Blower fan won't come on on the ac side, but it
Blower fan won't come on on the ac side but it works fine on the heater side is it possibly the relay?
  • 306 Answers
Yes it is possibly if you have such device. Older unit then yes. Newer say last 10 years no .. If you have a volt ohm meter you can check out the motor to make sure high speed works. Which the A/C uses the furnace uses the low speed. Get back with me if you need further assistance. ken
Posted on May 09, 2010
Heater ac fan won't blow 05 silverado. Started truck on cold day fan was blowing and turned it off waiting for truck to warm up and heater would not come back on. Checked all the fuses, all were good. Fan...
Test the electrical circuits ! Manual HVAC or automatic HVAC ?
Do you know the difference ? Heater / A/C blower motor electrical control diffrent . Manual has resistors an a relay for different speeds , automatic has a blower motor control module .Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info year , make , model and engine size . Under system click on HVAC ,then under subsystem HVAC controls will pop up . Click the search button , then the blue links . First off you need to know what system yours has , manual or automatic.
GMC Yukon HVAC Blower Motor Won Turn On
Blower Motor Problems Auto Repair Help
Feb 27, 2018 | 2004 Chevrolet Aveo
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
1998 buick century my heater and ac fan only work on high i'm told it's the blower relays where are they located
they are not relays its a blower motor resistor a one piece unit usually held in by two bolts and an electrical connector either under the passenger side dash or behind glove box
Aug 03, 2012 | 1990 Buick Century
Blower fan won't come on on the ac side, but it works fine on the heater side, is it possibly the relay?
it could be the relay or the winding in the motor try wiring a different speed on the motor by switching wires if that works its the motor winding
Mar 20, 2010 | Heating & Cooling
The heater/ac fan only works on speed settings 4 & 5
you might check your switch sounds like to me that your two lower speed sides of the switch maybe burnwed out.
Dec 19, 2009 | 2002 Chevrolet TrailBlazer
Heater fan not blowing..fan works with direct power..and ac fuses test o.k.....is this an electrical control problem?
Likely either a bad switch or relay. I'd also probe all fuses(regardless of what they are for) with a test light just to make sure they have power at both ends of each (takes ten minutes and eliminates the possibility that you missed something there.)
Dec 12, 2009 | 1997 Buick LeSabre
Ac blower motor
Check fuse supplying fan is not blown,
Check blower control switch is operating OK,
Check relay controlling fan is operating OK,
Check variable speed resistor pack is not faulty (the resistor pack is usually located in the blower ducting, in the blower airflow),
Check blower motor ground connection is not missing.
Aug 12, 2009 | 2000 Mercury Grand Marquis
AC compressor works fine, Blower does not. How do you repair?
check the fuse in the fan-fan relay-check voltage at the terminals of the blower if you have the voltage problem is to check the blower motor of the blower speed control
Aug 11, 2009 | 2006 GMC Sierra
1983 Chevrolet Suburban Heater fan not working
Heater blower motor resister is bad, replace, located under dash above heater motor.
Mar 15, 2009 | 1983 Chevrolet Suburban
Only getting lukewarm air from heater even with new thermostat
1. maybe your ac condenser blower is not working properly
2. slipping ac belt
3. air con compressor hub is sliding due to oil leak
Dec 10, 2008 | 1994 Subaru Legacy Outdoor
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
