Player will not load dvd disk. Advises 'no valid disk'. But will play cd.
MYSTRO
  • 6 Answers
SOURCE: player won't play any disks only says CANNOT LOAD DISK
change the way you connect the dvd player to your tv
Posted on Jun 22, 2007
SOURCE: LG DVD player LG276
I picked up a LG DV276 DVD Player here in Australia but I am from the United States so I own region 1 DVDs. I unlocked my new player by instead 1. Open the tray. 2. Press 0 0 0 0 on the remote and a Menu will appear. 3. Press 0 for region free. 4. Press pause and power off.
I can play everything now, Aussie and US DVDs. Thanks LJ66.
Posted on Jan 01, 2008
humbletech
  • 31 Answers
SOURCE: portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Posted on Dec 03, 2008
stonephoenix
  • 563 Answers
SOURCE: dvd player won't load disk
The only troubleshooting you can try is to unplug the unit for 30 minutes. If the problem persists, the unit needs to be repaired. If you're under warranty, the manufacturer will repair or replace the unit. If you're out of warranty, they may have an out of warranty exchange or repair program.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 04, 2009
SOURCE: Clear Play DVD player
I just encountered the same problem. We've had our player for quite a while, but it seems like there ought to be a way to fix it from home. I don't mind taking it apart if that is needed, but I'd can't just buy a new one each time!
Posted on Apr 13, 2010
This is a complex problem. I have an hp dv7 3162nr, Windows 7 (64 bit). The Blu ray/DVD player will not function. It will play the FBI warning but then stalls and plays no more. It does this on all...
I am no expert, but try an external DVD player and if it does not work, then I would suspect that there is a Windows problem. Or you can try a Windows repair if you have the Windows disk. You can borrow a disk from any one who has a Win 7 64 bit version disk, and do the repair from the menu that appears when you insert the disk. Failing this, you may be at a point where you need to R&R the OS. Do a data back up first to preserve your data. Re-reading your post, you may not be able to run the Win 7 disk either. It may be a motherboard problem, which my experience last year with an ASUS video card problem, it was less $ to buy a new laptop, which I did. Hope this helps.
Sep 13, 2013 | HP WA801UA DV7-3162NR Notebook PC - AMD...
Not a valid disk
HI,
The problem is with the DVD player.Pleas use a leans cleaner to clean the lens.
I will give you more home remedies if they don't help then you will have to get this repaired.
Oct 12, 2008 | Toshiba Televison & Video
Cd says loading error and wont play
disks re lazer screen needs cleaning disk cleaner
Aug 12, 2012 | Alpine IVA-D100 6.5" Wide LCD w/DVD/CD/MP3...
DVD Player Not loading Movies
optical sensor is burned out or the spindle is not spinning the disk to read it.
Nov 06, 2009 | Coby DVD-224 DVD Player
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Portable dvd player showing"no valid disc"
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
No disk
Try playing Different DVDs, Second Make sure which Region Disk your playing is it Region 1 or Region 2, If your DVD player is Manufactured in USA it plays only Region 1, If its manufactured in UK it plays only Region 2, If still you face same problem Use Lens Cleaner, If still you face same problem do Reset.
To Reset Dvd player, Remove DVD from Dvd Player, Unplug Power chord from Walloulet for 15minutes so player goes to Defult Factor Settings, Then plug back again Power chord. Turn on Dvd player insert DVD, It should Play or else Claim Warranty.
Nov 29, 2007 | Curtis DVD8017 Portable DVD Player
DVD not playing
here is the link to the user manual, troubleshooting and venturer support contact details; http://www.1800customersupport.com/products.aspx?view=93&p=43&sc=5&sn=Portable%20DVD%20Players&pn=DVD%20Players%20and%20Recorders Hope this helps, please post again if not :)
Jan 30, 2007 | Venturer PVS177W Portable DVD Player
INSIGNIA IS-PD040922
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
Nov 27, 2006 | Insignia IS-PDO40922 Portable DVD Player
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
