Question about Pool & Spa
Flame coming back up venturi - Pool & Spa
  • 198 Answers
Check for a blockage in the lines---sometimes spiders will build a cocoon in the tubes.
Posted on May 10, 2010
Yellow flame how do you adjust it to a normal blue/yellow tip flame
You need to introduce more air to the flame. There is an adjustment near the venturi which is just past the control knob. This is a job best left to a gas fitter who will also adjust minimum flame height at the same time. Quick job, less than an hour.
Oct 29, 2015 | Kitchen Ranges
Low flame on one side
If your grill is older and has seen several seasons check for obstructions elsewhere the venturi is only one place for problems, check for hose kinks loose connections. If this is in a cold weather area, it maybe just low pressure. Also look for collected/ponded water in the burner tubes, especially if the flames are yellow.
Jan 13, 2013 | Broilmaster Premium P4 Grill
When I try to start the propane grill (Ducane)by pushing the knob and turn to hi, it creates a spark and from the "pilot" there is a big flame straight up, I hear and can smell the gas , but that...
It sounds like something got disconnected between your gas line and your venturi (which deliver gas to your burners. Take out the grills and whatever holds your rocks or ceramic briquettes and look at the connection where the flame is coming from. It may be obvious what has come apart, and the fix may be as simple as pushing it back together.
Jul 15, 2017 | Ducane 30400042 (LP)
Full tank, very low flow/flame, how do I clean venturi, if this is the problem. Unable tp remove V-shaped tent over burners
I suspect that your problem is related to the grill's regulator. But, there is a solution. Turn the gas tank valve OFF and the burners to high for one minute, then turn them OFF. Also, disconnect the hose from the tank and wait 5 minutes, After 5 minutes, reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, turn ON and light the burner farthest from the tank, first. Has the flame height returned to normal? If so, light the remaining burners the same way. Now, do all the flame heights look normal? If so, you solved the problem.
If it didn't solve the problem, you will need to replace the grill's hose/regulator assembly. You can get one at any home center or hardware store that sells gas grills and accessories. Take your old one with you, for comparison purposes.
The V-shaped Tent (also called a Flame Tamer) should just lift up and out. According to your Owners Manual, they are not attached in any way, They just sit there, Once they are out of the way, you can access and remove the burners for cleaning. The Venturi is part of the burner, where it fits over the burner orifice. It will have a slotted opening. It mixes the gas to air, so that you get an even, clean burning flame. Spiders love to build nest in them. An old toothbrush works well in cleaning the Venturi's .
Hope all this info was of some help to you and will get you back grilling real soon. Please let me know. Thanks.
May 17, 2011 | Sunbeam Grill Series 760
The venturi is open to wide. If you have thre manual it should explain how to make the adjustments. If not, adjust so air intake (slot on bottom half of valve) is smaller.
Mar 23, 2010 | Garden
I have a goodman gmp100-4 gas furnace and the gas comes on but shuts off in around 30 seconds, then tries again and the same thing... can i get some help please?
On the last gas venturi tube there should be a flame sensor located in the flame to prove it exsists, if its coroded the spark can,t jump back thru the moisture molecues in the gas to prove it has a flame to tell the circuit board to keep the gas comming. Just reomve the flame snsor and sand itand replace itback. T. Y. V. M.!
Dec 01, 2009 | Goodman GMS90703BXA Heater
Oven flame too high.
Take a 1/2 inch open end wrench and tighten the orifice on the oven gas valve. Then adjust the air shutter on the venturi tube.
Mar 18, 2009 | Frigidaire FGFL79GC Stainless Steel...
Gas grill prob.
Barbecue Repair Parts Don't let spiders crawl into your venturis, yearly maintenance part are available. 27897.jpg?qlt=80&cell=325,325&cvt=jpeg If you notice that your Barbecue is getting hard to light or that the flame isn't as strong as it should be, take the time to check and clean the VENTURIS. 27898.jpg?qlt=80&cell=325,325&cvt=jpeg In some areas of the country, spiders or small inserts have been known to create "flashback" problems. The spiders spin webs, build nests, and lay eggs in the BARBECUE VENTURI TUBE (s)obstructing the flow of gas to the BURNER. The backed-up gas can ignite in the venturis behind the control panel. This is known as a flashback, and it can damage your Barbecue and even cause injury. To prevent flashbacks and ensure good performance the BARBECUE BURNER and VENTURI assembly should be removed from the grill and cleaned before use whenever the BARBECUE has been idle for an extended period of time.
Also, when you lite the BBQ, make sure that you turn the gas on at the tank, wait a couple of minutes and then turn the knob on and light the burner. This is to make sure that the pressure is regulated and sufficient prior to lighting.
Hope this helps!
Sep 01, 2008 | Grilling
Bunners do not get hot
Hope this helps!
Apr 20, 2008 | Coleman LG40811E Grill
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
