Question about ASUS Eee 4G Notebook
Touch pad will not zoom in or out - ASUS Eee 4G Notebook
  • 88 Answers
missing drivers. Go to:
http://www.asus.com/product.aspx?P_ID=h6SPd3tEzLEsrEiS
On the bottom you have "Download" tab. Click, then pick your operating system, when the list of things to download will show up select "touchpad" and download thing which will appear. done
Leave rate if I helped you, thanks!!
Cheers,
Mike
Posted on May 09, 2010
Don't you just slide two fingers apart to zoom out and slide them back together to zoom in?
Posted on Sep 19, 2010
3 Suggested Answers
SOURCE: fn button not responding, touch pad not zooming/scrolling etc
O have a eee notebook. An antivirus programme attached it self to my system, asking me to purchase. I tried to get rid of it with no success. I turned off the notebook, re started pressing f 8. Tried running it in safe mode, the whole thing freezes once this is done. Everyother option on the f 8 menu, gets no response. Any ideas.
Thanks
Paul
Posted on Dec 19, 2009
Endeir
  • 140 Answers
SOURCE: how to disable touch pad in asus k40IN series?
This happend to me on a Asus U81 (Best Buy version of the U80) which has the Elantech mousepad
9.10 includes an X configuration utility called xinput. It is a command line tool. To see the many things you can do with this simply type xinput at a shell prompt.
Start by typing in:
Quote: xinput list This will show you all the input devices attached to your computer. You will need to know your mousepad's id to continue. On My Asus laptop the internal pointer was found as a "ImPS/2 Logitech Wheel Mouse". The Id I get after booting my system with my external mouse attached is 10.
Next you need to know how to disable the mousepad. So you need to know what properties it supports. the command is "xinput list-props" followed by your mousepad's id number, which for me was:
Quote: xinput list-props 10 The "Device Enabled" was what I needed to be able to use to switch it off. On my laptop this line was "Device Enabled (97): 1". The parenthesized number is the properties id number, the 1 that follows it is the value (0 will turn it off).
So now I need to set it such that the mousepad is disabled. My mousepad id is 10, property id I want to set is 97 and I need to set the property value to be 0. The option for xinput is set-int-prop which needs deviceid, propertyid, format of the value (8, 16, or 32 bit), and the value itself. For me this is:
Quote: xinput set-int-prop 10 97 8 0 To turn it back on:
Quote: xinput set-int-prop 10 97 8 1 Since this does its work on the X in memory it is not persistent. If you log out and back in the mousepad will be active again. This is desired behavior for me as I occasionally need to be able to use the laptop without my external mouse.
When I get a little time, I will write a small shell script that can toggle it on or off based on a grep of the output of "xinput list" and bind it to a key combination so I can do this without having to drop out to a script. (EDIT NOTE: See post #15 in this thread if you want the scripts)
One last note, xinput interacts with X. It will not be able to function at a normal terminal screen not running under your X. It will work just fine in an xterminal (the one under accessories menu).
Hope this helps.
Posted on Feb 19, 2010
How do I get the pinch and zoom to work on Toshiba satelite
Open the "Control Panel" Then change from "Category" in the upper right of the screen to "Large icons". Then find the "Mouse" icon. From there you can change settings for everything related to your mouse.
Jul 23, 2014 | Toshiba Satellite Computers & Internet
My Eee PC notebook's special function keys and touch pad are not working
Have you tried a System Restore to a date before this issue? Have you done ANY updates?
Apr 13, 2013 | ASUS Eee PC 1005PE (SeaShell) Netbook
Im trying to turn on my touchpad via control panel but when i click the box to turn it on, it wont work
go to acer.com go to support and drivers and download the driver files for the touch pad again that should solve this issue. Follow instructions to the letter and off you should go again unless the touch pad is bad mechanically.
Make sure you input the correct laptop make and model when searching their files. The driver will be there.
John
May 19, 2012 | Computers & Internet
I was using to touch pad to browse ebay and the font got small. Tried to fix and it got even smaller! Ugg. When I go away from ebay the font is fine but every time I go there the font has stayed small. ...
You must have been using a multi-touch gesture on your laptop by mistake. You can resolve this in two ways:
  1. Just like zooming out on an iPod, place two fingers on the touch pad, and spread them away from each other OR
  2. In your web broswer - IE, Firefox, Chrome, Opera, etc. - press Control and 0 (thats the number zero) at the same time. This will bring you back to the standard 100% zoom.
Mar 26, 2011 | Computers & Internet
When I am using the internet to send emails sometimes when I move the cursor using the touch pad the text size ruduces and I can't get the size back to what it was
Its a special feature of laptops' touch pad that if u slide two finger(one horizontal and one vertical) simontaneously, it will zoom in or out... Try not to touch two fingers simontaneously on touch pad.... It also occurs with me... Thanks..
Feb 21, 2011 | Computers & Internet
Hello i have a Acer Laptop and when i was online it zoomed the site i was looking at to make it really big,but now it seems its locked when i try and move it out.When i touch the touch pad to try and zoom...
Zooms in and out while on internet? -- this is a "feature", and it happens because of your use of the TOUCHPAD. Resolved with a "pinch" on the pad -- making your fingers come together to zoom in, pinching fingers apart to zoom out (like an Iphone map application)
Aug 17, 2010 | Acer Aspire 5100 Notebook
Toshiba Laptop spontaneous font size change
Disable the dreadful "pinch-zoom" of the Snyaptics touch pad.
How it is supposed to be used is at
http://www.synaptics.com/solutions/technology/gestures/touchpad . However, I tried these "gestures" and none of it worked on my touchpad.
On Windows7, one can disable this poor excuse for a feature by going to Control Panel->Hardware and sound->Devices and printers->Mouse->Device Settings->Settings [button half-way down, on the right]->pinch zoom. Then uncheck "enable pinch zoom".
Aug 02, 2010 | Toshiba Computers & Internet
How do i turn off zoom function of synaptics touch pad Hp laptop
Are you talking about the two finger zoom by spreading your fingers apart on the touchpad to zoom out or pinching them together to zoom back in?
This works for Dell touch pads so below where it says ‘Dell touchpad’ it probably says HP touchpad?
· Goto your control panel
· Click on ‘Mouse’
· Click on the ‘Dell touchpad’ tab
· On the resultant popup screen, double click on the main touch pad region
· Click on the ‘gestures’ setting
· Uncheck the zoom
Good luck…Chris
Jan 16, 2010 | HP Pavilion Dv3-1075us Notebook
HTC Diamond questions
Its because of the touch sensitive navigation pad (the thing that has the up down left right enter/ok controls). The 'rim' or circle of the 4-way pad is touch sensitive and is used to zoom in and out in messages browser and pictures. If it zooms in and out by it self for a few seconds after a call, then its just lag from the multiple times it touched your face, or it could be a problem with the touch sensor (if it takes much longer), in which case you would have to get the phone replaced if its still under warranty, or to the store you bought it if you still can.
Mar 01, 2009 | HTC Touch Diamond Smartphone
ASUS Eee 4G Notebook Logo
866 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
