Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
Basement flooded;water Heater insulation is a little wet on right side of entrydoor; Relighting the pilot light has been unsuccessfull; What do you reccomend?
  • Anonymous May 11, 2010
    I reccomend locating the source of the water leak first and then formulating a question based on the presentaion of any available useful info you may have. All you have stated is that your basement is flooded and your water heater is a little wet in one spot presumable near the entry door to the pilot light not the entry door to the basement. I can't be sure which from your lousy description. I'm also curious if the pilot light is an issue at all. Do you know how to light it. Have you lit it before? Assuming the water heater is leaking and flooding the basement that issue would be unrelated to pilot light operation in any case. I would say that if your water heater is leaking, you should not be trying to return it to service until you determine the cause of the leak. Did the unit overheat and release water through the pressure relief valve on top. If so you need to dissasemble the heating and thermostat components and replce them with a simple kit you can buy at Home Depot. Also this time install a PVC pipe on the discharge valves at both the top and bottom of the unit and run those pipes to the nearest floor drain in the basement.Purchase a water heater spill pan as well and place it under the unit. Installa pvc pipe on the pan as well and run it to the nearest floor drain. Next time the basement won't flood when the water heater springs a leak of any kind. Bottom line to fix the problem issimple. Go to Home Depot and get a water heater rebuild kit which comes with new heating elements of similar amp rating to your water heat. It also comes with a new thermostat and pressure release valve. Go home and install the kit. Do not skip any steps in the installation instructions! Then install your new emergeny drain plumbing and make sure to use pvc rated for high temperature. Then hang a dry erase marker on or near the freshly rebuilt unit and write the date and maintenance you performed on the unit. From now on you will perfom an annual maintenance inspection of the unit including draining all sediment out of the tank bottom by opening the tanks drain valve and letting the tank purge out all the sediment that builds up in the tank bottom. You will also remove the heating elements and clean them to ensure efficient operation. Then inspect the drain valve and connecting pipe threads to make sure they appear to be in solid shape and wont break . Write that down on the heater along with the date you inspected it and next year you will have a written reminder there to tell when when it is time for next inspection. Your water heater will never break again and flood your basement if you follow these steps. Good luck.
  • Ernest London
    Ernest London Oct 24, 2017
    That sucks about your basement flooding. I recently had a neighbor whose basement flooded, and he had a lot of water damage. Have you considered calling a professional? I imagine they have the skills and tools to help fix any number of things that might have been damaged in flooding. Good luck! http://www.redeemingrestoration.com/wate...
    Scholar:
  • 102 Answers
Call your gas company and have them check out the unit.
Posted on May 13, 2010
Reliance 606 water heater was in flooded basement had few inches of water up to it now wont light. What to do?
This could be a tough one without being able to examine it. First, have you precisely followed the relighting instructions printed on the heater (turn the knob to "pilot," hold down the button, etc.)? One other thought: the gas pressure to the pilot flame is very low - if some water got into its little supply pipe it could keep gas from getting to the pilot burner device. You would have to disconnect the pilot tube from the gas controller valve and blow it clear, then try again. Dealing with this type of gas problem can create dangerous conditions if not done properly. If water got into the gas controller valve (the one with the knobs and buttons) it will have to be replaced. If unsure, consult a plumber.
Apr 20, 2013 | Reliance & 50gal Electric Water Heater
Power vent rheem mod pvw50 underneath is leaking
You have a water leak coming out of side of tank?
Water heater must be replaced. It is rusted, and could rupture.
Inspect and replace anode rod to prevent rusted tank, so water heater will last longer.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Aug 09, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water in basement in flood that covered the lower element. When power was turned back on, the green light on the top of the heater was blinking twice. When I hit the reset button, it is now blinking...
Yes sensor should be replaced along with lower element.
1) Manufacturer's say that flooded water heater should be replaced: Call homeowner's insurance company.
http://waterheatertimer.org/Flooded-water-heater.html
2) Brand of water heater is not known, but it could be the American or Craftmaster or Whirlpool energy-smart electric with control box.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
3) With energy-smart:
1 flash is start-up failure, and 3 flashes is sensor failure.
The moisture probably shorted element and/or lower sensor.
4) The moisture inside tank will take long time to dry out, especially since the foam insulation is wrapped tight. To dry out element and sensor, you have to remove cover and insulation over element, but if you leave insulation off and run water heater, then the sensor is exposed to cool outside air and will not read temperature inside tank.
Plus a wet water heater is electric shock hazard.
5) Add a comment for more free help.
6) Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 13, 2011 | Water Heaters
Basement was flooded and water cover electronics,
TURN OFF ELECTRICITY before touching gas or electric water heater this is or was flooded.
Replace flooded gas or electric water heater.
Warranty is void, all manufacturers say replace water heater, and even if parts are replaced, there is no guarantee that unit will work again.
Resources:
Take a moment and rate answer:
Sep 01, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Rheem 82V52-1 Fury Electric Water Heater. The breaker keeps tripping atfer about five minutes of use. I uncovered the Bottom Element and Tested it with a Multimeter. Reads about 6 Ohms, Seems...
Protect yourself.
If water heater is tripping breaker and water heater is wet, then danger of electrocution.
Turn off power.
You do not need special element. Local home center and hardware sell generic elements.
Check side of tank for element wattage, usually 4500 Watts.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If fiberglass insulation is wet, you need new insulation because the insulation and cover cannot be left off the heater.
If thermostat is not covered with insulation, then cooler air will cause thermostat to mis-read temperature, and tank will overheat.
Putting a wet water heater back into service is dangerous.
Manufacturers suggest replacing flooded water heater.
Local Lowes here sells new 40 gallon electric water heater for $207.
Loosen anode rod before installing.
http://waterheatertimer.org/Replace-anode-rod.html
Upvote the help.
May 27, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
High water in basement, the push button temp indicator reads both leds lite on both ends. i dont know who to reset
1) Call service technician.
2) If water heater flooded, contact insurance company for possible replacement coverage.
3) Manufacturer's suggest replacement of any flooded water heater.
4) Be very careful around wet or previously wet water heater.
Insulation inside tank will stay wet. Household electricity is grounded to water pipes that are connected to gas or electric water heater. Touching wet water heater can be fatal.
5) Read label on side of tank for product identification.
Read manual for possible part replacement.
http://www.rheem.com/product.aspx?id=772AB3A7-6282-4A0B-8657-21977DFB57E3
http://globalimageserver.com/fetchDocument.aspx?id=4e20f58c-94ce-4ac5-8971-9337178fb90f
http://waterheatertimer.org/Water-heater-manufacturers.html
Apr 20, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I pipe (sump pump connection) near the hot water heater was leaking and the botton portion of the 'hot water heater' got wet, now the 'hot water heater' will not turn on. Should i assume the 'heater' is...
1) Electric heater, do not touch electric heater that is wet or has been wet unless power is 100% off.
2) Gas heater: Same applies to gas heater if controls are electronic, or if electric is grounded to hot water pipe.
3) Manufactures suggest replacing water heater that has been flooded.
Warranty is voided.
Set next heater higher.
4) Electric: You can replace thermostats and elements, but if insulation is wet, the unit could short and be continual electrocution danger >>> and you can't operate electric heater with covers removed because cool air will keep thermostats from reading correct temperature.
5) Gas: You can clean out combustion chamber and replace gas valve and burner assembly, but new heater from local hardware or box store will save time and possibly money.
6) Use old heater as tempering tank if incoming water is cold:
http://waterheatertimer.org/Tempering-tank.html
Or use old tank as solar collector:
http://waterheatertimer.org/How-to-make-a-solar-water-heater.html
Also take advantage of fixya expert assistance live.
For a price, expert works with you via while you work on water heater or any do-it-yourself project.
Feb 25, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Basement flooded;Water Heater insulation is a little wet on right side of entrydoor; Relighting the pilot light has been unsuccessfull; What do you reccomend?
tank looks to be leaking and getting the insualtion and floor wet .. so replace water heater?? Once the tank is leaking there is no repairing it..
Mar 16, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
353 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
