How do I add another dvd only two audio plus both used by harddrive and 1st dvd
  • Abdulhakim
    Abdulhakim May 11, 2010
    please clarify more.
  • 69 Answers
You can add a external usb dvd rom or add additional contoller if you have expansion slot open on mother board
Posted on May 09, 2010
HARDDRIVE ERROR ON SONY RDRHXD860 DVD RECORDER
http://www.avforums.com/forums/attachments/blu-ray-dvd-recorders-media/68631d1198812029-succesful-upgrade-hdd-rdr-hxd970-how-upgrade-hdd-sony-x70-series-dvd-recorders.pdf You shouldn't use a computer to format the drive as the dvd recorder will do that for you.
Oct 25, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
My laptop is running slow and i can not change my home page to centurylink, need a tune up!
Hi ,
1st- lets get the computer running faster , click on the start button and on your right side you'll see my computer , ,double click on the icon , this will bring up a screen showing your harddrive and dvd/cdrom ......right click on your harddrive ( C:\ ) scoll down the menu to clean disk . this will clean your harddrive .....then another menu will pop up showing you all the files you can delete , go throgh them to make sure you dont need the files ..........click on clean up and this is the 1st step ,
2nd - you can run disk defrag , this will also help yor system .........
OK , now for the centurylink , go into the control panel and click on internet options , this will bring up your service provider , make sure you have centurylink.com as the home page ..........
if you need more help , let me know ....................Good luck Roy
Aug 27, 2011 | Computers & Internet
Data transcoding taking too long.
Transcoding takes up an enormous amount of computer power. The best ways to help your transcoding go faster are to:
Check that your hardware is optimal for your computer setup. Free your operating system of unnecessary application that often run in the background taking up resources. Move all of your temporary files, used for transcoding, to any harddrive other than C. Having them share space with the operating system will slow you down further. Always work from your harddrives and be certain your operations don't include the active use of a CD or DVD rom drive. ROMdrives are notoriously slow compared to the average harddrive. If you have money to spend, a solidstate (non-flash type) harddrive would also really speed your transcoding up. You would also be a good candidate for a 64 bit operating system.
Good luck! William
Mar 01, 2011 | Corel Ulead VideoStudio 11 Plus for PC...
A770E3 MOTHERBOARD 4 GIG RAM SATA 1 TERABYTE HD SATA CD/DVD NETBIOS SEE EVERYTHING FINE. BOOT SEQUENCE FOR CD ROM 1ST PROBLEM. WONT BOOT ANY OS. XP PRO ORIGINAL DISK LINUX UBUNTU...
You can get a manual here:
http://www.biostar.com.tw/app/en/mb/content.php?S_ID=450
Did you set the boot sequense in your bios ??
First your CD or DVD drive
Second you harddrive.
Harddrive must be in sata 0.
CD or DVD must be in sata 1.
Or look in the manual how the settings should be.
Good luck.
Feb 27, 2011 | Biostar A770E3 AM3 AMD 770 ATX AMD...
I have a Dell Dimension 4600. When I burn an AVI file and play it back, there is some missing audio and jumping video that occurs. I have burned DVD videos with no problems. What could be wrong here? Thank...
1st convert AVI files to MPEG2, use a good converter....
use WINAVI 9...
use a codec called FFDSHOW....
use Nero (Nero Vision) to burn DVD...it will take some time...to burn...
i bet your will never fail .
or
just
add the AVI file in Nero(Vision...make movie option/ Export option / Configure option...) and let it convert to MPEG2 first....
then use the Make DVD option in Nero Vision and then make your menu etc and Burn
Jan 21, 2011 | Dell Computers & Internet
Cant start my laptop it reads "reboot and select proper boot device and the screen is black ?
Go in to bios by pressing del key sometimes F2 or F1 and see if your harddrive is set to 2nd highest boot priority.Set your CD/DVD drive to first. Save your settings and exit. Remove any cd's/dvd's you may have in your drive plus if you have a flash drive plugged into the usb port unplug it before starting.
If you still have this problem, your harddrive might have a problem with the booting files on it. Reinstalling or repairing windows will fix this. Put your windows disc in and boot to it.
Hopefully you wont have a problem installing or repairing windows or your harddrive could be bad. Before buying a new harddrive for it try removing it from the bay and reinstalling it, in case of a bad connection (example:harddrive wasn't fully connected.).You could go into bios and see if it shows up there.
Hope this helps ya.
Jan 10, 2011 | Computers & Internet
I add another dvd rom to my PC but it refuses to load my operating system. my OS is windoow xp celeron iv with 40G hard disk. Desktop computer with 256GHz ram. I eqully returned the rom using corect...
there may be a clash of IRQs of the DVD ROMs....
the 1st DVD ROM has been alotted a IRQ and then you connected the 2nd DVD ROM but the OS does not know which DVD ROM drive to look for while loading the OS to look for the boot CD....based on the setting in BIOS for boot order....
plus you may have to define both the DVD roms as primary and slave by making changes in the jumper cables...
(google and loacte the solution for the jumper setting for that)
reg
May 05, 2010 | Computers & Internet
My problem is my mainboard being a m2n mx se plus [replacement board] is only a two days old.When I ripped a cd to my 2nd harddrive it came up with following Delayed Write Failure and then later on this...
Check your second harddrive. First check its connection try to reseat it. Secondly, maybe its failing and somehow messing your CPU to boot up. You could try to disconnect your second harddrive for the meantime its power connector and interface cable. Then boot up with only your 1st drive where your OS is installed I suppossed.
Boot up, if this boot with no problem, 2nd harddrive is failing.
Apr 04, 2009 | ASUS P4V8X-X Motherboard
Harddrive
Get into boot setup and change the 1st boot device as hard disk
Dec 30, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
