Question about Car Audio & Video
Back speakers do not work - Car Audio & Video
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Check your wires on back of speakers, and the back of the head unit. but check your fade and balance gain on your deck........
Posted on May 12, 2010
How do I get the back speakers to work? The speaker test shows that all speakers work but i only hear the front speakers
Try reinstalling speaker drivers, or check the cables to see if they are working. Try turning off the front ones or unplugging them and plugging the back speakers where they were.
Apr 10, 2016 | Audio Players & Recorders
Front Speakers stopped working
turn on your video and start something playing, press the speakers button repeatedly until the sound comes back. this should bring back your front speakers, if it doesn't, double check your speaker connections and sound field program.
the speakers button should cycle through all available front speaker options.
Nov 16, 2007 | Yamaha HTR-6030 Receiver
My speakers were working fine and i unplugged everything to move them. When i plugged everything back in no sound. My computers speakers are working just fine but when i plug in the speakers no sound. I...
I suspect you have not plugged them back into the correct socket. The plug is coloured green and therefore should go back into the green socket. you have probably plugged it back into the blue or pink sockets. Use a torch to check that is in the green one.
May 04, 2011 | Harman Kardon SoundSticks II Computer...
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
No sound coming from my speakers
Possible scenerio's with the little info you gave.
1.You have a bad speaker thats blown or the wires are touching the chassis of your car.
2. You have a factory amp and you need to connect the blue wire to the amp turn on wire. And if it still doesnt work then you have to rewire it complete or maybe have to get a special car amplifier compatible harness so your aftermarket works with your amplified system in your car.
3. In certain Ford cars they crisscrossed the back speaker wires. To test this unplug your harness from the radio. VERY IMPORTANT( splice these colors of wires in the middle enough so you can use a 9volt small rectangular battery to make the speakers you want to test pop(harmless))
1. green = back left + speaker
2. green/black = back left - speaker
3. purple = back right + speaker
4. purple/black = back right - speaker
test green speaker wires first touch battery to the + and - and the speaker should pop if not you have already discovered the problem. Know this time pop the green + and the purple/black - on the 9volt battery if the speakers pop you have found the solution.
Just criss cross the the negatives of the back speakers. From the radio harness end attach green to green, purple to purple, green/black to purple/black and last purple/black to green/black. And all your speakers should work again.
Dont ask me why late Ford Models crisscrossed their speaker wires. They just did.
Apr 08, 2010 | JVC KD-G140 Car CD Player
Two of four speakers are not working...one each in front and back of car
then the ones not working r probably ran together pull out radio and check speaker wire connections,if that doesnt work run the back speaker off the other back speaker , then do same w front , or if that doesnt work maybe speakers r blown out ,
Jun 27, 2009 | Aiwa CDC-X204 CD Player
Surround sound will not work sr805
Did the speaker cailibration work on the speakers in question?
If YES, then the program material or settings you're using don't require the rear speakers.
By "Back" do we mean Surround or Surround Back? Surround Back speakers are the 6th and 7th channels in the 7.1 matrix. Not all source material has programming for them. But when using any 7.1 digital surround mode you can get anything, even stereo recordings, to output something from every speaker.
If NO, check your connections...
http://63.148.251.135/redirect_service.cfm?type=QuickHookup&file=TXSR805_QSS_En_0330.pdf
Dec 21, 2008 | Onkyo TX-SR803 Receiver
Speakers
'Buzzing' is not a good thing; it implies that filtration of the DC used by the output section is not as it should be. Power supplies that are mildly overloaded can cause this or an abnormal current drain from one (or more) channels.
The odd problem with the back speakers does sound like a setup problem rather than a circuit failure.
Oct 31, 2008 | Onkyo TX-DS989 Receiver
Only one surround back speaker works
It sounds to me like one of your speakers may be mis-wired. Try reversing the speaker wire (don't switch right-for left, but switch negative for positive) and see if that changes anything.
Dec 31, 2007 | Onkyo HT-SR800 System
Main speaker not working
Just press and hold the "phone" green buttom for about 2 seconds. The main speaker is enabled. The same procedure works when during a phone call, to enable a hands-free operation, or when listening to windows media player.
Sep 14, 2005 | HP iPAQ h6315/h6365 Pocket PC
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
