Question about Linksys WAP200 (LS-WAP200) 802.11b/g Wireless Access Point
Default IP 192.168.1 doesn't work , how can I setup and secure password on my wireless
  • 88 Answers
because default IP is 192.168.1.1 not 1.92.168.1
Leave rate if I helped you, thanks!!
Cheers,
Mike
Posted on May 09, 2010
I just received a new modem from my cable company and now my router doesn't work. I tried resetting it and it still doesn't work. What do I do next
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Need to set up security key for wireless access. Have dlink WBR1310 router, but no longer have the CD that came with it. Recently had laptop repaired.
once connected to the network type 192.168.0.1 into your address bar in your browser.
Username is admin
Password can be left blank
Click wireless network settings. Use the wizard.
Mar 03, 2011 | D-Link dlinkgo Wireless N 150 Router...
Hi, i have already installed and all is running fine however i didn't secure the network and now need to add a password how would i do this ?
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE: If the IP address of the router has been changed, type the router's IP address in the "Address" bar instead.
The router's IP address can be changed by:
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
    NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name space blank, type in your router's password ("admin" is the default password), then click OK.
3695-005.png NOTE: If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
Step 4:
When the router's web-based setup page appears, click the Wireless tab and select the Wireless Security tab.
Step 5:
For the Security Mode, select WEP.
Step 6:
For Encryption select 104 / 128-bit (26 hex digits).
Step 7:
For the Passphrase, type a wireless network password of your choice such as "MySecretKey," then click Generate.
NOTE: Your password should be unique and can be a combination of numbers and letters of up to 16 characters.
Step 8:
For the TX Key, select any number. This will determine which key you'll be using. In this example we selected number 1.
Step 9:
Copy Key 1 as this will be the key to your wireless network.
Step 10:
Click 4058-005.jpg.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | D-Link DIR-615 Wireless Router
I have forgoton my key words
If you forgot your password, we can actually access the router web ui.
Accessing the Router's Web-based Setup Page
Step 1: Open your web browser.
Step 2:Enter your router's IP address on the address bar and press the Enter key.
NOTE: The router's default IP address is http://192.168.1.1.
Step 3: The Enter Network Password window will then appear. Type your router's User name and Password. Click OK afterwards.
Web-based Setup Page Wireless Security Options
On the web-based setup page, you'll be able to see all of your router's wireless security features. Wireless settings wherein you can see your network name and once your click wireless security sub tab under wireless page you will then see your network key or password (passphrase).
Nov 05, 2010 | Linksys Wireless-G WRT54G Router
How do you remove a security code from a wireless router?
Disabling wireless security key on the router. Just follow these steps:
Step 1: Access the router's web-based setup page.
Note: For Linksys default ip address 192.168.1.1: default password
Step 2: On the router's web-based setup page, click the Wireless tab then click the Wireless Security sub-tab.
Step 3:Click the drop-down arrow for Security Mode and select Disable and save settings.
Nov 04, 2010 | Linksys Wireless-G Broadband Router
I want to change password for wifi network
Open up an Internet browser window on your computer system. To gain access to the default settings, type in the default IP address of the wireless router in your Internet browser's address bar and press enter. You must refer to the wireless router's documentation or navigate to the manufacturer's website for the correct IP address.
Type the default user name and password in the security dialog box that appears, then press Enter on your keyboard. Because different router manufacturers use different default user names and passwords, refer back to your router's documentation or support webpage for the correct information.
Navigate through the router administration pages to find the wireless router's administrator password settings. Change the default user name and password to a unique set so that possible unauthorized access to your router settings will not take place. Make sure to hit "Save Settings" to complete the change.
Set up your wireless security settings by navigating to the proper administration settings page. By default, wireless routers do not come with a password for connectivity access. Choose the appropriate wireless security level you need and type in a unique user name and password. Save these new settings and log out of the router's administration setup.
5
Write down the user names and passwords for both network access and the administration setup page. Keep these user names and passwords in a safe place.
Thanks.
Have a great day.
Oct 14, 2010 | Computers & Internet
Zyxel 600 security
Open a web browser like internet explorer or firefox. Enter the ip address of your router in the address bar of your browser. By default the ip address should be set to 192.168.1.1. You should see a box prompting you for your username and password.
Enter your username and password now. By default the username is admin, and the password is 1234. Click the Ok button to log in to your router
Click on wireless setup and you should have options there to change the security settings and setup a WEP key(password).
once you do this.
click on start
click on run
type ncpa.cpl
right-click wireless local area connection
click on view available wireless networks
and connect to your network again using the new password that you have just setup
Feb 20, 2009 | Zyxel Prestige 600WH Wireless Router...
Wireless router hookup...
You need to use a working computer with the router then access the router setup page that way you can get the wireless security key, then follow this step:
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
When you're already on the Linksys router setup page, click on Wireless tab and look for a sub tab that says Wireless security and there you can find the security key that you're looking for..
Hope that helps..Don't forget to rate the solution FIXYA thank you...
Oct 04, 2008 | Linksys Wireless-G WRT54G Router
Removing security from a wireless network
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Wireless Router (The default IP Address is 192.168.1.1).
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Wireless Routers password (The default password of a Linksys Router is admin) into the "Password" field.
  4. After the "Setup" Page loads, click on the Wireless tab.
  5. From the "Wireless" area, click on the Wireless Security sub-tab.
  6. When the "Wireless Security" area opens, select the Disable option for "Wireless Security" option
Apr 17, 2008 | Linksys Wireless-G WRT54G Router
Where to find security settings for wireless routers and to changed security setting for wireless router
On the back or bottom of the router is a default ip address,(192.168.??.??) also will be the username and password needed.
  1. Open the browser you normally use e.g.Internet Explorer
  2. in the area you would normally type a web address, type in the default ip address
  3. log into the router
  4. Go to the wireless setup tab or security tab
Apr 13, 2008 | Computers & Internet
Linksys WAP200 (LS-WAP200) 802.11b/g Wireless Access Point Logo
190 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
