Question about Xerox Phaser 8200 Laser Printer
Fault Code 08.001.44 Paper Jam
I am getting this fault code for a paper jam and cannot find any jammed paper. I just replaced the preheater/drumheater to solve one problem. Is there a reset or a common place paper can get jammed, that I am not finding?
  • Anonymous Mar 15, 2014
    Epson Px650 fault paper jam but no paper in
    President:
  • 2,072 Answers
That is a failure in the maintenance kit tray area.
1. The Cap/Wipe/Purge belts have loosened up or are out our alignment. - Adjust the Cap/Wipe/Purge belts and follow the procedures outlined in the Service Quick Reference Guide for adjusting these belts and proper alignment. 2. Ink contamination or spilled wax is keeping the Cap/Wipe/Purge from properly moving. - Clean up spilled ink from the drum maintenance rails guides, sensors, and pulley belts. 3. The Drum Maintenance rail guides are out of position. - Remove and reseat if necessary. These rails may have suffered fatigue and may show signs of cracking or breaking. If this is the case it is a recommendation to replace the Drum Maintenance rail guides
The maintenance drawer itself may have the end tabs worn down from lifting up and down.
Posted on Mar 27, 2008
  • Rick Kasper Mar 27, 2008
    Here is the parts list in probability of failure. A time consumin trouble shooting code
    PARTS:Parts are listed in the order of highest probability for repair.
    NUMBER
    QTY
    DESCRIPTION
    PROBABILITY%
    MODEL S/N
    FROM S/N
    TO S/N
    351105102
    GUIDE ASSEMBLY; DM DRAWER,LEFT,SAFETY CONTROLLED
    650428800
    FRU, CLUTCH/ANTI-ROTATION COLLAR
    351105301
    GUIDE; DRAWER ASSY,DM RIGHT
    367051501
    FOLLOWER,CAM; DM CAM,SAFETY CONTROLLED, QTY 1
    401080802
    CLUTCH; PICK,W/SOLENOID,SAFETY CONTROLLED
    148030101
    SOLENOID ASSY; TRANSFIX
    Cause:
    The cap-home sensor did not see the sensor?s flag when expected.
Colour Xerox Machine problem
its a problem with the fuser unit ,its overheating .two ways to solve it first check if the sticker paper is supported by your printer ,2nd you may need to replace the fuser unit
Oct 02, 2014 | Xerox DocuColor 242-252-260 PS
I have xerox dc 250 machine, it shows fault code 077-909, paper jam at tranfer module but i checked there is no paper in it??
Hello friend, you are not alone !!!!
From http://www.copytechnet.com/forums/xerox/28764-dc-250-fuser-problem-077-909-a.html
At the bottom of the page it says.......
'what sometimes happens is that the sensor flag/arm call it what you will, twists out of its holder and jams, hence the machine thinks that there is still paper. the flag/arm should pivot freely'
Sep 03, 2014 | upbright AC / DC Adapter For XEROX...
Exit jam
have the machine perform a paper path test with just 1 copy to see if this jams then have it path test 5 prints to see when it jams- if its only jamming when more than one sheet is being printed then the fault lies with the paper pick up ( you may notice a longer delay for first print)
the machine will attemp to feed three times before failing as a jam
if the machine is printing more than one sheet then the jam appears just before the tail end of the first print exits the fuser (fixing Unit).
clean or replace the feed rollers.
if the jam happens on every print and the code is 13:02/3
then paper pass sensor arm 2 has stuck (look on you tube to resolve this search for lj4200 13:02 jam)
hope this helps- if you are still unable to get the machine working and your willing to pay then I would suggest Belmonte Buisiness machines
are a good company to deal with they are on 0161 480 5556 and can call out anywhere in the UK
Jan 26, 2014 | HP LaserJet 4250n Printer
13.01.00 Jam in Tray 2 error when no jam exists
Check Tay2 paper sensor flag, located at tray2 pick up roller, its its stucked shoot the fault
Mar 24, 2011 | HP LaserJet P3005 Printer
Error code on Ricoh FT5733 copier
Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
Nov 12, 2008 | Office Equipment & Supplies
Phaser 8400 paper Jam
The preheat entry assembly has paper detectio arms/sensors that will get brittle and break off, leading the machine to think there is a paper jam. This problem usually will require a trained technician to diagnose & repair.
Sep 12, 2008 | Xerox Phaser 8400 Laser Printer
Jam error B3S
This is a problem with the preheater sensor. It could be a clutch, paper tray seperation pad, or (my vote for most likely) the preheater assy. Not too expensive, but you should get a technician to look at this.
Jun 26, 2008 | Xerox Phaser 8500/DN Printer
CANON PC920
POSSIBLE BAD EXPOSURE LAMP, SOUNDS FUNNY BUT THIS MODEL WILL SEND JAM CODE WITH BAD EXPOSURE LAMP. CHECK TO SEE IF LIGHT IS IN PREHEAT MODE. ALSO THE EXIT PAPER SWITCH GETS BROKEN OFF ON THIS MODEL...
Nov 29, 2007 | Office Equipment & Supplies
Xerox Phaser 8200 Laser Printer Logo
224 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
