Sharp copier, not producing clean copies
Model AL1045 Sheets of paper are coming out with two vertical sections on the a4 portrait of smudged printing. It looks like the roller? has got some of the words imprinted on it still and they have been faintly re produced on the copy
  • 1,110 Answers
Could be the fusing unit (part that gets hot) but most likely cause based on your description is the drum unit. Easy to check by simply removing your toner cartridge, then removing the drum cartridge which sits right next to the toner cartridge. After removing the drum cartridge, turn it over and look at the colored cylinder. This is the drum. It should be clean. If your problem is in the drum unit you will see the same 2 "bands" of toner are something on the drum surface. If this is the case, it means the drum cleaning blade is going bad. Just order in a new drum unit and this will fix the copy quality problem.
Good Luck and Thank You for using Fixya.
Posted on May 09, 2010
Copier prints page out in landscape not portrait
Check your paper tray settings under system settings/paper tray settings. You can also try turning off auto image.
Jul 20, 2012 | Sharp AR-M257 Black and White Copier
Windows 7HP and Epsom BX300F can scan but preview shows that, one a4 sheet is split into 4 or 5 random areas and will print those areas only on 4 or 5 seoerate sheets of A4. How do I change this so that...
Goto -> Printer's Property/ Prefrences 1 - "Layout" Tab -> Select Portrait in Orientation section. 2 - "setting" Tab -> Select A4 in Paper Size DropDown. 3 - Click OK and try.
Feb 16, 2011 | Office Equipment & Supplies
While copying a written document in A4 size paper vertically, the copy is coming horizontally and it does not copy the entire page. Even the problem occurs when the paper being copied is kept...
I would look at the paper in the paper tray to make sure the paper is going in the same direction that you wont & make sure that the paper tray is set to the correct paper size. You did not give a model, so I don't know how you input the paper size. But if the image is being cut off, one of the two things I suggested will solve the problem.
Sep 16, 2010 | Canon Office Equipment & Supplies
Printed documents have a vertical smudge
if paper goes through the device in portrait or A4, check fuser entry guide. if page travels through the device landscape or A4R look for obstructions that could disturb toner on the surface after drum but before fuser
Mar 29, 2010 | Office Equipment & Supplies
Check the fuser roller if it still has faint prints on the roller then your getting a shadow image in your prints,. Could be a bad fuser roller replace it
Mar 24, 2010 | Sharp Office Equipment & Supplies
Smudges on paper and then when it does copy, ink is light.
hi,check copy cartridge or clean corotron wire.try to increase toner.send me result.
thank you.
May 25, 2009 | Sharp AR-5320 Black and White Copier
Canonimageclass D320 makes smudged copies. What do I do?
This model is noted for a jam in the fuser area around the roller, Not easy to get to but sounds a like that may be proble, Can you hear a sound like paper wrinking as it runs. Also is the drum in the cartridge clean or has tone on it. Have you changed the cartridge. I do get a kick out of Staples Experts.. They did sell you some cleaning sheets... Hey Good Luck....
Apr 23, 2009 | Canon imageCLASS D320 Digital Copier
I want copy from A3 (2*A4 pages) to A4 (landscape)
While coping A3 paper it result in A4 portrait not in landscape which is incomplete.How to manage it?
Feb 19, 2009 | Canon iR 2016i Black and White Copier
44 people viewed this question
jasbo
jasbo
