Question about Samsung Avantalk Wireless Bluetooth Visor Handsfree Speakerphone Car Kit for Blackjack II SGH-i617, Blackjack SGH-i607 Smartphone
Why does my avantalk btck 20 flash blue? if it flashes red that means it needs to be charged but why does it continually flash blue around every 3 seconds once I have it on? Looking forward to hearing a response. Eimear. Ireland.
2 Suggested Answers
  • 95 Answers
SOURCE: Why does my avantalk BTCK 20 flash blue?
The bluetooth suppose to be a signal, and the posibility like the phone to activate it will often precising by the way that the bluetooth is running or working. For me, it is logic!
Posted on Mar 29, 2010
Why have I got a red light on the bottom of my shaver when I am using it
It is common for many Braun shavers, that if the indicator light flashes red while the shaver is being used (switched on and running), it means the battery is low and needs to be charged soon.
Below is an example from a manual for a Braun model 7526 shaver. You can search that site for other manuals if this is not the correct one.
This model shaver has 3 indicator lights:
1) Green (Charging)
2) Red (Low battery)
3) Blue (Power cord attached and plugged into the wall)
Download the manual for the model 7526 here: http://www.manualslib.com/manual/20281/Braun-5301.html#manual
"The green charging light shows that the
shaver is being charged. When the rechargeable
battery is fully charged, the charging light
flashes or goes off.
If later on, the charging light comes on
again, this indicates that the shaver is
being recharged to maintain its full
capacity.
The red low-charge light flashes when the
battery capacity has dropped below 20%,
provided the shaver is switched on. The
remaining capacity will then be sufficient
for 2 to 3 shaves."
Nov 09, 2015 | Braun Health & Beauty
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Btck-18n not charging
change your battery
Nov 04, 2012 | Cell Phones
I found my son's plantronics 220. Been in storage a year! I have it charging now. the light is red and ever so often it flashes a blue color for a instant. Is it still good?
Normally the flashing red / blue light indicates the headset is in pairing mode. The red light indicates it's charging but the occasional instant blue is a mystery. The user guide below has the instructions for turning the headset on and off, and pairing to a phone. I would suggest you charge it up, follow the pairing instructions and see what comes up.
http://www.plantronics.com/us/media/media-resources/literature/user_guides/Explorer220_userguide_en_us.pdf?WT.dl=20
Good luck from Headsets Direct - 800-914-7996.
Aug 19, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My avantalk btck 10b wont connect to my blackberry curve
Had the same problem. It all looked OK and it found the Avantalk, but it would not 'pair' and kept failing. I decided the problem was probably with the Avantalk unit and wondered if I had paired it with too many other phones so decided to do a 'reset' on it. This is achieved with the Avantalk turned 'on-standby', with the two blue flashes every few seconds. Press and hold the up and down volume buttons for more than 5 seconds, at which point the red and blue lights will flash on and off 5 times very quickly. The unit should then return to its 'on-standby' state again. Switch it off (larger MFB phone button), then on again and then set it into pairing mode (immediately after the Avantalk has come on, press and hold the MFB button again until the red and blue lights are flashing), then go through the searching blue-tooth device and so on again with you phone. It should all work now.
Cheers... Rob.
Oct 15, 2010 | Cell Phones
My new avantalk btck-12c mic.does not pickup my voice is there an adjustment ?
I have a avantalk btck12c car kit buy it calls the wrong number . Do I have to put my contacts into my speakerphone My phone is a iphone3g
May 15, 2010 | Pantech Avantalk Wireless Bluetooth Visor...
Why does my avantalk BTCK 20 flash blue? if it flashes red that means it needs to be charged but why does it continually flash blue around every 3 seconds once I have it on? Looking forward to hearing a...
Mar 25, 2010 | Samsung Avantalk Wireless Bluetooth Visor...
Battery flashing when charging why?
If the red light is flashing after inserting a NP-20 battery in the Casio Lithium Charger BC11-L, it means that the battery will not take a charge. Normally when putting the batterry in the charger, the light will be a constant red. After charging is complete, the red light will go out. Battery is then fully charged and ready for use.
Mar 19, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
I Can`t switch my headset on, and it stops charging after 20 secs
Move the call control button up or down, the indicator light will flash blue if it's paired or blue and red. If it flashes blue and red you need to pair phone with the headset. the passkey is 0000.
Jun 17, 2009 | Plantronics Explorer 340 Wireless Headset
Activate pairing mode
Holding down the multifunction button for eight seconds puts the unit in pairing mode and an LED lets you know the status of the headset. Flashing blue and red means the H4 is in pairing mode, flashing blue means it is paired and flashing red means the H4 needs charging.
Aug 10, 2008 | Cell Phones
Samsung Avantalk Wireless Bluetooth Visor Handsfree Speakerphone Car Kit for  Blackjack II SGH-i617, Blackjack SGH-i607 Smartphone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
