I have a Govideo VR2940 DVD Recorder VCR. My Control Receiver is a JVC RX-8040B. I wish to Use the JVC Remote to "manage" the DVD/VCR functions. I need to know what the Manufacturer's Code is. Govideo is not listed in the JVC Manual. Most other manufacturers are. What Code Number should I use?
  • 25 Answers
The remote code should be one of the following three digit codes, 359,368,375. Good luck.
Posted on Mar 27, 2008
SOURCE:
Go video manual
Go to http://tv.manualsonline.com/manuals/mfg/govideo_1/vr2940_1.html?p=1 there are print and a download icons down the page a bit.
Jul 26, 2014 | GoVideo VR2940 DVD Recorder/VCR
Cannot get a dvd out of the govideo VR 2940 DVD recorder. Screen says locked
Disconnect it for a minute, then plug it back in. It should reset it and you should be able to remove it.
May 15, 2011 | GoVideo VR2940 DVD Recorder/VCR
We have a govideo vr2940 and the dvd recorder does not copy vhs to dvd. the machine wont read the disk. we tried different types of blank dvd's but still says no disk. i found a solution that says...
I've had this problem (No disc) with my VR2940 and was preparing to open it up and find and clean the lens that detects the disc. This was suggested as a solution.
However, I used a can of compressed air (enviro-duster) and sprayed air in the drive slot (back and forth since I don't know where the lens is located).
No problem since, but I keep a can handy.
Norm
Apr 03, 2011 | GoVideo VR2940 DVD Recorder/VCR
Dvd recorder vcr combo 4940 will not recognize dvd disks
DVD RECORDER VCR COMBO VR2940 WILL NOT RECOGNIZE DVD DISKS
Mar 28, 2011 | GoVideo VR2940 DVD Recorder/VCR
Need codes for Go.Video remote control
Go video remote for dvd/vcr recorder combo; you program TV by 2 digit codes. press TV power down when TV is powered on; and input 11 for JVC TV, or 03 for GE TV. You can experiment any two digit codes until TV shut down, then you have just finished programing n150b remote. This also work for all LG dvd/vcr combo recorder remote such as 6711RN203A..
Mar 08, 2010 | GoVideo Go Video DVD/VCR Combo
Tne dvd door will not open
These are instructions to open door if DVD is jammed or the DVD recorder wont open.
Unscrew the 7 cover screws and the 2 foot screws. Remover player cover.
Pry the front control cover off from the top of the player and not the bottom with a thin screw driver paying attention not to crack or break the tabs. Just lift them enough to clear the hooks.Then lower the cover withut removing it so you can gain access to the DVD front internal bezel.
On the left side of the DVD recorder there is a notch with a lever in it. gently push on it as this is the release for the DVD door. Remove DVD from tray and close.
Re-install all covers and screws. Machine should work after this.
Jan 17, 2009 | GoVideo VR2940 DVD Recorder/VCR
Manual for a govideo
hello chipl
i only just seen this post check here
http://www.fixya.com/support/p191572-govideo_vr2940_dvd_recorder_vcr_combo/manual-18741
riz.
Jul 21, 2008 | GoVideo VR2940 DVD Recorder/VCR
Timer recording on GoVideo VR2940
First, you need to have the cable directly input into the recorder.
If you only plug the cable box into the machine, you get what is happening now.
After splitting the cable, one side into te box and the other into the recorder, run the channel seek part of the program and it will scan all the channels available on the cable and place them in memory.
Then plug the output of the cable box into the other input on the recorder, and you get yor pay channels and upper tiers.
Your recorder is now a switching unit as well
Woody [email protected]
Nov 19, 2007 | GoVideo VR2940 DVD Recorder/VCR
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
Ekse
