Question about Toshiba TLP 261 Multimedia Projector
Toshiba TLP S30 projector
LAMP WENT OUT DURING USE , OR WON'T COME ON .... RETURN TO STANDBY AFTER ABOUT 2 MINUTES.
TRIED WITH NEW LAMP AND NO IMPROVEMENTS
  • 818 Answers
  • 3,037 Answers
Hello
Check the lamp condition, Ballast unit may be faulty.
Possibly replace ballast to correct the lamp ignition.
Let me know how this works out for you, good luck and have a good day.
If it's not the lamp, it may be good to take it to a skilled professional who could spot the problem in an instant.
Be safe when working on any electronics
Posted on Mar 27, 2008
  • Benjamin Patri
    Benjamin Patri Mar 28, 2008
    ser, its not the lamp
  • Benjamin Patri
    after viewing the requested page that you wanted me to view
    http://www.fixya.com/support/t473178-tos...
    I am glad that you have been able to figure out what to do, please don't forget to rate this solution and good luck in getting it working again. Feel free to ask anything else in the future.
    Genius:
  • 3,422 Answers
HI,
Make sure the lamp cover is in place as it has a plunger on it which closes a switch . If the switch is open you will never power on. With the cover remover you can manually activate the switch too and it will power up.
For more troubleshooting steps you can see the user manual from HERE
Goodluck,
Please don't forget to rate the solution.
Reset lamp timer
If you go into the info menu you should see lamp hour meter, should be option there to reset it.
only do so if you have put in a new bulb as bulbs can explode if they go over the hour usage time.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP s30 projector identification part
http://www.nextag.com/toshiba-tlp-s30/search-html
Mar 28, 2008 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP projector identifiation part
You need to check lamp again, it may be not well mounted.
How do i reset lamp hours for a toshiba TLP-T721
I have not actually tried this but on a different post, here's the wild solution:
Reset the lamp counter hours of operation for the projector TOSHIBA TLP-T720
1. Turn-off the device by pressing the "ON/STANDBY" and unplug the power cord
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord
3. The lamp operation counter will automatically turn to zero
4. Check if the lettering "0H" appears on the lamp operation counter in the status display
5. After the lamp operation counter has turned to zero, turn off the projector by pressing "ON/STANDBY" and unplug the device.
Sep 02, 2010 | Toshiba TLP T721 Multimedia Projector
What bulb is needed to replace in the projector?
three green lights come on then the standby light goes red and remains on when the projector is plugged in. The lamp and fan do not come on when the power button is pressed instead the lamp light comes on red.
Jul 13, 2010 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP-S30 loses calibration/alignment with whiteboard.
there are phisical adjustments for the projector itself. is it on a smartboard? hold down the 2 buttons on the pen tray until the 9 point callibration screen appears. the points react to stylus release, so put the stylus near the point and "draw" a line to the center of the point then release. do the same for the other 8. that should do it.
Dec 11, 2009 | Toshiba TLP S30 Multimedia Projector
I have a Toshiba TLP-S30 and lately the color balance of the projected image is way off. I've tried adjusting the color balance via the menu, but no improvement. Could this problem be fixed with a new...
reset the settings to factory default. sometimes the lamp will burn at a lower temp at the end of it's life and emits a different color. might be the lamp or the ballast. if all else fails, replace the main board.
Oct 18, 2009 | Toshiba TLP S30 Multimedia Projector
Internal fan location in TLP S30, I get an error message about internal fan problem
one of the fans arent working. there should be at least 3- one for the lamp, one for the power supply, and at least one for the lcd panels. you should be able to see the one for the lamp and power supply from the outside. if both are spinning, it's the other one, which you might be able to see from the bottom.
Sep 22, 2009 | Toshiba TLP S30 Multimedia Projector
HOW TO RESET LAMP HOURS
Do this
Unplug the AC cord
Press Input, VOL - /Standby/Menu at the same time.
Plug the AC cord and wait until the Power light is amber. release the Vol/Standby/Menu bottoms. I hope will work for you.
Jul 12, 2008 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP-S30
Make sure the lamp cover is in place as it has a plunger on it which closes a switch . If the switch is open you will never power on. With the cover remover you can manually actuate the switch too and it will power up.
Oct 16, 2007 | Toshiba TLP 261 Multimedia Projector
Toshiba TLP 261 Multimedia Projector Logo
95 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
CheckitRight
CheckitRight
pkwc
Richard Roth
Richard Roth
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
