Question about Samsung CLP 300 Laser Printer
Hi... Where does the spring go on the yellow cartridge? it just popped out and I don't know how to re-install it
    President:
  • 670 Answers
It sits above the yellow cartridge. There is a plastic nib where it is seated. If look on my Tips section, I have a picture to show you where it goes.
Posted on May 11, 2010
How can i change the headlight bulb,dont know how to remove the lamp
These have the cartridge type bulbs...you need to pop the hood and look at the area where the headlight are...there will be a retainer that you need to turn ccw to allow you to remove the cartridge assembly, then when you replace the cartridge, be sure to seat it in the housing properly(it goes in only 1 way) and then replace the retainer....some parts stores may be able to help you in installing the assembly(especially if you purchase the bulbs there)
Feb 05, 2011 | 2001 Chevrolet Blazer
HP 1050c....Hi, i am getting error on display for
Are you using HP factory new cartridges or some third party cartridges or even wores a refilled cartridge?
80% of the time, that's the cause of the failure.
Don
Feb 24, 2010 | HP DesignJet 1050c plus InkJet Printer
Canon Pixma MP600 - Error Message U052 ... incorrect print head
Hi, sounds like you need new printhead, take a look on amazon for replacement Amazon com canon mp600 printhead I hope this was helpful. Cheers
Nov 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon iP4200 thinks it has two yellow ink catridges installed
I have had this happen a couple of times to me with a few cartridges so if you can be sure it's just the black that has changed then I'd contact your retailer and request a replacement under warranty.
The only other way to solve this is by process of elimination using some other cartridges. If you know of someone else with a similar printer model that uses the same cartridges then perhaps ask nicely :)
Feb 13, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
hi,
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
RE: Installing rainbow E series water pan latch
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=652000
Posted by bettyannsoto on Jun 06, 2008
Need to know how to install rainbow water pan latch and spring latch
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow latch can be replaced but I believe it is a pop rivet that holds and replaces the old latch and to replace the new latch, I have seen it done but if you don’t have the right tools you may want to contact your local vacuum cleaner dealer in your area, it can be done. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Cartridge error
remove the cartridge & install the new one cartridge other wise
May 10, 2008 | HP Photosmart C5180 All-In-One InkJet...
Changing printer cartridge
hi, if you have put a new cartridge it has a protection tape stuck on the nozzel, we have to remove it before installing it.the yellow light indicates no or bad cartridge, may be this should solve the problem.. let me know..
Nov 15, 2007 | HP DeskJet 5150 InkJet Printer
Blank paper print always
Hi sema, For this type of problem the first suspect is the toner cartridge: -Make sure it?s seated properly. - Look for the electrical contacts that connect to the toner cartridge. When you find them make sure the spring contacts on the printer are connecting to the cartridge and that they are clean. -Try installing a brand new, preferably genuine (not a refill) Canon cartridge. If none of this works then the next steps involve disassembly. If you are comfortable with this you can try: -testing all connectors to make sure they are plugged in and oriented correctly -check all wires (for damage) and secure connections -If you don?t turn anything up here then you are better off going to an authorized repair shop. Otherwise you?ll wind up buying parts to test with and guessing like that gets expensive unless you luck out and guess right the first time. Let us know how it goes and please don?t forget to rate the posting.
Jan 05, 2007 | HP LaserJet 1300 Printer
Samsung CLP 300 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
