Question about Mitsubishi WS-65869 65" Rear Projection Television
Help with my big screen mitsubishi ws65869 tv
I need help. my tv trys to turn on for about 5 or 10 seconds, then it will turn off. what do i do?
  • 6 more comments
  • Anonymous Apr 19, 2008
    Mine, the power light stays on for 1-2 seconds and shuts off.
  • Anonymous Sep 25, 2008
    i have the same problem great sound no picture work 5 hrs ago
  • Sam Nguyen Oct 16, 2008
    Shut off after all the lamps lit up 5 seconds
    Shut off after the lamps lit up for 5 seconds
  • gmontelione Nov 02, 2008
    When I power on my WS-65869, a red screen appears and then the tv powers off. What can I do to troubleshoot and repair?
  • mikeyeh88 Dec 17, 2008
    green light bliking will not turn on
  • cbeverts Jan 11, 2009
    I have the blinking green light of death problem  I had a repair guys out who wanted $500 and no guarantee that is would work.  I have decided to try and tackle it myself and I am looking for directions.  Any help is appreciated.
  • Anonymous May 23, 2009
    it was working fine until the green light came on permanently. now i can't even turn the tv on. i'm trying unplugging it for a little while to see if it'll reset the tv...
My tv turns off after 1-2 seconds what is the solution.
Posted on May 03, 2008
My screen is a right blue with no picture although I have sound it reads "tuner out"
Posted on Mar 27, 2008
SOURCE:
Mitshubishi plasma tv ws65869 wont start green led on in a sec off
Not a Plasma by the model number listed.
When green power light comes on and goes off a few seconds later:
Press and hold on the front of the set both the Menu and Input (source) buttons at same time for at least five seconds and let both go.
Power light will blink a two digit error code like: 2 blinks, 2 blinks and a pause and repeat it several times.
If set has been unplugged it clears the errors and you must turn on and when power light goes out repeat.
Let me know error code found and I will help
Mar 11, 2012 | Mitsubishi Televison & Video
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Have ws65869 tv
Replace the dm power board . Its inside the metal box on the left (looking at the back with the back removed). p/n 935C986002
Or if you can solder then replace the 7 electrolytic capacitors on the DM power board. value 1000uf16volt.
Jul 25, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi Big Screen Digital 65 inch
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
Feb 16, 2009 | Mitsubishi WS-55807 TV
Blue arc extends acoss width of mitsubishi ws65869
The WS65869 is a CRT based projector, no bulb. It sounds like you have a convergence failure. The convergence output ic's will need replacing.
Jan 02, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi big screen won't stay on!
Its very possible you have a failing resistor r2200
Nov 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi ws65869 big screen tv
Does the LED power light come on? Have you checked the fuses?
Feb 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi TV WS-55511 Turns Off after Turning On
My mitsubishi big screen tv turns off in few seconds what should I do and I just got tv today please someone help
Oct 28, 2007 | Televison & Video
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
666 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
