the Garmin, for 30 seconds each, and it still does not turn on. I did this while it was plugged into the car, and while it was unplugged. Thanks for helping me out.
  • fergstudios May 09, 2010
    Yes, very helpful. I found the computer USB---which I didn't remember receiving--- and plugged it in to the Nuvi, and it worked!
  • 19,396 Answers
Hi.
That may happen because you drained the battery completely.
Connect the Nuvi to charger and turn car on. wait fifteen minutes or so, then turn on the Nuvi. If that does not work, then the internal battery must be replaced. In that case you will need to contact Garmin at the number listed on the owners manual.
If that does not work, also test the Nuvi using a different charger, or connecting it to a computer USB. Sometimes the problem is caused by a defective charger.
Regards.
Posted on May 09, 2010
Reset with no disc etc
SAT NAV - RESET PROCEDURES FOR GARMIN, NAVMAN, TOM TOM
Updated 08/05/2014 05.01 PM
Reset Procedures for Garmin, Navman, Tom Tom
Garmin Master Reset NB: This will erase all way points or favourites and will restore your unit to the default factory settings.
Nuvi® 2xx, 2x5, 5xx, 6xx, or 7xx.
  1. Start with the unit OFF and unplugged from power.
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil.
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON.
  4. Release the power button when the device powers ON.
  5. You will see a new message: Do you really want to erase all user data?
  6. Remove your finger from the touch screen when this message displays.
  7. Touch Yes.
The device will automatically reset. Please follow the on-screen prompts on the n?vi and when completed, place your device in an area with a clear view of the sky until it acquires satellites.
Nuvi® 8xx or 5000.
  1. Turn the device OFF (you will need to remove the battery from a nuvi 8xx).
  2. Turn the device back ON (you will need to install the battery into the nuvi 8xx).
  3. When you see a progress bar on the screen of the unit, quickly place your fingertip, or the eraser end of a pencil, in the bottom right corner of the touch screen.
  4. Hold the bottom right corner of the touch screen until a message says, "Do you really want to erase all user data?"
  5. Release the touch screen and touch Yes.
  6. The unit will now restart.
  7. Follow the onscreen prompts to set up the nuvi.
Navman S30/50/70/S80/90i.
  1. To reset your device, hold down the power button for at least 10 seconds and the device will power off.
  2. Press and hold the power button to turn the device back on.
For other models, please visit this link, select model and search for 'reset'.
TomTom
  1. Soft reset - select your model.
  2. Reinstall TomTom application.
  3. Format internal memory or memory card.
Apr 01, 2015 | Navman S30 3D Portable GPS Automobile...
Hello i forgot my germin nuvi 350 gps password can you please help me how to reset it Plzz
To perform a Master Reset on the nuvi 300 series, follow these steps:
  1. Start with the device OFF and unplugged from the power source.
  2. Use your index finger to press and hold the top right corner of the touchscreen.
  3. Power the device ON while continuing to press and hold your finger to the top right corner of the touchscreen.
  4. After the device powers ON, release the power button. Then you will see the message: Do you really want to erase all user data?*
  5. When this message displays, remove your finger from the top right of the touchscreen and touch Yes.
  6. The device will now go through the Reset.
  7. Follow the onscreen instructions to set up your nuvi.
After the nuvi is set up, if indoors, please go outside to allow the device to acquire the satellite information. Ensure that the device has a clear line-of-sight with the sky.
*If this message does not appear when using the top right corner of the touchscreen, please repeat these steps using the bottom right corner of the touchscreen.
May 30, 2011 | Garmin nuvi 350 GPS Receiver
My garmin nuvi will not shut down. The screen is white. Is there a reset button on the unit?
In some nuvi models there is a reset button.But in some nuvi models there is no reset button.you have mentioned only garmin nuvi but not mentioned the model of the garmin nuvi.But still i will mention the reset button location of some garmin nuvi models.Hope that helps you.
The reset button/procedure for garmin nuvi models
In order to reset Garmin device or enter into maintenance mode, perform one of the following procedures:
Power off Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
above works on Garmin Nuvi 660, 680 series.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
above works on Garmin nuvi 200, 250, 360 750, 760 series unit. Garmin Nuvi 360 on how to perform the hidden reset function.
Reset button on the bottom of the nuvi backside.
Click on the link below to get the exact location of the reset button.http://www8.garmin.com/manuals/1512_SetupandGo!.pdf also check out this link too http://www8.garmin.com/manuals/Nuvi350_OwnersManual.pdf Thanks. keep updated for any more query.you can rate this solutionand show your appreciation.
Jun 11, 2010 | Garmin GPS
GPS is disabled
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
Apr 14, 2010 | Garmin Nuvi 350 Car GPS Receiver
My garmin 255w nuvi keep turning off and wont turn on
It is a good idea to perform a hard reset on your Garmin Nuvi after updating the software.
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
Dec 29, 2009 | Garmin nuvi 255W GPS Receiver
Nuvi touchscreen dead
settings.
1. Turn the device OFF.
2. Place your fingertip or the eraser end of a pencil in the top right corner of the touchscreen.
3. Apply pressure in the top right corner of the screen.
4. While pressing down on the screen, power ON the unit and continue pressing on the screen. A message displays
to confirm if you really want to delete all user data?
5. Touch Yes.
Jul 31, 2009 | Garmin Nuvi 350 Car GPS Receiver
After trying to install new maps, Garmin nuvi 350 don't start
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 30, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi
Hi Matt,
That function normally comes up when you put your finger on the upper right corner of the screen and hold it there while you turn it on.
Have you tried pressing the reset button under the antenna?
- Jim
Sep 17, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350
All you need is to reset the GPS. THere is a small button under the antenna. Simply press the button, and everything would be reset.
Apr 16, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin 360
Have you tried performing a soft reset by pressing the reset button on the back of the unit, then turning it on again?
How about a hard reset?
With the unit powered off, hold your finger on the upper right- hand corner of the touch screen and tap the power key. Continue to hold your finger on the screen until you get a warning message. Tap "OK" to reboot the GPS.
Please let me know if I can be of further assistance to you.
- Jim
Feb 15, 2008 | Garmin nuvi 350 GPS Receiver
GPS Logo
21 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
