Timer Replacement I have had a repair technician out who has quoted me over $175.00 to replace the timer. Our problem was that the washer ran fine to about 6 minutes left in the cycle and wouldn't go farthe in the cycle. When you adavance or run the timer control button around it sometimes will turn the washer cycle back on for a few to many seconds and then the motor turns off and there is a buzzing sound coming from the timer. I have found the part online for about $65.00 delivered and wanted to know how difficult the part is to change out as I may opt to do it myself. Also are ther any directions? I have unplugged the washer and have managed to disconnect the wiring harnes but can't see how and where to get the timer loose. There is a note on the timer about pressing in the control button and pulling out a black button 3/16" but I don't see what they are talking about. By the way I have checked out the lid switch and that does not seem to be connected to my problem. Thanks!
  • 1 more comment
  • udamangeorge Mar 28, 2008
    Whirlpool Gold #GSN2000HQ0
    Ultimate Care II
    Heavy-Duty Super Capacity Plus
    Imperial Series
    traded out the old timer for a new one and that's not the fix. every time I turn the control knob to any setting and try to start the washer it cuts off within 5 to 20 seconds and the timer just gives off a buzzing sound which goes away and everything shuts down within a few seconds
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Please post back with your manufacturer and complete model number. I need to know this as different makes and models come apart differently.
  • 5,911 Answers
There should be a pull tab on the back side of the timer that you pull to release the timer knob. Most parts come with directions on how to install. I hope this helps you.
Posted on Mar 28, 2008
  • Jeff Rockwell
    Jeff Rockwell Jun 10, 2008
    You asked me how to get the timer knob off the washer, NOT if the the timer was the problem. You did not provide any elaboration on what led you to the conclusion that the timer was defective, and you didn't request to troubleshoot any further. I feel your "Thanks for Trying" rating is a bit unjustified.
SOURCE:
My machine stops in both (arrowed)positions but I only have to move knob one click then all is ok.can this be fixed Thanks Kevin
it this is a timer unit that clicks as you rotate the knob, the problem is in the contacts and the fix is a replacement timer control
get a quote first as the whirlpool/ westinghouse / simpson/hoover aeg ( all electrolux makes ) timer is in the vicinity of $150.00 plus AUD
best have a technician check it out properly and quote the price
Jan 21, 2016 | Washing Machines
How to diagnose washer timer not turning?
Good Afternoon Friend,
I understand that the washer timer on your Frigidaire laundry center, model# GLEH1642DS, stopped turning and you want to know how you can diagnose this. Typically, this is not be a do it yourself repair, as there are no step by step repair instructions. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose it and determine what is causing the timer button to not turn. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire GLEH1642DS Front Load Stacked...
How do you replace the timer on a frigidaire frontload washer
Good Morning Friend,
I understand you are trying to replace the timer on your Frigidaire Affinity washer, model# ATF7000E. If it is just the selector knob you are replacing, you should only have to snap the new knob on. If it is anything other than the selector knob, typically it is not a do it yourself repair. I do suggest contacting your local authorized technician for further assistance. They have been trained on your specific appliance, and will be able to better assist, and replace the timer on your washer. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire Affinity ATF7000E Front Load...
My Kenmore 11020022012 washer stops prior to spinning cycle. If I manually turn the dial to spin, it will spin fine. Need help troubleshooting..
timer needs new electric motor to advance from rinse to spin cycle.
or alternately ,you can have your old timer taken out of your washer and sent out to be rebuilt or buy a new timer.
in any case , you will need a kenmore washing machine repairman to take out your old timer and send it away to be rebuilt and expect that to take 2 or 3 weeks
the timer rebuild used to cost$ 50.00 in 1993 and a new timer went for $110.00 to $129.00
for a sevice man to take out and reinstall a timer $60.00 to 100.00 labor
try to google.com or bing.com or ask.com-----and type in : kenmore washing machine,rebuilt timer. you will need the model number of the washer as well as the model number of the timer and the timer may have a different name that kenmore
also try typing in kenmore washer,new replacement timer
try call sears and see how much their service man wants to put in a new timer. I am sure prices have gone up since 1993
when I retired from the major appliance repair busness. i could do the timer remove & install, but I probably live 1000 miles from you.
another option: knowing that you will need to spend around $200.00 or more by the time you get a new timer installed
you might want to see how much lowes or home depot wants for their cheapest bottom of the line washer. that might be a good alternative as it allows you to get a new washer and buy an extended warantee so you dont get stuck with another 200.00 repair. I think they have washers starting at 289.95 only 90.00 morte that repairing your old washer which is going to run for how many more years before it again gives you trouble?
check out lowest prices on bottom of the line washers unelse you want to spend a lot on a fancy washer to make yourself happy.
you can shop on line by just google.com or bing.com and the name of the store. home depot, lowes, sears,walmart
and type in clothes washers.
Oct 08, 2013 | Kenmore Washing Machines
I want to replace a timer on a Whirlpool washer Model# LSN1000KQW
Good day Mr.james dant..
Whirlpool manufactures many types of washing machines. Whirlpool's top load models rely on an analog timer that controls the cycle used to wash the clothes in the washing machine, rather than a digital control board found in most front load models. The timer contains a number of moving parts and is physically turned to choose the wash cycle. Because of the high usage of the timer, it will eventually break, requiring replacement. Rather than calling a service technician to repair the timer, replace the timer yourself to save both time and money.
Instructions
1. Unplug the washing machine from the wall outlet
2. Turn the dial to the "Off" position and then unscrew the knob from the timer. To unscrew, hold the dial with one hand and turn the knob counter-clockwise.
3. Lift the dial off of the washing machine.
4. Remove the two mounting screws securing the timer into position. 5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
6. Remove the wire harness from the old timer and remove the old timer
7. Connect the wire harness to the new timer.
8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
9. Place the dial back onto the timer post and then screw the knob onto the post.
10. Plug the washer back into the wall outlet
Try to watch this video:
Nov 25, 2011 | Washing Machines
Kenmore 300 washing machine does not leave rinse cycle
This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Switch on washer stops at rinse. I have to twist to spin for it to spin. What might be the problem
It would appear that your timer is faulty and needs to be replaced.
Typically when a timer starts to wear out, over time, the plastic steps that are part of the timing sequence can wear down and cause the washer to malfunction.
If you can hear the time motor running but it doesn't ever go into the rinse cycle, then it is most likely the timer motor that is the issue.
If you want to get an idea of the cost for obtaining a replacement timer, you can go to www.searspartsdirect.com and enter in your complete washer model number into their parts search and then select the "control" link to see a line drawing and parts list for your washer.
Since you didn't provide a model number for your washer, I'll give you the generic instructions for doing the replacement. Again, with the sears link above, you'll be able to see the location and mounting method of the timer on your washer.
This is an easy repair for anyone to undertake, just be sure to unplug the washer from the power outlet before you attempt it. First, remove the timer knob from the front of the washer simply by pulling it straight off. then with either a socket wrench or nut driver, remove the nut and lock washer that holds the timer onto the panel.
Now remove the screws on the backside of the control panel so you can get at the timer. remove any mounting screws/hardware that holds the timer on the panel. Once you've done that, you can just unplug the wiring harness from the faulty timer and plug it into the new one. Now just remount the timer, put the back panel cover back on and fasten the timer shaft with the lock washer and nut, put the timer knob back on and give it a try.
That should get your washer back working properly. I hope you find this Very Helpful and best regards!
Sep 23, 2009 | Maytag Washing Machines
GE WASHER, REPLACED TIMER THEN BIG SMOKE
Be sure you are using the EXACT replacement part. The wiring may be different if it is a "close" match.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 20, 2009 | Washing Machines
Washing Machines Logo
435 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
