Question about Averatec 3200 Notebook
Internet hookup Trying to hookup to wireless internet without success. Comcast tech tells me probelm with an IP# 169 which preceeds all other numbers and needs to be removed. Suggest I contact maunfacturer which is what I thought this site was. Can you help?
  • myascj Apr 27, 2008
    having problems to connect to nternet with my wifi.
  • lifer6529 May 03, 2008
    I have 3300 Averatec Laptop. I downloaded a utility program and all of a sudden i can access the wireless internet. It shows that im acquiring signal with my provider. IP add shows 0.0.0.0 when i tyoed the ipconfig on the black box. My proviser says theres nothing wrong withmy modem and shows that something in the pc is kicking back the signal. I cant system restore because the the program i downloaded delted it too.
    Can anyone please help resolve my issue.
    Novelist:
  • 156 Answers
Hi
I am try to take a stab at answering your query.
Internet Protocol (IP) Address preceeding with "169" means your PC is not receiving IP Address "generally" from your Boradband Modem or Internet Service Provider (ISP). The PC through Automatic Private Internet Protocol Addressing (APIPA) is assigning itself a temporal IP address.
This conditions means either
1. Dynamic Host Configuration Protocol (DHCP) Client service is not running properly on your PC (Unlikely)
2. There is no connection between your PC and Broadband Device or ISP wired or wirelessly (very likely)
3. DHCP Server Service is not configured or not running on Boardband device (likely) or ISP (unlikely)
4. Some firewall software when improperly configured are known to block all ports and services. This can block TCP Ports 67 and 68 used by DHCP Client/Server communication (quite likely)
Some pointers for more info;
1. Your query suggest your issues are limited to Wireless connection. Can you access Internet through wired connection? If so;
a) What Wired connection is in use? USB or Ethernet?
b) Is wired connection through same Broadband device?
c) What IP is assigned to your PC in wired connection?
d) If wired connection works, is IP assignment static or by DHCP?
e) What Boardband device is in use? In which mode is the device set to? Router/Bridge
2. If you can't connect both wired and wireless, then it is unlikely your PC hardware is at fault. Call your Broadband Provider for further help and configuration. Try entily disabling your firwall software (if installed) and test conection.
3. If you can connect through wired connection and your IP Address does not proceed with "192.168" or "172.16" then your boadband device is likely in a bridge mode. In bridge mode, the DHCP Server Service on your boardband device is disabled. Most ISPs will only assign only one IP address to a user. If an IP address has been assigned to your PC on the wired connection, then the wireless connection will not receive an IP address and therefore your PC will assign itself an IP in the range "169.254"
Regards
Mike
Posted on Mar 28, 2008
  • 242 Answers
This is not the manufacturer's site, but i will try to help.
Is it your own network?
You need to make sure that the network is not protected, or you'll need the password.
Go to Start>Control Panel on your computer
Then go to Network Connections
There should be an icon for your wireless connection.
Right-click -> select Properties
In the selectbox select 'Internet Protocol (TCP/IP)'
Click Properties
Check if 'Obtain an IP-address automatically' and 'Obtain DNS-server' are selected
If they were not, Press <Ok> two times and try to connect to the wireless network again.
Can you also tell what IP-address you get?
Find it by going to Start > Run
Type 'cmd' without the quotation marks and press <Ok>
you get a black command box
type 'ipconfig', again without the quotation marks and press <Enter>
Please tell me the IP-address it tells you...
Posted on Mar 27, 2008
I am trying to connect my tablet to xfinty
You have to connect the tablet to your Arris 862 gateway "comcast modem" the key to your wireless is on the bottom of the modem on white sticker. The key is case sensitive most generally all in caps. Your network name is as well on the sticker should be HOME- and a 4 digit number. To get the tablet to connect you need go into "settings" on the tablet and then tap "wireless or may say WIFI", Find the comcast modem/router name "the Home- whatever number it is click it then it should prompt you to type in the network key.
Mar 22, 2015 | Internet Computers & Internet
Need Help with new Wireless Router
more info needed.
Are you on cable or dsl? Can you access the router set-up screen? Can you ping the router from the computer? Whose tech support did you call? Are you using wireless or ethernet connection to router? Can you access the net if you hookup using a ethernet cable? What OS are you using?
You migh try disconnecting the modem line for a few minutes and then reconnecting it to reset the IP address your ISP gives you. If you were using the net successfully without the router, you may want to clone your computer's MAC to the router (DSL).
May 13, 2008 | Computers & Internet
Hook up wireless interenet
Did you by any chance give you router the mac address on the wireless card? Do you have the comcast version of a netgear wireless router? Any wireless router will do also. Does not have to be netgear or from comcast. You can get online by the network cable right?. Where else are you trying to connect to wirelessly?
Let me know
comier957
Mar 27, 2008 | Averatec 3150H Notebook
Wireless internet hookup
What seems to be the problem of your wireless internet?
Mar 27, 2008 | Computers & Internet
Laptop (Averatec Model #3150
Hi
Regards
Mike
Trying to hook up lap top to wireless internet. Comcast tech says there is problem with IP# 169 which preceeds other numbers and needs to be removed for hookup. How can I accomplish this? Model #3150H
Usually you will have an IP address starting with 169 if the adapter cannot get an ip address from anywhere, it is an autmoatic IP address.
What operating system (Windows XP or 2000 or Vista) are you using?
P1i problem with my Wlan
if you are using the winxp operating system try to run the network wizard from the control panel
Jan 24, 2008 | Sony Ericsson P1i
Linksys router befw11s4
The easiest way to sort it is to enter your routers settings page in your internet browser or desktop icon and make sure you enable DHCP which will give your pc an automatic ip address. Make sure WEP or similair is off until the set up is sorted out. Next go to your properties of your wireless adapter(Card) and go to internet TCP/IP and click properties and make sur 'Obtain IP address automatically is ticked. No click Start, then Run then type:- ipconfig /flushdns then press enter.(note the gap between ipconfig and the /). Restart your pc and router and try connecting again
Jan 31, 2007 | Linksys (WMP54GS) 802.11g/b Wireless...
Averatec 3200 Notebook Logo
134 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
