Question about Air Tools & Compressors
Dear sir/madam i have a stanley bostitch compressor 8 bar 160L/min and its leaking out air at the regulator around the adjusting knob and i think its the o ring thats gone whats the correct size o ring for it or is there another problem with it. Thanks for your help. Paul o'halloran.
2 Suggested Answers
  • 1584 Answers
SOURCE: dear sir/madam
Just purge the air out / dismantle the reg and match spares up from you r local engineering shop.
Posted on Mar 16, 2010
Can the pressure switch on a Bostitch pancake compressor model cap2000p-of be adjusted so the compressor will come on and shut off at a different pressure than what was set a the factory?
NO unfortunate There is a electric pressure stop on this model !! not an adjustable pressostat (presure switch) pos 21 is the electric stop at maybe 8 or 10 bar
the savety valve is pos 22 (there is mostly a maximum pressure notition on to read) there is nothing to adjust on this type compressor what is made for a group a (Stanley-Bostitch-Dewalt) patented this pump is placed in several types of compressors of this brands.
http://servicenet.bostitch.com/Products/Detail?isId=true&productNumber=CAP2000P-OF&selectedType=25111
Detail
Oct 24, 2015 | Air Tools & Compressors
I have a Stanley Bostitch CAP2000P-OF Air Compressor. It runs constantly and won't reach the shutoff pressure. It will build some pressure. When I turn it off, I dont hear any leaks.
Jim:
There is a leak somewhere... Use a soapy solution at the air tube from the compressor head to the tank (both ends) and at all air hose connections. The bubbles will tell you where the leak is and you can repair the connections from there...
Aug 17, 2013 | Stanley Bostitch CAP2000P-OF 2 HP Peak 6...
Large red pressure adjustment knob on my compressor is broken and will not screw on, compressor will not hold pressure
You may have to replace the regulator as many of them do not sell just the knob. If you go to this link and put your model number in the search box you will be able to see what is available for it. By the way, Stanley (Bostitch) merged with DeWalt so all the breakdowns for Bostitch can be found on the same site now.
DeWalt/Bostitch parts and owners manuals.
Aug 19, 2012 | Stanley Air Tools & Compressors
Compresor will not hold pressure
Some are push down to lock so you need to lightly pull up on the knob before trying to turn it. If the regulator itself is bad the correct one is part #AB-9051116 and is less then $10. Any Bostitch or DeWalt (the companies merged) can get this part for you. Here is a link to the parts diagram. It is item 108 and is called a pressure reducer.
Bostitch CAP2060P diagram
Aug 19, 2012 | Stanley Bostitch 2hp 6gal Air Compressor...
I have a 2007 Bostitch sir compressor that will not buid pressure. I am able to repair my self, I just don't know what to replace or adjust. Any info will help. Its a model CAP6OP-OF. Thanks
Your compressor could have worn cylinder /ring, worn/ leaking/ or broken reed valves or just leaking at a joint (check for leaks first using soapy water). Oil-less compressors have a silicone /vinyl compression ring that wears out quite easily depending on conditions at the job site (dusty/ gritty etc). Remove cover and turn motor till the piston is at top of stroke. Look for scratches close to top of cylinder, if present, replace cylinder and compresson ring to restore full power. If cylinder is smooth, and ring looks ok from the bottom than loss of power could be reed valves. Remove head and examine reeds replacing as needed. Good luck
Dec 16, 2011 | Stanley NEW Bostitch 2 HP 6 Gallon...
I have a Stanley Bostitch Oil Free Air Compressor 6.0 Gal 2.0 Hp Peak, 1.5 Hp Running 135 Psi The problem is it won't blow out air or hold the air.. How can I fix this?
Some Bostitch compessors are very unique in that they intake air from below the piston. If you cannot find an air filter, then your compessor has reed valve built into the piston that may cause problems. If you have an air filter on the head of the pump, then you have reed valves in the head. When the reed valves fail, there will be very little or no air pressure. Second problem with all compressors is the in-tank check valve. This valve allows air to enter the tank and not back-out into the compressor. Easy to check. Add air into tank with another compressor thru the quick connect and listen for air leaking around the head or pressure switch. If no leaks and pressure holds in the tank then valve ok. Examine the condition of the cylinder and piston ring by rotating the crank by hand so that the piston is at top of cylinder. Look for scratches around upper part of cylinder wall. If scratches, then replace cylinder and piston ring. If top of cylinder looks good, then suspect reed valves. Good luck
Sep 12, 2011 | Stanley Bostitch 2hp 6gal Air Compressor...
On a Bostitch CAP60P-OF air compressor I can get 120 PSI easily but get little or no air pressure on the the hose side. Can't even run a stapler.
i also own a bostitch and it works great, the pressure regulator knob on mine is red not sure if yours is the same color but just turn this knob until you get the nail depth that you need , it should be near the pressure gauge, a quarter turn of this knob at a time is recommended until you get the pressure you need, i think you turn it in the loosen direction to get more pressure
Jan 22, 2011 | Stanley Air Tools & Compressors
Describe your Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit ProblemCompressor builds to 80PSI and will not shut off or build...
sounds like an air leak of some sort. when you get it up to as high as it will go, turn it off and listen for an air leak. Let me know where it is leaking and i will tell you what to fix
Jul 13, 2009 | Stanley Factory Reconditioned Bostitch...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
