Question about Maytag Neptune MDG5500AW Gas Dryer
My dryer doesn't get hot enough to dry clothes.
I have to turn the auto dry cyle on more than once in order to get clothes to dry completely. I have cleaned out the vent many times and it doesn't solve the problem.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: my dryer doesn't get hot enough to dry clothes.
Try changing the ignitor...
Here is a tip that will help to explain why I think this is probably your problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Posted on Apr 01, 2010
Why dryer shuts off too early on auto
The sensor detects the moisture content of the clothes, If the clothing is packed tightly some of the clothes in the middle of the pile might not dry completely, if the clothes on the outside near the drum have low enough moisture. If you have a position on the control for dryer clothes or a more dry position try using that or use timed dry.
Aug 01, 2014 | Whirlpool Dryers
Whirlpool gas dryer (LGR8648PW1) doesn't stop spinning in automatic mode.
More than likely a bad timer assembly. They are usually easy enough to replace if you have basic mechanical skills. The part can be ordered from repairclinic.com.
Jun 26, 2012 | Whirlpool Dryers
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
Dryer unevenly drys clothes
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
Jun 21, 2010 | Bosch Nexxt 500 Dryer
Dryer won't get hot enough to dry clothes
mAKE SURE THE VENTING SYSTEM IS COMPLETELY CLEANED OUT. a MOISTER SENSOR DETECTS ANY BUILD UP OF LINT CAUSING TO KEEP THE HEAT IN CHECK WHICH TAKES LONGER FOR THE CLOTHES TO DRY
Jun 13, 2010 | Hotpoint NBXR463EBWW Electric Dryer
heatman101
Apr 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
Runs and heats but will not dry
Fist need to know if it is gas or electric dryer, it makes a difference.
If an electric dryer, It is possible that one of the heating elements has failed (burned out), which would still allow the other one to get hot, but not enough to completely dry the clothes during the normal timed or automatic drying cycles.
You can check this with an ohm/amp meter if you are comfortable with working around 220V-AC voltage, etc. You'll need to remove either the rear cover, (if your unit has rear access) or the top of the dryer and then the drum, to gain access to the electric drying elements. This depends on which model you have and how old a dryer it is, etc.
Once you've done that, you can sometimes see a broken drying element, if not, you can check for continuity with the ohm meter (make sure the power cord is unplugged!).
If you are unable to determine with this method, you can restore power and briefly put the dryer into a timed dry cycle (drum and drive belt removed, while you visually check for heating elements turning red/orange as they heat up. Only do that long enough to confirm which element is good, be very careful, as they get extremenly hot. Once you know which one is bad you can order your replacement by model number , etc. Hope that helps.
Jul 13, 2009 | Maytag Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
GE Dryer model DBXR463EDIWW
If there is no lint blocking the air outlet path, I would next check two things: First, is the dryer in a small, closed room? If there is not enough space for air to get in to the dryer, it won't have good airflow through the clothes. Second, for older dryers, the blower fan may be loose on its shaft or, if the blower has its own separate motor, the blower motor might be dead. In order to find the blower fan, you'll have to be able to open up the dryer. Once you find the fan, see if it turns easily without moving the motor shaft -- if so, you need to replace the fan. Also, be sure there isn't anything blocking the blades of the fan.
Dec 30, 2008 | GE DBXR463EBWW Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
