Question about Acer Aspire One PC Notebook
Why do i have to reboot 4 or 5 times to get it to work?
Why do i have to reboot 4 or 5 times to get it working?...why does it freeze every startup?
  • Uvex0_0 May 11, 2010
    freeze@hang after start up logo or when try to load windows? Hang may cause by Hard disk or windows.
  • Abdulhakim
    Abdulhakim May 11, 2010
    Where does the freeze happen is it after windows login or after system boot?
    Prodigy:
    An expert who has answered 500 questions.
  • 674 Answers
Fix this problem by:
-- cleaning system junk
-- optimizing computer services
-- optimizing internet
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
Posted on Jul 13, 2011
    Novelist:
  • 76 Answers
Hi ,
There is a startup program that has gone corrupt and is making the computer freeze to correct this problem here are the steps that you can follow.
Turn the computer off and then as soon as you turn it on start tapping the f8 key until you get a black screen that says advance boot menu ,select plain safe mode and then hit the enter key.Then when you get the log on screen select administrator ,it should take you to the desktop and please check if the screen freezes or not if it doesn't then go to start?run ?type msconfig?enter?select startup tab ?click on disable all ?apply?then go to services tab?click disable all ?apply ?ok or close to exit from the page and then it will prompt you to restart the computer .When it boots up to the normal mode check if the computer freezes or not if not then we will have to find the program that is making the computer freeze.To do that first enable all the strartup items restart the computer and check if it freezes if it doesn't then there has to be a program under services that is causing the problem so need to go to the system configuration utility page and then you need to go to services tab and then check one no more program's restart and then check if it freezes or not .So this way you will have to isolate and find the find the program that causes the computer to freeze and once u have found it check all other program's except the one that causes the computer to freeze.
It can also be that an external device is causing the computer to freeze so if you have any external device connected like a usb .printer etc and also check if there is any disk in the drive.So disconect all th external devices and check if the computer does not freeze then connect one device at a time and check which external deivice makes the computer freeze.
Hope this post helps you ......All the best
Posted on May 09, 2010
This is probably done to the bios on start up you will need to load new bios when you get connected
2 Suggested Answers
JackHeath
  • 1049 Answers
SOURCE: why do i have to reboot 4 or 5 times to get it to work?
Typically indicates bad or failing RAM.
Posted on Mar 26, 2010
My hp xp pc 2005 media center edition freezes up the only thing that works when it freezes every time this pc it freezes the c a d buttons do not help could you help ?
seems like an issue of junk files and infection in the computer.
remove the unwanted programs
clean the startup from msconfig (expert advised)
clean the junk, prefetch, temp, etc
clean the registry
update the version.
reboot and see if it works.
if this does not help, then call 1-877-805-1027 for expert help
Aug 06, 2015 | Microsoft Computers & Internet
Hi, I need help, my pc freezes and I cant move the mouse or do anything else, I have to restart it. Please Help me.
Start/Run... Run msconfig. On General tab, select Diagnostic Startup. Reboot. Use the computer in this state for as long as the freeze usually appears.
If no freeze, return to msconfig General tab. Selective startup, uncheck Startup.
Repeat reboot and trial usage. If no freeze, check normal startup. On startup tab uncheck everything that looks non-essential. Reboot and retest. When the computer seems "fixed" recheck one startup item at a time. Repeat your timed test until the issue reappears. When it does, the latest startup item you enabled is the cause.
Oct 16, 2012 | ASUS P5VD2-X Motherboard
Television turns off then reboots by itself
It sounds that the memory IC to your TV has some fault with it. Seek tech support.
May 29, 2012 | Curtis-Mathis Televison & Video
Averatec 3200 PC Notebook freezes at startup but
I suspect one of your startup items to be causing this problem. I suggest you to disable the startup items in safe mode and then try booting in normal mode.
Since you have already tried in safe mode i believe you know how to get in there so lets start from second part on how to disable the start up items.
Step1: Click on start and then click on Run.
Step 2: Type msconfig and hit ENTER.
Step 3: Click on Startup tab.
Step 4: Click on Disable all then click on apply and then Click on OK.
Step 5: Your system will be prompted for a reboot. Go ahead and restart it.
Step 6: As soon as the system is backup you would get system configuration utility screen where in you should check "Don't show this message again".
If you are curious to know which start up item is causing this problem then you might want to try enabling few at a time and narrow down.
Jan 15, 2011 | Averatec 3200 Notebook
Startup is normal, then while working for about 5 minutes, it freezes. reboot and it does the same thing again.
here is something that might do the trick, Compaq use a quirky set of motherboards, and they akk seem to have this problem sooner or later
1) unplug everything from the computer except for the keyboard, mouse, and screen
2) unplug the power cord
3) wait 30 seconds, then hold in the power button for another 15 seconds
4) plug computer back in and reboot system
if it works then you're good to go.
if not, then there is a resource conflict which is sendinga fault code to the OS, causing a reboot
if you recently installed any hardware, ur USB adapters, that could be the cause
also, sometimes does this if print and file sharing is turned on
Dec 16, 2010 | HP Compaq nc6220 Notebook
After the windows logo on start up it freezes
Try to start up in Safe mode - usually by pressing F8 continuously during start up.
If that works - run any antivirus, malware and registry cleaning programs you have. If you don't have any - you can reboot in safe mode with networking and download some - irecommend malwarebytes amongst others.
If still a problem - it is possible a driver/service error - gor to MSCONFIG /STARTUP - disable all the start up programs. Try to reboot - if ok - enable startup programs one at a time to isolate the bad one. Uninstall that program. Once everything is working ok - you could try reinstalling again. Check for updates.
Hope this helps
Aug 31, 2009 | Acer Aspire 9410 Notebook
Bios screen freezes at startup
go to bios/set up and check in advanced set up and select the first boot device as HDD 0 or HDD 1 (hard disk 0 or 1) and also you need to see that the hard disk is seen in the bios, save and qite. if it is the same reinstall the operating system
May 23, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Freezes up at 3/4 boot 90% time
when u power up the computer press
F8 key then enter in safe mode.then tpye in run"chkdsk /r"
then press "y"
then restart the system.then it fixes error on harddisk.scan your computer with latest updates antivirus.
Jan 05, 2009 | Computers & Internet
Every time i boot up my acer aspire 5315 laptop I always get a black screen and the computer freezes?
Please try to reboot in Safe mode after Tapping F8 Key during start.
If the option for run in safe mode not appear you need to do it again.
After then, when you login at desktop, do the following:
  1. Click on Start
  2. Open the Run window,
  3. Type msconfig, then click 'OK'.
  4. Go to the Services tab, find the 'Background Intelligent Transfer' service.
  5. Disable it, apply the changes & reboot.
Also at startup tab in msconfig, and in the Startup Tab
Disable the items which you think not necessary to come during startup.
THis will help you lot to reduce the time being taken in Startup.
Hope it will work for you.
Oct 14, 2008 | Computers & Internet
Acer Aspire One  PC Notebook Logo
170 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
