Question about Health & Beauty
We are in need of a wiring diagram for a Ford Think. The 6 batteries appear to be in two banks of 36 volts but the owners manual claims the motor is 72 volts.
4 Suggested Answers
plaztiksr4me
  • 154 Answers
SOURCE: fazer nash electric vehicles 72 volt golf carts
bad batteries?? maybe only getting so much power then ooomph hmm bad connection maybe to battery
Posted on Apr 09, 2010
micromatikal
  • 2777 Answers
SOURCE: My schwinn s750 elec. scooter
Yes that is quite dangerous and definitely not normal operation . It sounds like something in the throttle itself is not sensing the turn correctly. You are going to want to get the part from Schwinn directly, they will know which part, and can provide the manual to you as well. Their number is 1.706.860.8880
Posted on Sep 28, 2010
  • 405 Answers
SOURCE: new charger for 36 volt
HI.It should be connected in that way.The + sign of the charger connected to the +sign of the batt then connect the - batt next then finally connect the -sign of the batt and finalle the+ sign of the last batt must be connected to the -sign of the charger.This connection allows the voltage to flow within the 3 batteries.Thank you for choosing FIXYA.
Posted on Aug 03, 2011
Wiring diagram se-4020 battery charger
try this web site
http://www.manualslib.com/manual/523935/Schumacher-Se-2254.html Schumacher SE 2254 Owner Manual
Feb 08, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
Need wiring diagram for 230 v for delta table saw cat. #36-451
Is the motor designed for dual voltages? The manual does not have a wiring diagram. I assume the motor lable diagram is faded or missing.
Dual voltage motors contain two sets of winding. Each set is rated for the lower voltage. To operate the motor on the higher voltage the windings must be connected in series. AND, they must be connected in the same direction. I use a variac to apply 30-40 VAC to the coils in various combinations, then measure the open lead voltage to determine the proper connections. This test should be performed by a licensed electrician.
Dec 05, 2013 | Delta Saws
I need to convert mu Puma PPH 30-10 air compressor from 220 Volt to 110 Volt wiring, but I do not have the owners manual or a wiring diagram for it. The Motor is a GE
If this is a 3HP I don't think you can switch it. However there is usually a wiring diagram under the square box on the side of the motor.
Sep 29, 2013 | Puma 3-HP 60-Gallon Belt Drive...
I've bought (at auction) a Marketeer 36 volt electric truck (similar to what you see pulling luggage carts at airports). Before spending money to buy 6 new 6 volt batteries, I'd like to know whether the...
I doubt your understanding of how the motor works is correct. More likely 2 of the terminals on the motor are for the field coils. The battery charger should not be used directly to power the motor without a battery also connected. The motor would function as a short circuit to the battery charger.
Instead, you can use 2 car batteries to test if the motor works. The full 36 volts is not needed.
Sep 16, 2013 | Dryers
Hooking up a 36 volt charger to three 12 volt batteries in series
first of all do you have 3 or 4 batteries your cranking battery is not to be wired into this 36 volt if you have 4 batteries you have 3 for trolling motor and 1 cranking battery look on your charger see if the banks or numbered 1 2 3 4 .... you got to find what battery is # 1 depends on how they hooked in series if you hook charger on wrong battery most the time a red light comes on telling you wrong battery move wires till green lights come on all batteries.# 4 goes to cranking battery if you only have 3 batteries you don't have 36 volts you have 24 volts and a cranking battery if so # 3 goes to cranking battery
Aug 29, 2013 | Minn Kota Boating
Bought a used 1983 southwinds motorhome but no batteries. does someone have a wiring diagram for the batteries
no diagrams but the reason for duel 6 volt batteries is for proper distribution of power you can put duel 12 volt in it and it will seem to run fine but over time fueses will get weak and start to pop as well as relays. i hope this information helps. J&D services
Sep 22, 2012 | 1983 Chevrolet Suburban
How do i wire 4 6 volt batteries in my 2000 monaco knight motor home
Quick drawing but I think you'll get it. If not let me know. Your building 2 separate banks of 12 volts with jumper.
Oct 06, 2011 | Rv Motorhome Dual Co & Lp Gas Alarm...
How to connect 4, 6 volt batteries on a 2005 fleetwood expedition
Assuming that you want a 12 volt equivalent, you should wire the batteries as in the following diagram.
If you are looking for some other configuration, post a reply.
Dec 27, 2010 | Rv Motorhome Dual Co & Lp Gas Alarm...
Want to connect electric lights to ez-go electric golf cart. It is a six battery system and I want to simply add a front light and rear red light.
You said you have 6 batteries. Are they 6 volt or 8 volt? Hint-- 6 volt has three holes in the top and an 8 volt has 4 holes on top of the battery. Battery manufacturers recommend the use of a voltage reducer wired to the whole bank. This take the 36 or 48 volts down to 12 volts and is regulated. this is recommended so as not to stress just 2 batteries. If you have 6 volt batteries, you can use any 2 that are wired in series.
Sep 21, 2009 | Garmin Walking Cart Mount For Golflogix...
Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
budman772357@embarqmail.com
Mar 01, 2009 | Minn Kota Boating
Health & Beauty Logo
423 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
