Wireless internet hookup - Computers & Internet
  • Anonymous May 02, 2009
    i have wireless internet at my house but when i take my laptop other places i cant connect to their wireless internet and it not because they have a password set or anything my computer just wont pick them up
    Novelist:
  • 156 Answers
Hi
I am try to take a stab at answering your query.
Internet Protocol (IP) Address preceeding with "169" means your PC is not receiving IP Address "generally" from your Boradband Modem or Internet Service Provider (ISP). The PC through Automatic Private Internet Protocol Addressing (APIPA) is assigning itself a temporal IP address.
This conditions means either
1. Dynamic Host Configuration Protocol (DHCP) Client service is not running properly on your PC (Unlikely)
2. There is no connection between your PC and Broadband Device or ISP wired or wirelessly (very likely)
3. DHCP Server Service is not configured or not running on Boardband device (likely) or ISP (unlikely)
4. Some firewall software when improperly configured are known to block all ports and services. This can block TCP Ports 67 and 68 used by DHCP Client/Server communication (quite likely)
Some pointers for more info;
1. Your query suggest your issues are limited to Wireless connection. Can you access Internet through wired connection? If so;
a) What Wired connection is in use? USB or Ethernet?
b) Is wired connection through same Broadband device?
c) What IP is assigned to your PC in wired connection?
d) If wired connection works, is IP assignment static or by DHCP?
e) What Boardband device is in use? In which mode is the device set to? Router/Bridge
2. If you can't connect both wired and wireless, then it is unlikely your PC hardware is at fault. Call your Broadband Provider for further help and configuration. Try entily disabling your firwall software (if installed) and test conection.
3. If you can connect through wired connection and your IP Address does not proceed with "192.168" or "172.16" then your boadband device is likely in a bridge mode. In bridge mode, the DHCP Server Service on your boardband device is disabled. Most ISPs will only assign only one IP address to a user. If an IP address has been assigned to your PC on the wired connection, then the wireless connection will not receive an IP address and therefore your PC will assign itself an IP in the range "169.254"
Regards
Mike
Posted on Mar 28, 2008
    Sergeant:
    Champion:
  • 329 Answers
What seems to be the problem of your wireless internet?
Posted on Mar 27, 2008
SOURCE:
Acer AX1920-UR20P computer will not connect with Internet, I have tried wireless and ethernet connections.
is modem in bridge mode? sounds like you try wireless first. the router would then do the dhcp to get you on the net I would hook modem to router to tower. you may also want to power cycle them.
Aug 11, 2015 | Acer Computers & Internet
Hookup internet wireless
Please check your system specs out very carefully. This particular system does not support nor include any wireless capabilities. To use the internet connectivity, you must run a CAT-5 Network cable from your router, to the network port on the back of the console!
http://images.owneriq.net/download/images/7/73fb106c-28a9-43af-83b1-656b4b895d5e-000001.png
Sep 07, 2011 | RCA RTB1100 Theater System
My sister is visiting and when we tried to put her laptop on my internet hookup the message was displayed stating that my internet connection through comcast was unsecured. What do I do to correct this...
its letting you know that your wireless network is open and not secured. she just needs to acknowledge it and she will be able to browse the internet but it is not secured.
if you want to secure your wireless network you will need to configure it by opening internet explorer
browse to http://192.168.1.1
the default login is blank and the password is admin
click on wireless
click on wireless security and choose wpa personal
enter a passphase which you will use to join your wireless network securely on any wireless device.
your sister will need to rejoin the network once you do this and you will need to rejoin any other wireless device to join your secured wireless network.
Apr 03, 2011 | Linksys Wireless-G WRT54G Router
Can't get online to play this new PS3. The console is hooked up to the TV & Belkin Wireless router. The internet, computer and phone line are in a different room and can't reach to hookup. AT&T is...
There should be no HDMI cable to router. In any situation.
Try the following:
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and choose the appropriate settings. (What's highlighted is going to be the best option, continue to hit the right button on the analog to go through the stages.)
Be sure to choose "Wireless" when configuring the settings if you are using wi fi for connectivity.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
What connections are needed to hookup the ps3 to the internet?
You can either hook up your PS3 through hard wire using an ethernet cable plugged into your PS3 and your modem or wireless since the PS3 has a built in wi - fi adapter for the wireless network in range.
May 12, 2010 | Sony Playstation 3 (PS3) Console
Have a computer with a new lynksis wireless-b router. i am running windows xp but dont have internet to the computer (minus the wireless) how can I install a driver with no cd or internet?
If you do not have the drivers on media, then you will have to obtain them first. Can you temporarily hookup wired and get them downloaded? or use a usb flash drive on another computer to access and download the drivers...
Apr 14, 2010 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
How do we get wireless hookup to PC in rural area no cable or DSL
You will have to use a wireless cell phone type of modem. Some hi end cell phones like, blackberry's and some blackjack's have this capibility, to be used as a computer internet modem, see your local cell phone co. This service will be a bit expensive.
Aug 31, 2009 | Compaq Presario 5000 PC Desktop
Any wireless pc card will work.
Jan 20, 2009 | Panasonic Toughbook 47 Notebook
Internet hookup
Hello, I see your wanting play online, Your xbox needs either a wireless lan adapter if wireless internet available, if not then yes you will need a internet cable, just be careful on which cable you buy, cause not all internet cables work with the X-box systems. Hope this helps and we look forward to hearing back from you.
Jan 16, 2009 | Microsoft Xbox 360 Console
Open Questions:
BULLGUARD Technical SuPporT pHONe {@}+18OO8O\=\31O69^%%= NUmbEr ddkkjj This BULLGUARD USA phone number is ranked #2 out of 2 because 7,728 BULLGUARD USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the BULLGUARD USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, BULLGUARD USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BULLGUARD USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact BULLGUARD USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BULLGUARD USA Calling BULLGUARD USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BULLGUARD USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BULLGUARD USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BULLGUARD USA's phone numbers against each other. Contacting BULLGUARD USA in General While I8OO8O31O69 is BULLGUARD USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BULLGUARD USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BULLGUARD USA.
Oct 17, 2019 | Best Computers & Internet
Computers & Internet Logo
292 people viewed this question
Ekse
Alun Cox
