Question about Garmin zumo 550 GPS Receiver
Extension cabling for Garmin GPS
Garmin GXM 30 antennae comes with extension that is rather long. What is the solution if I only need one 18" long? This would be the cable that connects from the one on the GXM 3o to the cradle.
    Scholar:
  • 174 Answers
Hmmm, it uses mini usb cable, 1.8 mtrs, thats about 6 foot...
check here http://www.pc-mobile.net/pspgps.htm
Posted on Jun 10, 2008
I need an antenna for a garmin 660
Here is a link to amazon were you can get a new antenna for around 15 the Garmin does sell stock antennas but they are 30 with a 1-2 order processing time so this would be quicker.
May 04, 2011 | Garmin Nuvi 660 GPS Receiver
Cant get xm weather on garmin 740s
To receive XM weather or audio, the GPSMAP 740s requires a GXM 40 Smart Antenna with XM subscription.
The GXM 40 Smart Antenna (010-00730-00) is used to receive weather and audio service from XM satellite radio. For details on XM services please visit our XM webpage.
Once a GXM 40 Smart Antenna has been connected to the GPSMAP 640, the device can display the subscription information for the antenna.
From the Home Page in Boating mode:
  1. Select Configure
  2. Select System
  3. Select System Information
  4. Choose Weather Subscription
From the Home Page in Driving mode:
  1. Select Tools
  2. Select XM Services
  3. Select XM Radio
  4. Set the channel selector to channel 0
  5. Select Radio ID
The subscription information will now be displayed on the screen.
Mar 26, 2011 | Garmin Gxm 51 Weather And Audio Xm...
Bought a 987c si hd. i have a 917c on the front. I bought a inter link for them. when it is hooked up like the diagraphm says, that is 1) plug the puck into the gps port on the interlink. 2) run power...
If you have put power to the gps antenna then there is going to be a problem with your gps antenna. The Humminbird gps antenna gets it power from the unit. If you have done this you will need to contact our customer service group to get it resolved. There number is 800-633-1468.
Joby @ Humminbird
Jan 29, 2011 | Humminbird 4068201 AS InterLink Network...
Golflogix gps-8 wont connect to my mac and register
make sure its plugged into the mac itself and not a hub, or an extension on the keyboard. Also, make sure the cable is pushed ALL the way down on the back of the gps, it can be tricky. even when its tight, it might not be all the way down.
Jan 09, 2010 | Garmin GolfLogix GPS-8
Garmin GXM30 stopped working. what is the usual reason for this? Driving along in the morning, the sound started to sound'' fuzzy'', I went to try a different channel and immediatly lost all XM radio in...
There is very little to those pucks. If you have tried it in two devices then the electronics have gone bad. Blame a solar flare or something but it will need to be replaced
Apr 15, 2017 | Garmin GXM 30 Antenna
How do download music to a garmin
The music must be in a MP3 format with an .mp3 extension on each file. You need a USB cable to connect your Nuvi to your PC. Once you have the files on your PC, just copy and paste them onto your Nuvi directory in the MP3 folder.
- Jim
SHARCNET-USA
Jan 16, 2009 | Garmin Nuvi 660 GPS Receiver
Locks up after a few seconds/have to kill power to reset
This may help. Mine has the GPS antenna build into the bracket at the back. I removed the bracket and the unit did not go into the error screen and the sounder worked fine. The GPS would not locate but it has not antenna attached so DOH!! I have orderd a new antenna with the BNC connector and will post if that fixes the problem. At this point I'm guessing its a blow GPS antenna.
Dave
Oct 12, 2008 | Garmin GPSMAP 168 Sounder GPS Receiver
Sirius Antenna
There are several ways to tackle this problem, most of which would involve getting to the back of the radio, but before you do, make sure you have an "antenna extension cable". Then plug in the 'extension cable to the radio/sirius unit' leaving the other end to 'hang out' where you can then get access to the 'extension' cable. Then you can plug in the existing antenna when you're not using the camper or plug in new antenna that gets clear view of the satellite. Depending on your location and general direction of travel you may be able to use a 'home unit ' antenna on your dash as I do and it works very well. In my truck I often use a home antenna also, although I also have the large unit that bolts to the (tractor) truck mirror assembly.
The other solution is to find a CB repair place (often at truck stops) that is familiar with repairing, satelite antenna wire and pucks. Have them split the wire and place a male and female plug to accomodate the extisting antenna and the new antenna. This service will cost you about $30-50.00 They should find the parts needed at a satellite radio store that sells marine/business/home antennae systems. The parts are not all that common - or the CB fellow may connect male/female connectors that are unique to your truck situation - then any connectors will work but only on that truck of yours. -- Frank
Sep 15, 2008 | Audio Players & Recorders
Pioneer Navigation System
You will need a gps antenna, 30 pins data cable and an antenna extension to do basic installation set. For more precise set up you will also need reverse and speed signal sensor wires(pink and purple).
Nov 19, 2007 | Pioneer AVIC-N2 Car DVD Player
XM radio sounds like crap!!!
if the xm and gps antennas are close together this will happen. u will have to move one to the front and the other to the back of the vehicle.
Nov 03, 2007 | Kenwood DNX7100 Car Video Player
Garmin zumo 550 GPS Receiver Logo
190 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
