Question about Hoover AAA160 Front Load Washer
Hoover vision 1600 inter@ct - error 3 occurs on most washes
4 Suggested Answers
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
Posted on Jun 08, 2008
SOURCE: Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Posted on May 07, 2008
  • 6277 Answers
SOURCE: I have a hoover machine
It has been unable to drain all of the water out in its alloted time ;-0)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 10, 2011
Reset button on hoover inter@ct washing machine hnf 9147 z
try this link out you should find how to reset it here-
http://www.manualslib.com/manual/644650/Hoover-Hnf-9167.html?page=37
Sep 26, 2015 | Hoover Washing Machines
Which is hot and which is cold pipe on Hoover vision 1600
With the lid off, the cold one goes to the prewash bit of the powder dispenser and the conditioner syphon. The hot goes to the main wash powder dispenser. On the back there should be a H and C stamped into the metal (difficult to see when painted white!) and the cold often has a blue dot on the plastic thread.
May 18, 2012 | Hoover AAA160 Front Load Washer
Error of hoover vision 1600
Hi again! Answered on your other posting ;-0) John C
Sep 10, 2011 | Washing Machines
My Hoover 1600 AAA Vision HD 8 kg. Washing machine will not open the door after programs are ended. I can run all programs, but when finished the door will not unlock! What is wrong? I dont have the...
try pushing the door really hard if it opens check the door seal is on properly sometimes they pull off when removing clothes they can get trapped in hinges
Jan 17, 2011 | Hoover AAA160 Front Load Washer
Error code 9 on hoover vision hd
Dear Carol. I'm writting to you because I encounter the same problem with the same washmachine (Hoover Vision HD 9kg): fill/empty ok but the drum won't turn = error 09!
My guarantee is out of date only from 3 months and Hoover Switzerland won't help me (I have to pay for the reparation more than the machine price!!!)
I've read on another web forum that the problem could be due to an electrical component (BTB12-600BW), but before to try to change it by myself, could you please tell me how did you resolve your problem???
Please, answer me at "maisoui_cyber@hotmail.com"
Thank you
Johan
Jan 10, 2010 | Washing Machines
Instructions for Hoover Washer Time 160E
i have a hoover soft wave maxi 1600 7.5kg AAA it spins and empty's and sometimes it don't what could be the fault
Nov 23, 2008 | Hoover AAA160 Front Load Washer
Error code 8 on Hoover vision hd 9 kg frontloader. No Manual.
Had same problem wouldnt spin found clip on motor had come loose pushed it back on problem solved!
Nov 18, 2008 | Hoover AAA160 Front Load Washer
High summerzaman,
with regard Andreas
Apr 11, 2008 | Washing Machines
Have the same problem, different model and it looks like I am outside 5 years spare parts. Probably just a belt or something from overloading. Also looks like it would nearly be cheaper to buy a new machine.You must have checked your pump???? What a rip off
Nov 27, 2006 | Hoover HF7 160E Front Load Washer
Hoover AAA160 Front Load Washer Logo
389 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
