Question about Lexmark Z640 InkJet Printer
The printer seems to be printing, but there is no
The printer seems to be printing but there is no ink on the paper . Both cartridges are nearly full however the printer hasn't been used in months. I used a wet tissue to get the ink flowing but it didn't solve the problem.
  • 4,041 Answers
Hi There
Right if not been used for months then yes the ink heads needs a good clean as they will be dry and blocked, and you may need to buy new inks.
Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on May 09, 2010
Ink waste absorber is nearly full. What do I do?
You need to reset it.
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full
You need Mptool to reset your mp170
download mptool here
Manual guide to use mptool
download manual guide here
Jul 09, 2010 | Canon PIXMA MP170 All-In-One InkJet...
The printer seems to be printing, but there is no ink on the paper . Both cartridges are nearly full, however, the printer hasn't been used in months. I used a wet tissue to get the ink flowing, but it...
Hello. Since, you have already used a wet tissue to clean the nozzles, how about reseating the cartridges. Remove both cartridges from the printer. Unplug the printer from the power source. Plug the power back in after 10-15 seconds. Re-insert the cartridges. If it still won't work, cartridges may have worn out already because of non-usage. Maybe it's time to buy new ones now. Hope I could help you more on this.
Mar 20, 2010 | Lexmark Z640 InkJet Printer
Kodak ESP3 not printing
Don't have a solution but can confirm this printer seems to be full of bugs. I have reinstalled software twice which gets the printer going for a very short time only. It does not recognise the Kodak ink cartridges..! Very frustrating.
Feb 27, 2010 | Kodak ESP 5 Printer
U053 error code,tried removing and replacing cartridges, but code still present,cartridges are compatible as come with printer.
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the printer cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
Dec 27, 2009 | Canon Office Equipment & Supplies
Error Message U053
Error messages displayed on the LCD and how to handle them
When an error has occurred in the printer, the error / check message is displayed on the LCD.
Take the appropriate action to return to the normal condition.
Error / Check message How to correct CHECK INK
U041 An ink cartridge is empty.
To cancel printing, press the Stop/Reset button.
To continue printing, press the OK button.
After the printing finishes, replace the empty ink cartridge.
Sep 15, 2009 | Canon PIXMA MX310 All-In-One Printer
My printer is flashing "E" & then "3" will not print or scan, what do I do?
As antiochpc said we don't know what printer you have. So the best thing to do is to contact the manufacturer website or the forums their you can ask questions. After doing some research I found this I hope it helps.
ERROR CODE CANNON MP150/MP160
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
Here is the entire link to the site http://www.fixyourownprinter.com/forums/inkjet/44590
Jul 03, 2009 | Canon Office Equipment & Supplies
Epson NX400 works but will not print any ink on the paper
did you remember to pull the tape off the print head before you installed the new cartridge?
May 28, 2009 | Epson Stylus NX400 InkJet Printer
Not printing
Have you checked if your cartridge protective tape is removed. There is this transparent tape in your ink cartridge contact area especially for HP printers, you need to remove it so you can print.
It would be helpful if you put in the actual unit with your question...
Mar 10, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer
Four flashes: Empty ink tank
One of the ink tanks is empty. Replace it.
Six flashes: No print head installed
Install a print head.
Seven flashes: Defective print head
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight
flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL
button to cancel the error so you can continue printing. Before the waste ink tank
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Oct 19, 2007 | Canon S520 InkJet Photo Printer
Lexmark Z640 InkJet Printer Logo
89 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
