Question about Peg Perego John Deere Gator HPX Ride on Toy
I can't find where to plug the charger into the tractor to charge the battery. No manual and wife doesn't remember.....
    Genius:
  • Peg Perego Master
  • 1,508 Answers
The battery is behind the front grille, you have to remove the screw in the middle and then pull out on the green plastic clips on each side then fold down
Posted on Jun 14, 2012
2 Suggested Answers
  • 156 Answers
SOURCE: I can't find where to plug the charger into the
You can get the peg perego manual for the gator at
http://www.shopjandl.com/
I get all my parts from these guys, plus they know what they are talking about when it comes to repairs.
The battery is in front, behind the black role bar.
Hope this helps
Posted on Mar 16, 2010
Testimonial: "Thanks a lot. I appreciate it."
Peg perego john deere tractor charger indicator light does not light up and tractor does not take a charge - brand new
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
I was using my psp while it was charging and the charging light turned off, so i naturally assumed that it was fully charged. But a few minutes later the battery died and it wont charge when i plug it in....
Have you tried to remove the battery and put it back in and try to turn it on. Try removing the battery and putting the charger in and starting the PSP. If it starts, it might be the battery. If it doesn't, it's either the plugin for the charger or the PSP is just dead. If it does start with the charger, try putting the battery back in, if it charges awesome. If it doesn't the battery might be dead.
Sep 27, 2011 | Sony PlayStation Portable (PSP) Console
Battery doesn"t charge
I don't see how this is related to the float?
With the engine running, measure output voltage from the alternator/charger at the battery. It should be about 13.5 vDC. It should increase a little bit with higher revs. If voltage doesn't change with engine running vs. engine off then you probably have a bad alternator which probablly has to be replaced or repaired by a service shop.
Jul 18, 2011 | John Deere 420,1020,2010,2020,2510,2520...
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
Given a hand me down Dexton Lil Driver Battery Golf Cart. Is there an online manual to find out what the charging cord looks like & where to plug it into the cart.
To charge... you need to remove the seat. Only 2 screws holding it in place. Underneath you will see the battery...you will notice wires from the battery connect to wires from the motor on the wheels...pull apart those 2 connectors and attach the charger...then plug it in to a wall socket and leave connected for a long period of time. I don't remember how long it takes for a full charge...but I'm thinking at least 12 hours. If the battery doesn't hold a charge you can typically get it at walmart or online. Best of luck.
Jan 30, 2011 | Toys
Hope this helps
Mar 16, 2010 | Peg Perego John Deere Gator HPX Ride on...
Bought a replacment battery for A30 and charging indicater does not show battery is charging
Im not sure what you are asking but I will try anyway.
You just want to see when you are charging?
Does the computer work when the charger is disconnected?
Most new batteries require hours to charge before they give any function.
How long will depend on the battery and charger. See the manual.
My battery took 2 days and I was angry. (24 hrs the manual said)
I put my wifes charger on and it began to function.
After that, my charger worked but not before...
Let it charge for 24 hours. Then see what happens.
Mar 16, 2010 | IBM ThinkPad A30 2652 Notebook
Peg Perego John Deere Gator HPX Ride on Toy Logo
43 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
