If i revert back to my factory settings on my netopia router will this impact my at&t settings? I'm just trying to let someone use our wireless access and have misplaced the login info
  • 22 Answers
Restoring the router to factory default will have impact on AT&T settings provided if you not made note of the setting details. However its adviced to call up AT&T and make a note of the settings before going for factory defaults.
Posted on May 10, 2010
I reset my Netopia Cayman 3347W wireless router and now my Laptop is not able to use the Wireless signal as it states that the connection manager is set to use only secure wifi but the reset signal is not...
You reset the router. that means router is set on factory default.settings has been changed now that's why connection manager is not responding properly. Now you have the run setup CD and set the router again.
Oct 11, 2012 | Netopia Cayman 3347W-Ent Wireless Router
HOW CAN I CHANCE SETTINGS TO FACTORY SETTINGS
to put a router on its factory settings, there's usually a button on the back of the router. its a small hole that you need a paperclip to press it. make sure to press and hold it for about 20 secs to revert it back to its factory default settings.
Sep 13, 2011 | Computers & Internet
Firewall set to high on my netopia 2247nwg roughter how do i change it
Try browsing to http://192.168.1.254, which is the default address of the router from the factory. If it's been changed you'll have to find the address of your computers 'default gateway' and use that instead.
Username is 'admin' and the default password is the serial number printed on the router itself.
Once into the router, you should be able to find the firewall settings and adjust them as necessary.
Good luck.
Mar 24, 2011 | Netopia 2247NWG-VGx Wireless Router...
How do i reset my password on netopia 3000 router
If you are talking about the password to change the router settings you will need to do a hard reset or try the already default username and password below, but be aware that it will take you back to factory settings.
Get a pen or a straighted paper clip and with the router still powered on, hold that tiny reset button for a bout 30 seconds, then unplug the router and plug it back in. This will set it back to factory defaults and you will need a cabled connection to reconfigure the router. If it ask for your username and password, use these
Username: admin Password: admin
Feb 26, 2011 | Computers & Internet
Good day i reset my wireless router netopia 3347and i can find the password and username do u guys have it thanks.
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
Feb 23, 2011 | Netopia 3346N-ENT Router (3346NENT)
Forgot my password how do I re set it
Hi friend,
As you have mentioned that you have forgot the password for the router, so you can reset the router to factory settings by pressing the "RESET" button on the back of the router. It is a very samll button and you need a paper clip to press it.
What you need to do is, you need to take the paper clip, put it in a small hole on the back of the router and press and hold the button for atleast 30 seconds.
Once you release the button, the router will come back to its factory settings.
NOTE: If you will reset the router, all the settings on the router for Ethernet and the Wireless will be lost and the router needs to be reconfigured.
Dec 07, 2010 | Netopia (3347NWG-VGX) Wireless Router...
I need to make sure port 3074 is open for xbox live but dont know how to do it.
You can use the netstat -a command to find out which ports are open on a local Linux/Unix or Windows system (Figure 1), but netstat can't be used remotely across a network. netstat.gif
FIGURE 1: The netstat command can be used from the Linux or Windows command line to check on
open ports on the local computer.
If 3074(TCP & UDP) port is not opened on the router, refer: http://www.netopia.com/support/hardware/technotes/CQG_025.html for further step-by-step assistance.
For any further help/support, revert!
Thanks for asking..
Arvind S Iyer
Sep 26, 2010 | Netopia 2247NWG-VGx Wireless Router...
If i revert back to my factory settings on my netopia router, will this impact my at&t settings? i'm just trying to let someone use our wireless access and have misplaced the login info
Yes if you reset all settings to factory defaults.All settings will be lost so you need to configure your router again.
You can access it and configure with following method.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
IF you are not able to access it with above ip then you need to reset it for access .Press RESET button for 10 seconds it is in back side of router then all settings are default.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 16, 2010 | AT&T Computers & Internet
I hooked up my wireless and dsl router again and I forgot the password to get into it
Try a hard reset (small button on the back of the router, usually recessed and accessably using a paperclip to push it in)
This will restore the router to factory settings. The password and user name will revert back to the factory ones which for netgear is
User Name = admin
Password = password
Then once your into the router settings you can set the username and password to something you want.
Hope this helps
Aug 15, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
